Castrol GTX regular oil for 1995 E320 - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 04-26-2018, 11:22 AM Thread Starter
Date registered: Dec 2017
Vehicle: 1995 E320 sedan
Hello everyone!
I have a question about engine oil. I know that engine oil has been discussed many times and I don't want to start an oil war again but I haven't seen many posts regarding my question.
I have a 1995 E320 with 187000KMs (117000miles) and I have been using Castrol GTX 10W-40 regular engine oil and change it every 4000KMs (or at least once a year). This oil is readily available everywhere with cheap price and I noticed many members recommend Chevron Delo Diesel oil but it seems that it's hard to find around here.
In Vancouver (Canada), the temperature range is -8C to 30C. I am not sure if this oil is suitable and I appreciate your comments. I haven't had any problems with it so far.
w124_owner is offline
post #2 of 17 (permalink) Old 04-26-2018, 11:54 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1848 Post(s)
Costco has Delo, and provides better ZDDP protection than Castrol GTX.
However, since you live in a cold climate I would recommend you run at least a 5W-40.
I highly recommend Liqui Moly LeichtLauf High Tech and is on MB's own 229.5 Bevo list meaning it has been tested and approved by MB themselves. I use this same oil and live in a very similar climate.
https://bevo.mercedes-benz.com/bevolisten/229.5_en.html
https://www.amazon.com/Liqui-Moly-Le...70_&dpSrc=srch
sbaert is offline
post #3 of 17 (permalink) Old 04-26-2018, 02:55 PM
Verbal's Avatar
Date registered: Mar 2014
Vehicle: 1994 E320, 1997 E420, 1999 E320 4MATIC, 1999 SL500
Quoted: 159 Post(s)
What are your feelings about using Mobil 1 0W-40 in the M104? This is the weight that Mobil recommends for that engine on their website guide. Thanks.
"I think of a man, and I take away reason and accountability."
Verbal is offline
post #4 of 17 (permalink) Old 04-26-2018, 03:49 PM
Date registered: Jul 2010
Vehicle: '85 300D Turbo, '91 420SEL, '92 190E 2.6, '09 C350, '12 E63 Wagon
Quoted: 589 Post(s)
This is the viscosity chart:
http://bevo.mercedes-benz.com/bevolisten/224.1_en.html
per ambient temperature.
No problems with Mobil 1 0W-40 in my diesel.
(If your model has a diesel particulate filter use 229.51 oils).
jzchen is offline
post #5 of 17 (permalink) Old 04-27-2018, 12:15 AM
sbaert's Avatar
Not enough ZDDP protection IMO. Fine for FSS (flexible service schedule) MBs, Mobil1 0W-40 is the one stop shop oil to cover all the newer generation cars.
W124s are NON FSS cars
sbaert is offline
post #6 of 17 (permalink) Old 04-27-2018, 01:46 AM
Quoted: 589 Post(s)
Mobil 1 0W-40 FS has 1100 PPM Zinc, in the form of ZDDP I assume, just an FYI.
(“FS” is the updated formula which came out a few years ago now):
https://mobiloil.com/~/media/amer/us...pecs-guide.pdf
jzchen is offline
post #7 of 17 (permalink) Old 04-27-2018, 12:37 PM Thread Starter
Thanks for the reply. I don't think Costco in Canada has the Chevron Delo. I will check it out. By the way, which Chevron Delo do you recommend? cause there are a bunch of them:
- Delo 400 LE SAE 15W-40
- Delo 400 XSP Synthetic SAE 5W-40
- Delo 400 SDE SAE 15W-40(Isosyn Advance Tech)
- Delo 400 LE Synthetic SAE 5W-40
My head gasket has a small leak and I tend to stay away from Synthetics for now.
post #8 of 17 (permalink) Old 04-27-2018, 01:56 PM
sbaert's Avatar
400 LE if you can still find it. It has been supplanted by SDE.
BTW, you will not find a synthetic 15W-40. And 5W-40 is for synthetics.
However, because of your climate I'd think 5W-40 is the way to go.
sbaert is offline
post #9 of 17 (permalink) Old 04-27-2018, 09:46 PM
Quoted: 589 Post(s)
Mobil 1 0W-40 $22.88 at Walmart.com/Walmart,
$10 Walmart certificate:
https://mobiloil.com/en/promotion/mo...ary-april-2018
$12.88 for 5 qts....
jzchen is offline
post #10 of 17 (permalink) Old 04-28-2018, 12:04 AM
sbaert's Avatar
Sorry, but you are wrong. OW-40 was never a approved fluid for the W124. Didn't even exist yet.
As I said, 0W-40 is for later FSS generation cars.
liebeskind likes this.
sbaert is offline
