E320 M104 exhaust system - Mercedes-Benz Forum
LinkBack Thread Tools
Old 02-05-2018, 05:43 PM Thread Starter
mercron's Avatar
Date registered: Jan 2016
Vehicle: '95 E320, 221k miles, fair cond
Quoted: 136 Post(s)
Is the E320ís exhaust system bolt on? Could I just buy and install the catalytic converter, silencer, and muffler components without going to a muffler shop? What brand would you recommend?
It looks like they just bolt on/off.
http://www.w124performance.com/servi...04/49-7000.pdf
mercron is offline
Old 02-06-2018, 12:19 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1848 Post(s)
Eberspaecher makes good exhaust stuff, and is pretty much a exact replacement.
The only issue you will likely run into is the catalytic converter unless you go original MB route.
sbaert is offline
Old 02-06-2018, 12:44 AM Thread Starter
mercron's Avatar
Quoted: 136 Post(s)
Thanks, what issue would replacement catalytic converters have?
mercron is offline
Old 02-06-2018, 12:47 AM
sbaert's Avatar
Mainly durability and fitment (or lack thereof) even from bigger exhaust companies like Magnaflow.
sbaert is offline
Old 02-06-2018, 12:53 AM Thread Starter
mercron's Avatar
Quoted: 136 Post(s)
I see. Iíll have to take my chances on whatever I can get that offers shipping to Hawaii.
My other worry is that I might have problems removing and installing the parts while lying underneath the car. Iím hoping that itís a simple bolt off and on.
The other option is to buy the better quality parts and have a local muffler shop install them.
mercron is offline
Old 02-06-2018, 01:14 AM
sbaert's Avatar
Soak all the bolts and nuts a few times with PB Blaster at least 24-48 hours ahead of starting removal to help loosen them
mercron likes this.
sbaert is offline
Old 02-06-2018, 04:10 AM
humblejoe's Avatar
Date registered: Feb 2007
Vehicle: 04 odyssey (265k) 1995 E320 wagon (295k)
Quoted: 329 Post(s)
How often do you want to do the job? Eberspaecher, esberbacher, or whatever it is will last 10 years, bosal will last 3-4, walker will last 2 ( Max). So when shopping price take that into account. ie, is bosal 1/5 of eberspaecher? If so then parts cost is same, but.....you'll do the labor 5 times..if it's only 1/3 or 1/2, then esperbacher is actually cheaper. Walker is only if you have to, or your selling the car and need cheapest option.
sbaert and mercron like this.
"alte Schulqualitšt"
W124, One of the last great gifts of West Germany
humblejoe is offline
Old 02-06-2018, 05:08 AM
Nate D. Rector's Avatar
Date registered: Aug 2016
Vehicle: 99 s320 member since 2009 fastest time 14.6 1/4 mile nitrous.
Quoted: 108 Post(s)
if no smog check,get rid of cat,and use one Thrush turbo muffler.Better performance,and mpg.
Nate D. Rector is offline
Old 02-06-2018, 08:37 AM Thread Starter
mercron's Avatar
Quoted: 136 Post(s)
Yeah, we donít have smog check here. Will not having a catalytic converters affect the O2 sensor?
mercron is offline
Old 02-06-2018, 08:38 AM Thread Starter
mercron's Avatar
Quoted: 136 Post(s)
Thanks for this.
humblejoe likes this.
mercron is offline
