1991 MERCEDES 300TE 4-MATIC replace control valve pressure reservoir - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 12-13-2018, 08:16 AM Thread Starter
Date registered: Sep 2018
Vehicle: 1991 300TE 4matic
Quoted: 15 Post(s)
Does any one have any tips or instructions on how to replace the 4matic control valve pressure reservoir. This is the globe/accumulator just ahead of the left rear wheel and part of the control valve unit. It is not the sls ones at the rear axle. Thanks G
gozody is offline
post #2 of 8 (permalink) Old 12-13-2018, 08:18 AM Thread Starter
Quoted: 15 Post(s)
Oops. My other left Its in front of the right rear wheel.
gozody is offline
post #3 of 8 (permalink) Old 12-13-2018, 08:42 AM
Real1shepherd's Avatar
Date registered: Jul 2009
Vehicle: '92 300TE 4matic 280,000miles, '92 300TE 4Matic 'Ice Blue Metalic' 101,000miles
Quoted: 498 Post(s)
Easy job...you find the appropriate size metric open-end wrench, unscrew (car completely shut off) sphere....make sure you have a new copper compression washer, screw new sphere on. You'll lose a few drops of hydraulic fluid....no need to rebleed.
If you trouble light should come on after this, then rebleed system....never happened to me.
Kevin
Real1shepherd is offline
post #4 of 8 (permalink) Old 12-13-2018, 09:54 AM Thread Starter
Quoted: 15 Post(s)
Kevin
Terrific. FYI, MB sent me a "rubber" washer instead of the old copper one we are all used to. I am sure it will be OK as it was already installed on the sphere. Its cold and snowy here so I don't know when I can install it but I will let everyone know how it went after I do. Thanks G
gozody is offline
post #5 of 8 (permalink) Old 12-13-2018, 10:40 AM
Quoted: 498 Post(s)
I can't see a rubber washer working versus the original crush washer. You can try it but.....
I bought an assortment box of metric copper crush washers off Amazon...I can't tell you how many times that has saved my butt.
Kevin
post #6 of 8 (permalink) Old 12-13-2018, 10:53 AM Thread Starter
Quoted: 15 Post(s)
Kevin
good idea.If it leaks I will do the same
gozody is offline
post #7 of 8 (permalink) Old 12-13-2018, 05:00 PM
Date registered: Nov 2002
Vehicle: 2002 E320 4Matic Sedan
Quoted: 27 Post(s)
Normal pressure in the accumulator is 25-36 bar (363-522psi). A good test for a rubber gasket.
brooktre is offline
post #8 of 8 (permalink) Old 12-13-2018, 05:13 PM Thread Starter
Quoted: 15 Post(s)
Good to know. It's just oring at bottom of threads on stem. It could fail sooner than later but I am willing to wait and see.👍
gozody is offline
