Blown Head Gasket! Questions.... - Page 6 - Mercedes-Benz Forum
post #51 of 106 (permalink) Old 04-09-2019, 10:41 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1848 Post(s)
When it comes to seals and gaskets on German cars, I always go OE without exception.
Nothing worse than having to do the same job twice, especially if you're not getting paid on round 2.
CheckEngine likes this.
sbaert is offline
post #52 of 106 (permalink) Old 04-09-2019, 11:39 AM Thread Starter
dtsdig's Avatar
Date registered: Feb 2011
Vehicle: 1994 Mercedes E320 Sedan 97K, 1995 Mercedes E320 Wagon 156K, 2009 VW EOS 45K (Wife's car)
Quoted: 103 Post(s)
Send a message via Skype™ to dtsdig
The original gaskets literally say Elring on them. I would call that OE, no? Anyway, that's what I'm proceeding with.
dtsdig is offline
post #53 of 106 (permalink) Old 04-09-2019, 12:18 PM
sbaert's Avatar
Ask that question to the M103 guys re. Bosch cap and rotors. You can buy the Bosch branded stuff and have it last 6 months to a year if you're lucky. OR buy the OE MB cap and rotor made by Bosch and have it last years.
sbaert is offline
post #54 of 106 (permalink) Old 04-09-2019, 12:46 PM
lowesguy's Avatar
Vehicle: 91 500SL 37k,90 300SE sold, 91 300E sold , 92 300E137k ,02 Kia Sedona ,I know..... its a Mini van.
Quoted: 601 Post(s)
Hope everybody's doing fine!
My personal experience with the blasted HG job, that was 7 years ago or so, everybody said use Victor-Reinz, I did, lasted about 3-4 years, then after 16K miles it started leaking at #6 passenger side USA, just oil leaking for now , no mixing of coolant, Yet!, some said John you didn't torque the head bolts right, I thought I did but then again had a crappy torque wrench.
What I don't get, if I did a lousy job why would it last 16K miles then start leaking? I just figured it was the bad Victor-Reinz gasket!
next time I'll get it from our dealer here, from what I've learned from this forum I need the updated thicker gasket that that address's the weak point at #6.
John
lowesguy is offline
post #55 of 106 (permalink) Old 04-09-2019, 12:51 PM
lowesguy's Avatar
Quoted: 601 Post(s)
Then again maybe the head warped? does get very hot here.
John
lowesguy is offline
post #56 of 106 (permalink) Old 04-09-2019, 01:12 PM
sbaert's Avatar
OE and OEM are not necessarily the same thing. Just because it came from the same manufacturer that supplies to MB does not mean the part is identical.
The only exception would be in those rare cases where the manufacturer grounds off the MB star to sell directly in their own packaging. Example Pierburg diesel vacuum pumps.
As for the headgasket example stated by John, AFAIK only MB reinforced their gasket to address the issue. I have never seen a properly installed updated MB head gasket (that means machine shop time to check the head) with brand new head bolts go.
As for the others like Victor Reinz, your guess is as good as mine.
lowesguy and CheckEngine like this.
sbaert is offline
post #57 of 106 (permalink) Old 04-09-2019, 07:00 PM
gsxr's Avatar
Vehicle: Buncha W124's
Quoted: 118 Post(s)
These are indeed different. OE means "Genuine Mercedes" from a dealership. Even if you buy an OE part from an aftermarket vendor, it originally came from an MB dealer/warehouse first. OEM (Original Equipment Manufacturer) is the manufacturer who makes the OE part. You'll only get OEM from aftermarket vendors, never the MB dealer. A lot of people think OE and OEM mean the same thing, but that is not accurate.
Correct. Most of the time, if the same mfr sells a part via aftermarket channels, it may be identical with the MB star logo ground off. But they could also be parts which failed to meet more-stringent MB specs and these "seconds" end up in the aftermarket channel at a lower price. Or they could be truly identical. There's no way to know for sure. That said, the OEM item is likely going to be better than anything else except OE.
Non-OEM would be third-party mfr's that are basically copying the original design, maybe as cheap as possible... think APA/URO/FEQ. There are also some aftermarket brands that stick "Germany" into their name or logo in a thinly-veiled attempt to make you think the part is made in Germany, when it isn't. Meyle and ACM are two that I can think of offhand. If there is no COO (Country of Origin) label on the part or package, it's safe to assume the worst.
Be careful out there.
gsxr is offline
post #58 of 106 (permalink) Old 04-09-2019, 07:44 PM
humblejoe's Avatar
Date registered: Feb 2007
Vehicle: 04 odyssey (265k) 1995 E320 wagon (295k)
Quoted: 324 Post(s)
Bottom line, can you redo a head gasket for $50? If not it's money well spent. Go MB..👍
"alte Schulqualitšt"
W124, One of the last great gifts of West Germany
humblejoe is offline
post #59 of 106 (permalink) Old 04-09-2019, 10:45 PM
lowesguy's Avatar
Quoted: 601 Post(s)
Its part of ownership , but man they sure run great afterwards!
John
lowesguy is offline
post #60 of 106 (permalink) Old 04-10-2019, 04:15 AM Thread Starter
dtsdig's Avatar
Quoted: 103 Post(s)
Well, I seemed to have stirred the pot! You guys got to keep in mind, I have no idea what the future plans of this car are are or how long Iím going to keep it. Itís never going to be some unicorn that draws the high bid on bring-a-trailer or anything. I donít need any lessons on OE vs OEM. I am quite familiar. Iím not some 17 year old with his first car.
As luck would have it (or not have it), when I went to total up my orders yesterday, the Elring head gasket kit went out of stock, on backorder, and was automatically removed from my cart. I checked around again and ECS, Pelican and FCP now all said out of stock!
MB it is.
dtsdig is offline
