New member, 1990 300E - Page 3 - Mercedes-Benz Forum
post #21 of 31 (permalink) Old 04-04-2019, 09:25 AM
Date registered: Dec 2012
Vehicle: 89 190E2.6- 5-speed Manual, 95 E320 Sportsline-sold, 2001 E320 4matic Wagon-sold
Quoted: 534 Post(s)
Send a message via Skype™ to dolucasi
BTW, what you described is very similar to what I had when "one" of my wires were broken. Intermittent operation, only goes in one direction, etc. Also the motor did make a "little" noise sometimes as one of the strands must have been barely touching. This noise had me convinced that it must be the regulator. Did you open the door card and tug on the wires individually to make sure they are truly "in tact".
I was dreading the window regulator replacement before I diagnosed the real problem.
Oddly, it was my hardly ever used driver side rear door. Go figure. None of the other 3 doors have had any issues over the past 30 years.
dolucasi is offline
post #22 of 31 (permalink) Old 04-04-2019, 10:48 AM Thread Starter
Date registered: Mar 2019
Vehicle: 1990 300E
Yeah the wires all looked brand new. And the motor would work, albeit strangely, on it's own. Attached to the regulator it just clicked, nothing else. Mine is the passenger front door, which judging by the wear on the interior, was not used very much. Strange indeed.
I'm pretty sure a set of the AMG O.Z. rims would solve this problem.
infinitenexus is offline
post #23 of 31 (permalink) Old 04-04-2019, 10:49 AM Thread Starter
Vehicle: 1990 300E
Originally Posted by sbaert View Post
FWIW, the window motors are pretty durable on these cars. The regulators, on the other hand, should be considered a wear and tear item especially if you don't lube the tracks and gears every couple of years.
That old factory grease just turns to tar with age. I like Mobiltac NC375 for anything with open gears exposed to the elements such as the regulators, wiper transmission, etc.
I'm wondering if this is the issue. The regulator itself seems to be in fine shape, and everything moves and the big gear isn't missing any teeth. But the grease is old and sticky, so the motor would really have to work to raise the window, but lowering it gravity would help it down. I'm tempted to try just re-greasing everything to see if that works.
post #24 of 31 (permalink) Old 04-04-2019, 11:05 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1848 Post(s)
You need to remove the old tar like stuff with solvent, THEN relube with the proper stuff
sbaert is offline
post #25 of 31 (permalink) Old 04-04-2019, 07:06 PM
betapi's Avatar
Date registered: May 2005
Vehicle: 1995 E420; 1995 E320 Estate, 1995 C220 (GF)
Quoted: 16 Post(s)
I like your optimism :-)
(in relation to the OZ wheels...)
Last edited by betapi; 04-04-2019 at 07:07 PM. Reason: reply not specific in re to what I replied
betapi is offline
post #26 of 31 (permalink) Old 04-05-2019, 04:02 AM Thread Starter
Vehicle: 1990 300E
sbaert - any recommendation on a solvent?
betapi - While I'd prefer 16 or 17 inch for a more retro look, I'm currently drooling on these rims, which I'm sure would automatically fix the window problems and the catalytic converter
https://www.ebay.com/itm/New-18-inch...-/332885013733
post #27 of 31 (permalink) Old 04-05-2019, 04:50 AM
sbaert's Avatar
Anything decent like CRC Motor Pro works pretty good.
In a pinch, you can use gasoline or kerosone and the like as long as you're careful removing all of it (old grease, solvent, etc). This stuff tends to leave a nasty odor unless you're meticulous.
IF that old grease has really turned to tar, it helps greatly to heat it up using a old hairdryer or other heat source. Makes removal a bit easier.
sbaert is offline
post #28 of 31 (permalink) Old 04-05-2019, 05:48 AM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 483 Post(s)
^Actually heating it up and trying the window should prove whether or not you even need to go through the trouble of changing out the grease.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
post #29 of 31 (permalink) Old 04-08-2019, 04:33 AM Thread Starter
Vehicle: 1990 300E
It's definitely pretty tar-like, yet otherwise the regulator seems to be perfectly functional. Maybe I'll get lucky and just need a clean and a re-grease
post #30 of 31 (permalink) Old 04-08-2019, 09:59 PM
LeftCoastGeek's Avatar
Date registered: Jul 2011
Vehicle: 1993 300CE Cabriolet (mine) ; 1994 E320 Wagon (wife's) ; 1990 Benz 300E 2.6 (son's)
Quoted: 1299 Post(s)
Originally Posted by infinitenexus View Post
Hmm, thanks for the tip. I would like to lower it a little, maybe just an inch, but I don't really want a stiffer ride since it's my daily driver and my wife will be riding in it plenty. I was thinking maybe just chop a loop off each coil spring (with new shocks of course) to keep the ride soft and lower it a little bit.
lowering the car shortens the suspension travel, specifically the compression. if you don't compensate by using a stiffer spring, you will bottom out the suspension on road bumps/dips where the stock car would have had no problems. bottoming out the suspension too many times or too hard, and you damage hard parts.
LeftCoastGeek is offline
1990 300e vs 1989 300e jfine W124 E,CE,D,TD Class 17 08-17-2015 06:02 AM
FOR SALE - 1990 300E ALSO IN FOR SALE FORUM LTYLER W124 E,CE,D,TD Class 5 07-18-2011 08:27 PM
1990 300E FOR SALE - $750 - PHOENIX AZ LTYLER For Sale/Wanted/Trade/Giveaway 2 07-18-2011 07:55 PM
Transmission issues (1990 300E, 3.0L, 722.5 transmission) [email protected] W124 E,CE,D,TD Class 5 04-13-2011 07:29 PM
FS- MERCEDES BENZ 300E 1990 Tyler2005 For Sale/Wanted/Trade/Giveaway 0 06-27-2005 09:35 AM
