W124 94 E420 won’t start HELP - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 10-08-2018, 09:17 PM Thread Starter
Date registered: Aug 2017
Quoted: 9 Post(s)
I have a 94 E420 and I was driving it and noticed my fans were going crazy but temperature was fine. Then as I was pulling onto my street I saw the ABS and ASR light come on and my fuel, oil, and temperature gauge dropped to 0. I parked my car in the driveway and shut it off then put keys back in and turned them and it wouldn't do anything. When the keys are in ignition and turned the battery light, ABS light, and ASR light are the only lights that turn on on the dash. No idea what it could be car was barely warmed up. Oil and coolant levels are fine. Please get back to me with potential issues.
DavidW108 is offline
post #2 of 18 (permalink) Old 10-09-2018, 05:24 AM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 848 Post(s)
check your alternator and battery
rumb is offline
post #3 of 18 (permalink) Old 10-09-2018, 09:03 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1859 Post(s)
^This, i.e. check the voltage regulator. Sounds like the brushes are worn. Replace with a new Bosch part if in doubt.
sbaert is offline
post #4 of 18 (permalink) Old 10-09-2018, 09:05 AM Thread Starter
Quoted: 9 Post(s)
Alternator and battery is fine getting charged still. Where is voltage regulator located?
post #5 of 18 (permalink) Old 10-09-2018, 09:07 AM
sbaert's Avatar
Inside the alternator.
sbaert is offline
post #6 of 18 (permalink) Old 10-09-2018, 11:12 AM
Robert Kyle's Avatar
Date registered: Feb 2018
Vehicle: 1994 e320 coupe (sold), 1990 300CE ($400 beater)
Quoted: 164 Post(s)
Battery jump not help?
Robert Kyle is offline
post #7 of 18 (permalink) Old 10-09-2018, 04:28 PM Thread Starter
Quoted: 9 Post(s)
Would my battery still charge with a bad voltage regulator? And does that explain the lights that are on as well as the gauges dropping?
post #8 of 18 (permalink) Old 10-09-2018, 10:38 PM
sbaert's Avatar
A classic dead giveaway for a worn or faulty regulator is the (faint) illumination of the warning lights and/or erratic instrumentation problems while the engine is running.
sbaert is offline
post #9 of 18 (permalink) Old 10-10-2018, 07:41 AM Thread Starter
Quoted: 9 Post(s)
Is it always faint? Because my lights were as bright as possible.
post #10 of 18 (permalink) Old 10-10-2018, 08:14 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1102 Post(s)
Have you put a meter on the battery? Once you get it started again, put your meter on the battery. You need no less than 13.8v showing.
Sent from my XT1710-02 using Tapatalk
Jayare is online now
