seat belt extenders, overhead light, windows - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-14-2019, 10:20 AM Thread Starter
Date registered: Feb 2017
Vehicle: 1994 Mercedes E320 Cabriolet
It's been awhile since I have been here.
It seems like my seat belt extenders, overhead light, and using the key to bring the windows up is not working...............
All at the same time.
1994 e320 Cab.
Overhead light will actually work, but when you shut the door, it stays on. So I now keep it in the center position.
I am thinking that perhaps a relay controls all three..... it appears that the system is not "reading" that the door has been opened. I guess it could also be the door switch in the jamb.
Any thoughts?
M. Schneider likes this.
natsoundup is offline
post #2 of 5 (permalink) Old 03-14-2019, 10:26 AM
Robert Kyle's Avatar
Date registered: Feb 2018
Vehicle: 1994 e320 coupe (sold), 1990 300CE ($400 beater)
Quoted: 164 Post(s)
check door jamb switch. Might have disconnected.
Cheapest, easiest to remedy if that's the issue.
Robert Kyle is offline
post #3 of 5 (permalink) Old 03-14-2019, 12:10 PM
LeftCoastGeek's Avatar
Date registered: Jul 2011
Vehicle: 1993 300CE Cabriolet (mine) ; 1994 E320 Wagon (wife's) ; 1990 Benz 300E 2.6 (son's)
Quoted: 1362 Post(s)
that stuff is all tied into the CF module under the back seat. if your rear floor has gotten damp in rain storms, everything is probably wet under there. the seat belt extenders have their own module, but it too is tied into the CF module.... and the cabriolet has its OWN unique CF module which is unobtanium.
cabriolet CF module from my 1993 300CE...
innards of the CF module from a 94 E320 wagon, just to see what it looks like...
LeftCoastGeek is offline
post #4 of 5 (permalink) Old 03-16-2019, 02:45 PM
Floobydust's Avatar
Date registered: Nov 2002
Vehicle: 2003 G500, 2000 SL500, 1995 E320 Cabriolet, 1980 TR8
Quoted: 96 Post(s)
Before indicting the CF module, I would check one of the ago old issues with the W124 - the fuses. In particular, check Fuses 1 and C as they are common to all three systems that you are experiencing trouble with. Check for corrosion on the fuse ends. If you have not already done so, you should change out all fuses to the copper based ones instead of the tin/lead version.
Real1shepherd likes this.
Floobydust: a contemporary term derived from the archaic Latin miscellaneous, whose disputed history probably springs from Greek origins (influenced, of course by Egyptian linguists) - meaning here "a mixed bag." - National Semiconductor Audio Handbook
Floobydust is offline
post #5 of 5 (permalink) Old 04-09-2019, 09:06 AM Thread Starter
As usual Flooby is right. It turns out fuse 9 was the culprit..... I have to get the copper based by Flosser.... another fuse went out last week..... it controlled the instrument panel....but also "locked out" the ability to start.
Go figure..
I don't think I am having any electrical problems... just old tin plastic fuses...
Decoding ML datacards (what all those option codes mean!) stingray.au W163 M-Class 10 09-01-2016 10:30 AM
Replaced the kfront passenger SRS Seat Sensor JDC-SoCal W163 M-Class 3 04-29-2014 09:19 PM
Electrical - new issues; central locking, seat belt warn and utility light flashing RhinoF18 W124 E,CE,D,TD Class 9 07-08-2011 12:13 AM
Seat Belt light indicator & Passenger Air bag light on SLK350 2006 SLK350Benz R171 SLK-Class 1 10-29-2007 03:19 PM
'03 E320 SRS light Seat Belt behavior jmorgis W211 E-Class 4 03-24-2007 12:32 PM
