1993 300TE AC issue. My mechanic doesn't know. - Page 22 - Mercedes-Benz Forum
post #211 of 245 (permalink) Old 07-11-2018, 05:15 PM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 687 Post(s)
Originally Posted by gsxr View Post
Originally Posted by Robert Kyle View Post
I dunno; this guy successfully installed an electric fan. I plan on doing this swap (I bought the same gear) eventually:
https://www.benzworld.org/forums/w12...oling-fan.html
If you look closely, you'll see that is a five-cylinder OM602 engine, not M104. As mentioned previously, they have very different heat loads. And, he lives in a cool climate. And, he mounted the fan to a proper shroud so it works more effectively than zip-tying a fan to a bare radiator core, with no shroud.
LOL no shroud? You don't say
I was doing some measurements on my [124] wagon with the 606 engine. I don't think I can fit any known production puller fans in there, so I'd need to spend big $ on SPAL units.
This is incorrect.
Triggering religious fanatics since 1969
tjts1 is offline
post #212 of 245 (permalink) Old 07-30-2018, 02:22 PM
126guyMD's Avatar
Date registered: Nov 2017
Vehicle: 1989 560SEC
Quoted: 40 Post(s)
gsxr....why the silence?
126guyMD is offline
post #213 of 245 (permalink) Old 07-30-2018, 02:35 PM
gsxr's Avatar
Vehicle: Buncha W124's
Quoted: 117 Post(s)
Been waiting for the OP to re-appear.
[popcorn]
gsxr is offline
post #214 of 245 (permalink) Old 07-30-2018, 02:38 PM
126guyMD's Avatar
Quoted: 40 Post(s)
opcorn:
ahh, OK. I was thinking it was because tjts1 nailed it on this one !!
126guyMD is offline
post #215 of 245 (permalink) Old 07-30-2018, 02:52 PM
gsxr's Avatar
Quoted: 117 Post(s)
Nah, his last reply in the debate was directed at Casey, and I'll let Casey respond if he's so inclined.
gsxr is offline
post #216 of 245 (permalink) Old 07-30-2018, 02:56 PM
126guyMD's Avatar
Quoted: 40 Post(s)
My guess: he's not inclined.
126guyMD is offline
post #217 of 245 (permalink) Old 08-01-2018, 07:34 PM Thread Starter
Jason4758's Avatar
Date registered: Jul 2017
Vehicle: 1993 300TE VIN: WBDEA92E7PF248963
Quoted: 36 Post(s)
A quick update:
I have done the following since my last post. I finished today:
1. Removed aux fan shroud, cleaned condenser with coil cleaner, and used a pressure washer (electric) to pressure was the ENTIRE condenser. (both sides of condenser)
2. Replaced the viscous fan clutch with a new MB OEM clutch.
3. Replaced all hoses with MB OEM hoses.
4. Flushed coolant a few terms and replaced with new Zerex G-05.
It took me longer than planned due to things like having to special order expanding rivets for the aux fan shroud...and special ordering the fasteners for the pieces that go to the left and right of the condenser....
I cranked up today, checked for leaks and seems as though all is correct. Tomorrow I will double check the transmission fluid to make sure I didn't lose any while removing the radiator.
WHAT I NOTICED when I started it back up:
1. I hear the "roar" when the engine is warm and the fan clutch is engaged. This was definitely not the case with the old clutch. Even when the engine is running at idle there is a significantly higher amount of air being moved with the new fan clutch.
2. In 95F weather I was able to let the engine idle, with the a/c on, for about 45 minus and the engine temp never got above @85C. Prior to the changes it would have been closer to 95 or greater.
Tomorrow I will drive in stop and go traffic, 90F-92F ambient temperatures....and see what happens.
So far....the results are great.
gsxr, Jayare, tuttebenne and 1 others like this.
Jason4758 is offline
post #218 of 245 (permalink) Old 08-01-2018, 10:34 PM
Date registered: Feb 2014
Vehicle: 1995 E320, 1995 E420
Quoted: 45 Post(s)
Did you get fan clutch from the dealer? Is it a Behr unit?
Based on past discussions on this forums, I was looking at a Sachs unit but they have gone out of stock with no availability date....
Originally Posted by Jason4758 View Post
A quick update:
mikeym is offline
post #219 of 245 (permalink) Old 08-01-2018, 10:54 PM
Real1shepherd's Avatar
Date registered: Jul 2009
Vehicle: '92 300TE 4matic 280,000miles, '92 300TE 4Matic 'Ice Blue Metalic' 101,000miles
Quoted: 481 Post(s)
A quick update:
Too early to say I told ya so but.....I was never happy with the fact that you didn't hear the clutch fan roar. And I mentioned that some members like Steve had tried multiple fans before he got a good one. In my old TE, the one I put in I never heard roar and in traffic, it would easily kick in the AUX fans...which was not how the system used to work when newer. This new-to-me TE you can clearly hear it roar. I can also hear the clutch fan roar in my work truck. I'm not sure the best way to test them working 100%, but you should hear a roar on hot days.
Steve should remind us which one he finally settled on....I think it was Sachs?
Kevin
Real1shepherd is offline
post #220 of 245 (permalink) Old 08-02-2018, 12:51 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1848 Post(s)
Kevin
I got the original OE MB clutch, supplied by Horton/Sachs
It's been installed for about 6 years now, without a single issue.
Keep in mind this was for my diesel, and I picked a clutch designed for the W140 S class turbodiesel.
Jayare likes this.
sbaert is offline
