Lost HP and Bad Mileage. - Page 8 - Mercedes-Benz Forum
post #71 of 174 (permalink) Old 05-31-2019, 06:19 PM Thread Starter
E3201995USA's Avatar
Date registered: Aug 2018
Vehicle: 1995 E320 Sedan
Quoted: 72 Post(s)
Guys I got some good news, I have been getting the CC/ISC module CAN Communication Error CEL many times, so I bought one off eBay for $80. Now my idle is so smooth compared to before. I still suspect a vacuum leak or something isn't right. I will wait till my CEL comes back and update you guys!
E3201995USA is offline
post #72 of 174 (permalink) Old 05-31-2019, 06:45 PM Thread Starter
Quoted: 72 Post(s)
Originally Posted by dtsdig View Post
Are you leaking anything out the back passenger corner of the block? I wonder if you have a head gasket allowing small amounts of coolant into the cylinders?
I will check when my engine cools down, no leaks on the floor accept some condensation. My diff is soaked in oil and I think it's leaking.
post #73 of 174 (permalink) Old 06-05-2019, 11:11 AM
Robert Kyle's Avatar
Date registered: Feb 2018
Vehicle: 1994 e320 coupe (sold), 1990 300CE ($400 beater)
Quoted: 163 Post(s)
any update? Cleared the codes?
Robert Kyle is offline
post #74 of 174 (permalink) Old 06-05-2019, 01:39 PM Thread Starter
Quoted: 72 Post(s)
I don't know if I have a head gasket leak, I probably don't. I got a used idle speed control/ cruise control module, and idle is so much better, cruise control still works and has always worked. My car runs like crap in the heat it revs high and doesn't work when the engine jumps up to 100 degrees. MY CAR IS BOTHERING THE #### OUT OF ME, i WISH I COULD SIMPLY FIND THE ISSUE!!! No check engine light codes.
post #75 of 174 (permalink) Old 07-05-2019, 04:44 PM Thread Starter
Quoted: 72 Post(s)
GUYS I REALLY NEED HELP, My abs light has randomly been coming on and off and everything else has been normal like if had horrendous 10-13 mpg, sometimes I have to crank longer than usual then the car starts, and today I came home from a short drive and my head unit reset and the idle shot up to like 2-3,000 rpm, and abs light came on I checked my ovp relay i got used of ebay and the fuses were blown. My old one was fine I only changed it cause apparently, it causes weird starts and bad mpg, it is the original one model number 000 545 52 45 fuses never went out on the original one, it has one 15amp use, the used "updated" one 201-540-37-45 goes out within a month, I did some research and found out it might not be the right relay, What is the most reliable-updated ovp relay model for the E320 1995 M104.092 engine?
post #76 of 174 (permalink) Old 07-05-2019, 04:51 PM
dude99's Avatar
Date registered: Nov 2009
Vehicle: 2003 Volvo V70 5 Speed
Quoted: 119 Post(s)
Have you checked your alternator output? If it is putting out too much voltage the OVP may just be doing its job.
1989 JDM 420SEL The new project
2003 Volvo V70 5 Speed -Current Daily
1983 BMW 733i Fixed up and traded for above 420SEL
1997 E290 Turbo Diesel Wagon -traded for the volvo, an amazingly comfortable car to drive, great drivetrain, but the rust, oh my god the rust
1992 BMW 525i -traded in for E290
1990 Silver 300TE -Sold Loved the wagon, hated the M103
1985 Grey 380SE Diesel Conversion, 2.47 rear end, ABS -Sold, really should have kept this one
1979 Silver 300D "The Silver Slug" -Sold
dude99 is offline
post #77 of 174 (permalink) Old 07-05-2019, 04:56 PM Thread Starter
Quoted: 72 Post(s)
how do I check that?
post #78 of 174 (permalink) Old 07-05-2019, 04:56 PM Thread Starter
Quoted: 72 Post(s)
Why would it be putting too much voltage, how is that even possible?
post #79 of 174 (permalink) Old 07-05-2019, 05:02 PM
dude99's Avatar
Quoted: 119 Post(s)
Voltage output is controlled by the voltage regulator, located in the alternator brush assembly. They can fail and allow the alternator to pump out too much voltage. Hence the OVP (Over Voltage Protection).
Start the car and measure the voltage over your battery at idle and and ~2000 RPM
dude99 is offline
post #80 of 174 (permalink) Old 07-05-2019, 05:47 PM Thread Starter
Quoted: 72 Post(s)
Good news(I think). So I put my old original relay back and abs light hasn't come on and cel disappeared. Idle was smooth everything seems to be working, I just want a backup relay cause mine is 23 years old and is the original one, what is the best-updated version for my car?
