1988 260E - Mercedes-Benz Forum
post #1 of 86 (permalink) Old 01-16-2019, 09:02 AM Thread Starter
Date registered: Sep 2011
Quoted: 8 Post(s)
1988 260E
Hey guys. Im Alen. Im new to the W124 section but Ive been in the W204 section for about 7 years or so over at MBWorld. Apparently I have an account here as well so I thought I would check this out on this site. I bought a 1988 260 E from a friend and I had a few questions. I did a quick search but some of this stuff I did not find any solid info on.
1. The OD Solenoid is out. Has anyone had to replace that before and if so what is the difficulty level?
2. Any things to look out for on this model and/or problems that I might run into?
Other than that the car leaks a little ATF that I need to figure out where exactly it is coming from as well as replace the battery and its for the most part in business.
ID:	2482038   Click image for larger version
ID:	2482040   Click image for larger version
ID:	2482042   Click image for larger version
ID:	2482044   Click image for larger version
amoffitt is offline
post #2 of 86 (permalink) Old 01-17-2019, 10:25 PM
LeftCoastGeek's Avatar
Date registered: Jul 2011
Vehicle: 1993 300CE Cabriolet (mine) ; 1994 E320 Wagon (wife's) ; 1990 Benz 300E 2.6 (son's)
Quoted: 1290 Post(s)
OD solenoid? which transmission do you have? the US model 260E's (and the rest of hte 6 cyl W124's) have a 4 speed automatic without any overdrive. shifter is labeled 2-3-D-N-R-P
LeftCoastGeek is offline
post #3 of 86 (permalink) Old 01-18-2019, 01:50 AM Thread Starter
Quoted: 8 Post(s)
I am not sure which transmission is in the car. This is more or less information passed on to me from the previous owner. I haven’t had a chance to really look the car over much myself. I parked it in the garage. I will have a bit of time in a few weeks to do some diagnostics myself.
amoffitt is offline
post #4 of 86 (permalink) Old 01-18-2019, 07:39 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1846 Post(s)
All 260E cars use the 722.4xx series transmission. IIRC, the 260 uses the 722.409 specifically
These cars had no overdrive, and in stock form all had 2nd gear start unless you forced a kickdown
sbaert is offline
post #5 of 86 (permalink) Old 01-20-2019, 01:14 PM
note you can force a start in 1st by putting the car in 2 for a second, then back in 3 while fully stopped... after doing this, the car will shift 1-2-3 as you accelerate (and 4th when you put it in D)
at least on our 260, putting it in D while still stopped seemed to reset this 'start in 1st' mode.
post #6 of 86 (permalink) Old 01-20-2019, 01:24 PM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1037 Post(s)
Have you looked into the owner's manual for how the transmission works? As LeftCoast mentions, while at a stop, put the gear selector into position 2, then back in D and the car will start in 1st. Put the selector in 2 and leave it there, the car will start in first and stay there until you do a quick 2-3-2 shift and it will go into 2nd and stay until you move to 3, then D.
Sent from my XT1710-02 using Tapatalk
Jayare is offline
post #7 of 86 (permalink) Old 01-21-2019, 01:11 PM Thread Starter
Quoted: 8 Post(s)
I have not looked through that. I had it delivered to the house and I have not drove it. The only thing that I was informed of is that it will not go over 50-55mph and that it was an issue with the OD Solenoid. A friend sold it to me and I had to go out of town before I had a chance to check it out much.
amoffitt is offline
post #8 of 86 (permalink) Old 01-21-2019, 01:14 PM Thread Starter
Quoted: 8 Post(s)
I will give it a shot and see if I have use of all 4 gears at that point and if I can go over 55mph.
amoffitt is offline
post #9 of 86 (permalink) Old 01-21-2019, 01:18 PM
a 260E should be able to cruise at 100MPH+ all day long. probably wind it up to at least 120 if you have enough road.
post #10 of 86 (permalink) Old 01-21-2019, 01:22 PM Thread Starter
Quoted: 8 Post(s)
Yea I figured it was a pretty solid car. I need to put in a proper battery as the current one does not hold a charge and I guess has been sitting in the car while the car has been sitting in storage or something since the terminals are more or less seized to the cables. Thats my first battle then I can get it properly started and be able to diagnose the issue.
amoffitt is offline
