Front Suspension 'Rough' - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-14-2018, 01:45 AM Thread Starter
RSK_W123_230E's Avatar
Date registered: Mar 2007
Vehicle: '92 W124 230E Auto
Quoted: 22 Post(s)
Since buying my W124 I've had issues akin to worn shocks and/or worn upper mountings. It felt like the wheel was hopping. Since one of the shocks was bouncing excessively I opted to change both shocks, upper mountings and rebound rubbers. I still have exactly the same issue when driving over road undulations.
I've checked the lower ball joints (taking up the spring pressure under the wishbone and then checking for freeplay) - nothing found, also found no play in the tie-rod ends or steering bushes. However, I did find that the steering damper was worn, collapsing and expanding with relatively no resistance. Could this cause the symptoms I'm feeling?
1992 W124 230E Auto, M102.982, 212,750 km / 132,968 miles, MBSA-built - CURRENT.
1985 W123 280E Auto, M110.988, 110,265km / 68,915 miles, MBSA-built - SOLD.
1985 W123 230E Manual, M102.982, 219,320 km / 137,075 miles, MBSA-built - SOLD!
RSK_W123_230E is offline
post #2 of 5 (permalink) Old 05-14-2018, 02:29 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1095 Post(s)
You bet. A worn steering dampner will cause excessive play in the steering when encountering road imperfections.
Sent from my XT1080 using Tapatalk
Jayare is offline
post #3 of 5 (permalink) Old 05-14-2018, 03:03 AM Thread Starter
Quoted: 22 Post(s)
Originally Posted by Jayare View Post
You bet. A worn steering damper will cause excessive play in the steering when encountering road imperfections.
Great, then it's a relatively cheap fix.
post #4 of 5 (permalink) Old 05-14-2018, 09:34 AM
Date registered: Dec 2017
Vehicle: 1995 E320 sedan
Also check the sway bar bushings. They are cheap and easy to replace DIY. My car was having weird noises and clunks and it fixed it.
w124_owner is offline
post #5 of 5 (permalink) Old 05-14-2018, 10:50 AM Thread Starter
Quoted: 22 Post(s)
Interesting point! I previously had a groaning noise on one side when going over speed bumps and when bouncing the car. I checked the sway bar bushes and eventually traced the noise to the outer mounting point there the bracket that secures the sway bar mounts to the chassis by having someone bounce the car while I checked. Loosening this bracket revealed a dry, somewhat corroded surface with some evidence of rubbing. Some grease on this surface before re-tightening silenced the front suspension.
