1993 E300 wont start - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 04-30-2019, 07:06 PM Thread Starter
Kirby Henry Jr.'s Avatar
Date registered: Sep 2018
Vehicle: 1989 190e 2.6 & 1993 300E 3.2
Quoted: 16 Post(s)
ive been having this problem with my 300e where it will not let me start it when its in park, but it will in neutral. it did that about 3 times ad now it wont do anything.the radio will play and the lights all work but the motor wont do anything, the fuel pumps wont even kick on.any idea what this is?i think its the neutral safety switch.when i try to put into park it wont click like it will every other gear.. thanks for any help in advance
Kirby Henry Jr. is offline
post #2 of 9 (permalink) Old 04-30-2019, 08:25 PM
Date registered: Oct 2006
Vehicle: 95" W124/ E220 MasterPiece and 01" W210/ E200 KOMPRESSER
Quoted: 47 Post(s)
Gear recognition device was gone... People call it a backup light switch.
That is why you could start the motor at N or P.
Once the device cannot identify your gear position, your neutral safety mechanism will prevent the starter to engage.
It is attached to the left side of your transmission belly.
A Simple plug-and-play DIY.
jimmyhsiung is online now
post #3 of 9 (permalink) Old 05-01-2019, 03:02 AM
Date registered: Apr 2019
Vehicle: Soon
hope you get it working soon!
bigeast is offline
post #4 of 9 (permalink) Old 05-01-2019, 04:32 PM Thread Starter
Quoted: 16 Post(s)
so this might be a long shot but, i also have a 1989 190e motor and transmission that i pulled out for the ls swap...and from what i am finding online, both transmissions are the same?? so if i am reading this right i can just swap out the Neutral safety switches??
post #5 of 9 (permalink) Old 05-02-2019, 04:31 AM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 474 Post(s)
It shouldn't be too hard to match them up or to read the part number on them both. You can also repair the bad NSS.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
post #6 of 9 (permalink) Old 05-02-2019, 02:29 PM Thread Starter
Quoted: 16 Post(s)
How would i reapir a NSS?
post #7 of 9 (permalink) Old 05-02-2019, 07:27 PM
Quoted: 47 Post(s)
190E 2.6 (Chassis 201.029) comes with a 722.4 AT and this 722.4 switch wont fit on a 722.3 AT.
But some of the chassis did come with a 722.3 AT.
So you might take a look at your AT to make sure its fitting.
If you like to repair it, do it this way.
1. Open the switch plastic cover. Be careful not to damage it.
2. Locate its relevant gear contact pins and give a good clean or bend it a little bit.
So the both sided contact will be good enough to send its signal "strong enough" back to its receiver.
3. Lube its joints and seal the cover.
The fastening is rivet-type...so drilling might be a good method to "open" the cover....
Good luck.
post #8 of 9 (permalink) Old 05-03-2019, 05:06 PM Thread Starter
Quoted: 16 Post(s)
i was trying to see if i could get the 300 started again today with no luck, i also forget to add in the first posted that i wrote that the fuel pumps do not charge when i try to start the car. the radio and everything else does.is this still the NSS?
post #9 of 9 (permalink) Old 05-03-2019, 06:15 PM
tuttebenne's Avatar
Vehicle: W124
Quoted: 474 Post(s)
Its easy; I've done it. Drill out the rivets and open it up and see what is wrong. Usually the contact surfaces need to be dressed. Then pop rivet it back together. Easy peasy.
If your fuel pumps do not run, you have a second problem.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
1993 190E 2.3 No start after dead battery & swap. Sephrantill W201 190-Class 10 03-18-2016 05:57 PM
93 e300 no start issue bennzz W124 E,CE,D,TD Class 5 10-12-2012 10:51 AM
99 E300 TD hard to start after getting hot tomfreed W210 E-Class 63 09-02-2009 12:04 PM
1993 E320 sudden no start situation Blago W124 E,CE,D,TD Class 1 07-28-2009 03:13 AM
98 E300 TD - cold start good, hot start BAD! veggiebenzE300 W210 E-Class 26 07-04-2009 08:34 AM
