Suspension Question - Page 15 - Mercedes-Benz Forum
post #141 of 151 (permalink) Old 06-07-2019, 01:46 PM
partnumber187's Avatar
Date registered: Jun 2016
Vehicle: Mercedes-Benz
Quoted: 268 Post(s)
Camber and caster are adjusted with eccentric bolts. Depending on how low the car is you might not get camber in spec without camber bolts or camber plates.
That aside, the shop is full of shit.
partnumber187 is offline
post #142 of 151 (permalink) Old 06-07-2019, 01:55 PM
260e crusier's Avatar
Date registered: Nov 2010
Vehicle: 1999 E320, 2003 E320 Wagon, 2005 C230K SS, 2010 Accord LX w Eibach & Koni FSD's
Quoted: 494 Post(s)
Originally Posted by E3201995USA View Post
I have a w124. Yes, I was looking at those what are the alignment specs for a lowered car, they have the sport version of my car which I assume is sportline, but I think mine is lower, I also don't know which ones to get exactly would any of them work?
You want to have the alignment set as close to factory specs as possible.
I have not installed new camber bolts on my W210 yet and have excessive negative camber. So far, I have not noticed any unusual tire wear. I did increased my front tire pressure by 4-5 PSI though and rotate my tires on a regular basis.
260e crusier is offline
post #143 of 151 (permalink) Old 06-07-2019, 01:55 PM Thread Starter
E3201995USA's Avatar
Date registered: Aug 2018
Vehicle: 1995 E320 Sedan
Quoted: 78 Post(s)
Ok so what are some decent camber bolts you recommend:?
E3201995USA is offline
post #144 of 151 (permalink) Old 06-23-2019, 01:13 AM Thread Starter
Quoted: 78 Post(s)
I also want to thank everyone who gave me advice and contributed to my post. I love the Bilstein and h&r spring combo it is honestly the best $1200+ I have ever spent including labor and a crappy alignment. I have put about a 1,000 miles on them and so far they are good. I am glad I didn't take any chances with cheaper springs. I messed with my old shocks my rear is like new and my front right is blown soaked in oil and my front left is very weak.
All I need now is a sway bar upgrade
and proper alignment!
I also got the strut mounts and foam stoppers replaced, the car sits very slightly higher in the rear than the front but that is good with my new heavy sub setup and it won't sag with rear passengers.
post #145 of 151 (permalink) Old 06-26-2019, 10:38 AM
brian.vanbaush@gmail.com's Avatar
Date registered: Mar 2017
Vehicle: 1992 300CE sportline, 1991 300TE 104
I asked about raising the front of my 1991 300TE two months ago. I bought new pads two burl and springs. Installation went ok, the right side was tough to align the spring and install it i the seat, the left side easy to align the new spring and get it in place. It is a must to compress at least 8 coils on the spring. The new springs are Lesjofors 4056827, coil dia is 11.6mm The old springs had RBW on them and were a larger dia coil - 15mm
The new ride ht is nice, as is the ride. 34cm to the wheel ctr on the front and rear.
Jayare and luckymike like this.
post #146 of 151 (permalink) Old 06-28-2019, 10:05 PM Thread Starter
Quoted: 78 Post(s)
Silly question, but can someone tell me if beefier sway bars noticeably reduce body roll?
post #147 of 151 (permalink) Old 06-29-2019, 08:49 AM
Quoted: 494 Post(s)
Bigger sway bars will help reduce body roll. It's noticeable when you drive hard, but nowhere close to the improvement provided by the H&R springs and Bilsteins.
post #148 of 151 (permalink) Old 06-29-2019, 10:16 AM Thread Starter
Quoted: 78 Post(s)
I have a friend who has a 2016 dodge charger rt road and track edition, I know his car is way faster but that's because it has 370hp engine and 8 speed transmission, but it weighs like 800 pounds more. Do you think it is possible for me to handle better than him? I think the lowering springs were night and day and make my car feel weigh more sporty, but I could tell there is a little bit of body roll still. So all I need are new beefier sway bars and bushings. Also, the suspension and reduction of body roll make it obvious how un-sporty the steering is in these cars. I will come back to this topic after fixing my cooling system.
post #149 of 151 (permalink) Old 06-29-2019, 11:47 AM
Quoted: 494 Post(s)
I have no respect for drivers that drive aggressively on the street. The kind that floors it when the light turns green and then weave in and out of traffic only for me to pull up to them in the right hand lane at the next stop light.
Sooner or later they will crash and burn taking innocent people with them. Just like that Charger that totaled my CLK. As*holes..........not saying you are one of them.
post #150 of 151 (permalink) Old 06-29-2019, 05:52 PM Thread Starter
Quoted: 78 Post(s)
Thx for saying I'm not one of them, I would never weave in and out of people, for my safety and others. I accelerate quicker and my turns are sharper than normal, but that's really it. Racing is for the track, not the street. I don't ever text or drive or do anything that could seriously harm anyone, I just blast music and enjoy my 95' Benz.
260e crusier likes this.
