W124 94 E420 won’t start HELP - Page 2 - Mercedes-Benz Forum
post #11 of 18 (permalink) Old 10-10-2018, 08:32 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1859 Post(s)
^This, plus the voltage should also be less than 14.6V. In other words, you want to see a number between 13.5V and 14.5V
If the regulator is no longer "regulating" you will see a higher number accompanied by odd behavior of the electronics, lights, etc.
sbaert is online now
post #12 of 18 (permalink) Old 10-10-2018, 09:06 AM Thread Starter
Date registered: Aug 2017
Quoted: 9 Post(s)
So if I attempt to jump the car will it start?
DavidW108 is offline
post #13 of 18 (permalink) Old 10-10-2018, 09:15 AM
sbaert's Avatar
I don't know, that's for you to find out. Keep in mind that if the regulator failed and was putting out excessive DC voltages for long enough time it probably cooked your battery and most likely took other stuff with it if not more.
At a minimum, you'll need to check the the 4 mini fuses on the base module inside the module box.
post #14 of 18 (permalink) Old 10-11-2018, 03:19 PM
Robert Kyle's Avatar
Date registered: Feb 2018
Vehicle: 1994 e320 coupe (sold), 1990 300CE ($400 beater)
Quoted: 164 Post(s)
Robert Kyle is offline
post #15 of 18 (permalink) Old 10-20-2018, 01:27 PM Thread Starter
Quoted: 9 Post(s)
Would it maybe be an issue with the lower harness since all my gauges stopped working?
post #16 of 18 (permalink) Old 10-20-2018, 11:11 PM
sbaert's Avatar
No, but it does bump up the voltage regulator as being one of the prime suspects
post #17 of 18 (permalink) Old 10-27-2018, 09:32 PM Thread Starter
Quoted: 9 Post(s)
I replaced my alternator with a factory one. Car still wont start. Battery, ABS and ASR lights are all still lit. Gauges still arent working either. Any other possible reasons why this might be?
post #18 of 18 (permalink) Old 10-27-2018, 11:47 PM
sbaert's Avatar
Check for voltage and ground everywhere i.e. ground straps. Be sure to replace ALL the fuses (if not done already) with the updated copper core ceramic type such as those from Flosser. And as I said in post#13 at least check (or better yet just replace) the 4 mini blade fuses on the base module
Don't forget the weird little fuse on the back of the instrument cluster. That is a dealer only item, but costs next to nothing.
