Front left wheel: whining sound on slowdown - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 03-31-2019, 09:59 PM Thread Starter
tigerhunt2011's Avatar
Date registered: Mar 2013
Vehicle: 1995 W124 E320 Cabrio
Quoted: 47 Post(s)
Trying to figure out what could be on its way out.
Brakes recently re-done, all OEM pads, rotors, sensors.
Now diagnosing steering & suspension components--expecting a few replacements given LA's lovely road infrastructure
On the freeway, driving perfectly straight on smooth ground, I get a revolving whine in the left side front wheel when the car is moving slowly after it has been driving a while (when I've noticed it most is coming into traffic on the 405 after cruising comfortably for hours).
It does not present when accelerating, or driving at high speed. Only when slowing down, and not related to braking. It feels like it has something to do with the wheel.
Stock springs and suspension (wheel isn't rubbing or anything).
Is this indicative of worn bushings? Tie rods?
tigerhunt2011 is offline
post #2 of 9 (permalink) Old 04-01-2019, 01:08 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1092 Post(s)
Rotational sounds are more often associated with wheel bearing issues. Try "loading" one side of the car or the other ie sweeping right turn would "load" the left side of the car, then try in the opposite direction to "unload" the left side. Listen for the sound to increase or decrease depending...
Report back
Jayare
Sent from my XT1710-02 using Tapatalk
partnumber187 likes this.
Jayare is online now
post #3 of 9 (permalink) Old 04-01-2019, 07:50 AM
Walt'89300CE's Avatar
Date registered: Oct 2018
Vehicle: 1989 300CE & 1971 280SE; 73.5 911T
Quoted: 45 Post(s)
Buy a tube of genuine M-B wheel bearing grease, a pair of new wheel bearing seals- and repack your wheel bearings.
If the races are not all scored already.
Then you'll need new bearings & races.
Sounds like your car has never been maintained.
Walt'89300CE is offline
post #4 of 9 (permalink) Old 04-01-2019, 08:32 AM Thread Starter
Quoted: 47 Post(s)
bearings--I did not think of that. I've owned the car about a year--acquired with 67k miles on it. There was a maintenance gap between ~35k and my acquisition at 67k. Discovering the joy of bringing her back up to snuff.
Will touch back on bearings.
post #5 of 9 (permalink) Old 04-01-2019, 08:51 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1848 Post(s)
If your bearings are really worn out at 67K, then you've got to really suspect somebody rolled the odometer back at least 100K or more.
Just sayin'
sbaert is offline
post #6 of 9 (permalink) Old 04-01-2019, 08:56 AM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 576 Post(s)
I had a similar noise on our '95 E420 when we first bought it. Adjusted the bearings slightly and no issues since.
luckymike is online now
post #7 of 9 (permalink) Old 04-01-2019, 10:26 AM
Quoted: 45 Post(s)
67K miles- sorry, I must have you confused with someone else.
That's an almost new car.
Should change the ATF & filter, though.
post #8 of 9 (permalink) Old 04-01-2019, 01:10 PM Thread Starter
Quoted: 47 Post(s)
Just sayin'
I don't disagree, though all maintenance documents received with the car purchase do support authentic mileage if nothing else.
Between 35k and 67k the car was exported to Hawaii (and brought back prior to sale). I'm inclined to believe only basic maintenance was done during this window, by local "European" technicians, perhaps on cost-sensitive direction from the owner. So I've been uncovering all the fun deferred maintenance.
I've spent $10k so far learning what to look for when buying a 124 and I'd do it all over again...
one half of my mind says "a car with this few miles shouldn't have these issues" and the other half says "but at the end of the day, you'll have a 124 with under 100k miles with (head gasket/wiring harness/AC/etc) ready for another 100K"
luckymike likes this.
post #9 of 9 (permalink) Old 04-01-2019, 01:28 PM
partnumber187's Avatar
Date registered: Jun 2016
Vehicle: Mercedes-Benz
Quoted: 254 Post(s)
Somethings wear by miles, some by age, and low miles often worse on a car of that age. Grease that doesn't get worked often separates.
Jayare likes this.
Proceed with caution. >>>
#dontdealwithkahlil
partnumber187 is offline
Decoding ML datacards (what all those option codes mean!) stingray.au W163 M-Class 10 09-01-2016 10:30 AM
Anyone hosting Supplement 14? cbc atl W124 E,CE,D,TD Class 50 08-08-2014 10:57 PM
Squeaking or scrubbing noise from left front wheel mafitch W211 E-Class 3 08-31-2011 06:38 AM
no heat gargo11 W140 S-Class 20 10-19-2009 05:55 AM
whirring sound from front right wheel mgoldenbear W202 C-Class 4 12-08-2006 12:01 AM
