Windshield trim - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 04-25-2019, 11:38 AM Thread Starter
Real1shepherd's Avatar
Date registered: Jul 2009
Vehicle: '92 300TE 4matic 280,000miles, '92 300TE 4Matic 'Ice Blue Metalic' 101,000miles
Quoted: 486 Post(s)
Windshield trim
I'm getting ready to have my windshield replaced (thanks Safelite for turning a small chip into a crack that goes clear across my windshield). I've removed all the trim before for various reasons...BUT, I've never taken the one off the top; where the painted metal meets the glass. I can save almost a hundred dollars by removing everything, including the wiper motor so all they have to do is replace the glass.
I can feel that top trim piece has some flex with my fingernail. I would assume it has push in keepers like the side trim pieces?
Kevin
Jayare likes this.
Real1shepherd is offline
post #2 of 8 (permalink) Old 04-25-2019, 01:11 PM
dtsdig's Avatar
Date registered: Feb 2011
Vehicle: 1994 Mercedes E320 Sedan 97K, 1995 Mercedes E320 Wagon 156K, 2009 VW EOS 45K (Wife's car)
Quoted: 104 Post(s)
Send a message via Skype™ to dtsdig
I can't answer your question, unfortunately. I have only every messed with the small metal clips that hold the side trim in place and I don't know if they are the same for the top.
I did want to ask, what is the plan for the plastic channel at the bottom of the glass that holds the rubber molding in across the width of the windshield? I remember reading a thread years ago that mentioned that channel does not come with glass from places like Safelite. My windscreen is fine but my channel is all busted up. I don't know what options there are as I don't think it's available as a separate part.
dtsdig is offline
post #3 of 8 (permalink) Old 04-25-2019, 01:42 PM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 576 Post(s)
The manual makes it look like you just pry off from the end with a plastic tool. Still makes one nervous until you actually see underneath. Good luck.
luckymike is offline
post #4 of 8 (permalink) Old 04-25-2019, 06:38 PM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 483 Post(s)
Yes they pry off. If you can, pull some spare clips from a junkyard because its easy to have one or more pull off or break. The rivets are aluminum so drilling them out is easy. As for the wiper motor, I don't think that comes off for new glass.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
post #5 of 8 (permalink) Old 04-25-2019, 07:36 PM
luckymike's Avatar
Quoted: 576 Post(s)
For the attaching the rubber molding, I've read some people glue it into the broken channels. I chose to carefully apply horizontal strips of electrician's tape to secure the molding to the windshield. It blends in nicely and keeps water flowing in the right direction.
post #6 of 8 (permalink) Old 04-25-2019, 08:46 PM Thread Starter
Quoted: 486 Post(s)
Thanks guys! I'm very familiar with the moldings channels and those riveted receivers. I've used a rivet gun to put them back in...easy peasy. The old rivet remnants punch out easy and standard size US aluminum rivets seem to work just fine.
As far as the bottom moldings....I made the best two from the four I had. If your clip receivers are all in place, when you snap the molding in, it will hold those thin rubber strips in place against the glass.....although I swore the next time I did that, I'd glue them back on.
What worries me about the top piece is the shape....I'm betting if you get Medieval the bow shape could be destroyed. I have tiny plastic wedges and so I'll try prying from the ends. I do have the donor car if things go south.
Screw Safelite....I'm taking them to Small Claims Court if I ever find the paperwork I had before the move. But it's useless just to serve the company...the sheriff has to serve the manager or owner of the company by name. I have to figure out through WA State what jackass owns that particular franchise.
I don't trust the glass guys around that wiper motor...easier to just take it out for them. Gives them a clear, unobstructed shot at the glass.
Kevin
post #7 of 8 (permalink) Old 04-26-2019, 05:22 AM
tuttebenne's Avatar
Vehicle: W124
Quoted: 483 Post(s)
Kevin the bowing in the trim should be the least of your worries. Before the windshield is put in , check the bow in it to make is is close to the same as the original.
Jayare and Real1shepherd like this.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
post #8 of 8 (permalink) Old 04-28-2019, 07:33 AM
Date registered: Feb 2009
Vehicle: 1995 e320ce. 1993 230 TE. 1987 Kit car with 260e running gear.
Quoted: 85 Post(s)
Seal the ends of the glass with silicone or similar especially at the bottom corners.
I did this to my new screen in 2015 in an attempt to stop future milking/delaminating through capillary action.
boyd waugh is offline
2009-C230 Inerior Noises and Panel Flex Sounds 2009C2304MATIC W204 C-Class 18 07-29-2016 11:30 AM
Interior trim around the windshield John350 W126 S,SE,SEC,SEL,SD,SDL Class 3 06-29-2015 05:08 PM
chrome corner piece missing from windshield trim statred450sl R/C107 SL/SLC Class 4 05-29-2011 09:45 AM
Windshield Trim Panel tbjcc001 W126 S,SE,SEC,SEL,SD,SDL Class 2 09-12-2007 12:18 PM
Looking for Front Windshield Trim dpalmer W126 S,SE,SEC,SEL,SD,SDL Class 16 11-28-2005 03:04 PM
