Update for w124 late style lower control arms - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 05-06-2018, 02:37 PM Thread Starter
Date registered: Dec 2017
Vehicle: 1995 E320 sedan
Hello everyone!
I just wanted to share an awesome news with you. Thanks to 500eboard forum for this information.
The price for OEM mercedes late style control arms with integrated ball joint has dropped significantly. The part numbers are 1243303507 and 1243303407. This price drop has happened very recently and I purchased two from getmercedesparts.com for 185$ each.
This topic has been discussed before many times by forum members. Just for summary in case you didnít know, the later style LCA has non replaceable ball joint and if either bushings or ball joint fails, you have to replace the whole unit. The aftermarket parts for these late LCAs were offered mostly by Febi, TRW and some other brands for around 130$ but with much less quality. The original LCAs were around 400$ each in the past. Here in Canada dealer wanted 730$ each!
But now with this price change, you can get the originals with great price and be happy!
w124_owner is offline
post #2 of 13 (permalink) Old 05-07-2018, 03:41 PM
Robert Kyle's Avatar
Date registered: Feb 2018
Vehicle: 1994 e320 coupe (sold), 1990 300CE ($400 beater)
Quoted: 163 Post(s)
Got a link to OEM control arms?
I can only find $$$ ones:
https://benzparts.autohausofpeoria.c...243303507.html
Robert Kyle is offline
post #3 of 13 (permalink) Old 05-07-2018, 03:42 PM
Quoted: 163 Post(s)
post #4 of 13 (permalink) Old 05-07-2018, 03:43 PM
Quoted: 163 Post(s)
Isn't it cheaper if you need ball joints, to just buy the ball joints and have them installed?
post #5 of 13 (permalink) Old 05-07-2018, 03:56 PM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 483 Post(s)
The series I and series II cars had replaceable ball joints. But from about 92 (maybe sooner?) they are not removable from the LCA. That is why this thread is such a big deal.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
post #6 of 13 (permalink) Old 05-07-2018, 05:02 PM
Date registered: Jul 2007
Vehicle: 95 E300, 91 300TE, 84 190D
Quoted: 16 Post(s)
And a lucky exception to that is the 95 E300 Diesel, for which one can replace just the ball joints.
ds190 is offline
post #7 of 13 (permalink) Old 05-07-2018, 05:09 PM Thread Starter
yeah that's the one. There is really no way around the non-replaceable ball joint issue. The problem comes from the bigger brakes. Lots of threads talk about this. Some people tried to get the earlier style (with replaceable ball joint) and grind down the ball joint area, which is unsafe. Some say you can downgrade your brake to make room, but you loose stopping power. The aftermarket ones (Febi, TRW, MOOG, etc) are not a good option, as some pics in 500eboard shows the opened ball joint and you can see how cheap they are made. All of these were because they were very expensive to buy new. But now with this price change, I totally think everyone should get a pair. It doesn't really get any better than this.
post #8 of 13 (permalink) Old 05-08-2018, 09:53 AM
Quoted: 163 Post(s)
anyone know why Sportline arms are diff?
Also, do the bushings (#6) not come w/the arms?
post #9 of 13 (permalink) Old 05-08-2018, 10:38 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1848 Post(s)
Sportline arms use different durometer bushes
sbaert is offline
post #10 of 13 (permalink) Old 05-08-2018, 09:22 PM
Real1shepherd's Avatar
Date registered: Jul 2009
Vehicle: '92 300TE 4matic 280,000miles, '92 300TE 4Matic 'Ice Blue Metalic' 101,000miles
Quoted: 485 Post(s)
And another exception is the 4Matic. The ball joints take about 15 minutes to replace ea side....muhahaha.
Kevin
tuttebenne likes this.
Real1shepherd is offline
