Blown Head Gasket! Questions.... - Page 9 - Mercedes-Benz Forum
post #81 of 106 (permalink) Old 05-06-2019, 09:26 AM
CheckEngine's Avatar
Date registered: Dec 2017
Vehicle: 1999 C280 (sport), also 2001 SLK230
Location: Redding, CA (for now) Boston, MA, & Mexico City
Quoted: 13 Post(s)
Well, I'll bet you're excited about getting your baby back on the road!
I noticed that your pulleys are quite rusty. If I were you, I'd take a wire wheel to them and then repaint them, or at least put something like a very thin coat of, say, linseed oil on them. I have an old Toyota pickup that just used to positively eat fan belts (the old style ones). It was quite a mystery until I figured out that it was the rust on the pulleys destroying them. Once I cleaned up the pulleys, it stopped eating fan belts.
Cheers and keep up the good work!
Kim G
Redding, CA
Where I really ought to get around to changing the coolant in my SLK.
CheckEngine is offline
post #82 of 106 (permalink) Old 05-06-2019, 12:29 PM Thread Starter
dtsdig's Avatar
Date registered: Feb 2011
Vehicle: 1994 Mercedes E320 Sedan 97K, 1995 Mercedes E320 Wagon 156K, 2009 VW EOS 45K (Wife's car)
Quoted: 104 Post(s)
Send a message via Skype™ to dtsdig
@CheckEngine Thank you and I will definitely be cleaning up the pulleys before I put a new belt on. They actually aren't as bad as the photos make them look but I'll be taking a wire wheel to them. It sure is exciting!
CheckEngine likes this.
dtsdig is offline
post #83 of 106 (permalink) Old 05-07-2019, 09:02 AM Thread Starter
dtsdig's Avatar
Quoted: 104 Post(s)
I got the throttle actuator installed last night which completes the motor itself and all associated vacuum lines and wiring (minus the valve cover).
I went to install the new drive belt and discovered the whole tensioner assembly was all frozen up. I thought it was strange that the damper was completely compressed when I installed that the other day but didn't think much of it because I have never dealt with the version 1 tensioner setup before, my 95 wagon had the much simpler version 2 auto tensioner. Anyway, after loosening the bolt in the center of the tensioner and spraying everything down, it takes a lot of force to move the tensioner at all. The adjustment rod is not happy. So, another parts order will need to happen, which stinks. I started another thread to see if anybody has ever converted their version 1 setup to a version 2 setup but I have my doubts.
Brand wise, Febi seems to be it at many retailers. I'm not a Febi fan but I'm also not spending $300 on a MB tensioner. I see Rockauto lists a Gates one and a Dayco one. Not sure about either of those.
dtsdig is offline
post #84 of 106 (permalink) Old 05-07-2019, 09:31 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1095 Post(s)
I have two 95 TE's that have different belt tensioners. One of each. Like you, I find the spring loaded version is much better that the old style.
I suspect the two versions would swap out. Otherwise, the blocks would need to be different due to theounting holes. Measure the pattern of the mounting holes on the block and see if they mate up to the spring loaded version.
Jayare
Sent from my XT1710-02 using Tapatalk
Jayare is offline
post #85 of 106 (permalink) Old 05-07-2019, 11:51 AM
humblejoe's Avatar
Date registered: Feb 2007
Vehicle: 04 odyssey (265k) 1995 E320 wagon (295k)
Quoted: 329 Post(s)
You can swap out, but need the fan bearing cover from gen 2 I think.
"alte Schulqualität"
W124, One of the last great gifts of West Germany
humblejoe is offline
post #86 of 106 (permalink) Old 05-07-2019, 01:16 PM Thread Starter
dtsdig's Avatar
Quoted: 104 Post(s)
I think you are correct. There is part number 1042001328 for the gen 2 fan bearing bracket and 1042001528 for the gen 1 version. I wonder what else changes with hardware, etc. I know the belt length is different as well. I wish I had both version cars in front of me.
In any case, in the interest of getting this beast fired up again, I just ordered the Febi kit and Stabilus damper. Parts should be here Friday which is also when I hope to have the refreshed valve cover back.
With any luck, I will be firing this baby up this weekend!
Jayare and CheckEngine like this.
dtsdig is offline
post #87 of 106 (permalink) Old 05-08-2019, 09:40 AM Thread Starter
dtsdig's Avatar
Quoted: 104 Post(s)
Here’s some shots from the powder coating guy. It should be done tomorrow!
dtsdig is offline
post #88 of 106 (permalink) Old 05-08-2019, 09:53 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 146 Post(s)
Make sure the people doing this job dont get the powder coat inside .
I removed a cover a few weeks ago ,- i will say it was an older W124 and all the black paint of the outer cover was missing, and insidethe cover i found that the paint was bubbled up ready to fall off ,,,and most had fell in to the valve lifters and cam shaft . Worth looking at your cars guys with these mercedes that have black rocker boxes that are powder coated ,.This is the truth i know .And if you open up your rocker box covers of the older type you will see the same fault. I hope yours is not like the one i opened up
This is a retro ride .
plinker17722 is offline
post #89 of 106 (permalink) Old 05-08-2019, 11:37 AM Thread Starter
dtsdig's Avatar
Quoted: 104 Post(s)
The original paint on the inside of my cover was flaking in some areas. I asked that the inside be blasted as well but it won't be coated inside.
Real1shepherd and CheckEngine like this.
dtsdig is offline
post #90 of 106 (permalink) Old 05-09-2019, 06:36 AM Thread Starter
dtsdig's Avatar
Quoted: 104 Post(s)
I pulled the belt tensioner, damper and adjuster shaft out of the car yesterday. Pretty easy job with the right tools. I've got a really old Snapon 3/8" air ratchet that is a torque monster which makes removing pulley bolts a piece of cake. Once the water pump and PS pump pulleys were out of the way, it's just a few bolts to get the tensioner and bracket out. It's funny I'm still pulling things apart when I'm supposed to be putting things back together! Oh well, it will give me a chance to clean up that side of the block better than I could before. Strangely, the adjuster shaft was actually fine (I thought I stripped it the other night) and the bushing/bearing/rubber on the tensioner all looked fine but I do believe it is pretty bound up. I'm glad to be replacing it all and amazingly, the little plastic ring with the pointer on it is still in perfect shape.
dtsdig is offline
