95 E320 awful noise coming from engine, sounds like old an tractor. - Mercedes-Benz Forum
post #1 of 46 (permalink) Old 10-31-2017, 06:03 AM Thread Starter
Date registered: Jun 2017
Vehicle: 1995 E320
Quoted: 6 Post(s)
So yesterday my car started making this noise *it sounds like it is coming from the front of the engine but is hard to tell for sure.
the fist part is stationary in neutral I revved the engine a bit, and the second video is driving inside of a parking garage... you can hear driving noise over it but can still hear the mystery noise. It almost sounds like an old diesel tractor. Other than the noise, there doesn't seem to be any new symptoms associated with it while driving (loss of power or hesitation) There is no CE light but I have the California model on board led reader and that gave me codes 4, 5, 23, and 26. (26) wasn't cleared after I had the transmission serviced and the reverse clutches rebuilt so it is a non issue here. I have had the car close to 3 years and spent the first couple months trying to pass emissions in CO I ended up putting the catalytic converter from an E430 on it and that was the end of that trouble.
Any ideas on what this could be? The car has 251,000 miles on it. Any more info I can provide to help with diagnosing this please let me know. Thanks for all of the help that this forum provides.
****Final Edit*** The noise was coming from the fan bearing bracket, the clutch was fine. I ended up not needing to buy the two special tools layer in the post I made the fan stop out of a 5.5 mm steel rod I had and the special 8mm hex I used a cut off allen wrench set inside a stubby socket which worked nicely.
Last edited by 320forME; 11-05-2017 at 05:59 AM. Reason: Problem has been resolved.
320forME is offline
post #2 of 46 (permalink) Old 10-31-2017, 06:24 AM
Nate D. Rector's Avatar
Date registered: Aug 2016
Vehicle: 99 s320 member since 2009 fastest time 14.6 1/4 mile nitrous.
Quoted: 108 Post(s)
had that sound with a m104,oil filter was full of aluminum flakes,so I put a motor in it.
Nate D. Rector is offline
post #3 of 46 (permalink) Old 10-31-2017, 06:35 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1089 Post(s)
Nate
If the flakes you mention are from the motor that had the nitrous shot and was drag raced in your W140, you should say so.
My suggestion is to get the car outside. Trying to determine the source of a "sound" inside an concrete echo chamber has it's challenges. Outside and hood up will give you a good idea of the source of the noise. If you have a mechanics stethoscope or 3' long pipe/hose etc it will help you identify external accessories or internal rotating parts as the source.
Good luck and keep us posted
Jayare
Sent from my XT1080 using Tapatalk
Jayare is offline
post #4 of 46 (permalink) Old 10-31-2017, 06:52 AM Thread Starter
Vehicle: 1995 E320
Quoted: 6 Post(s)
Don't scare me like that, I just checked the filter no aluminium but it is due for a change.
M104_the_Situation likes this.
320forME is offline
post #5 of 46 (permalink) Old 10-31-2017, 06:56 AM Thread Starter
Vehicle: 1995 E320
Quoted: 6 Post(s)
Originally Posted by Jayare View Post
Nate
Jayare
I should have included in the post that it sounds like it is coming from the front of the engine at first I thought the fan was hitting something or the bearing was going bad. but that is not the case.
320forME is offline
post #6 of 46 (permalink) Old 10-31-2017, 07:29 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1848 Post(s)
Sounds like the timing is out of spec. In other words, the chain may have skipped a tooth causing the valves to touch the pistons.
This can be caused by bad chain guides, bad chain tensioner, stretched chain, or if the timing was not set properly after major engine work such as a headgasket replacement.
Do not drive the car until you figure out the cause.
sbaert is offline
post #7 of 46 (permalink) Old 10-31-2017, 07:44 AM
humblejoe's Avatar
Date registered: Feb 2007
Vehicle: 04 odyssey (265k) 1995 E320 wagon (295k)
Quoted: 324 Post(s)
I would try stethoscope/pipe/screwdriver to each accessory and your ear (transmit sound, but don't injure yourself with moving engine) like Jayare suggests. Try to pinpoint the noise.
Or remove the serpentine belt and see if the noise persists. No running accessories...no noise means its an accessory. From there try to spin each one by hand and see if one is crunchy/noisy
If you have a 95, you might luck out and have the later tensioner so it will be easy.
If its the old style make sure you research how to loosen so you don't break the adjuster. And be prepared for the tensioner to die if its really old (rubber no longer provides tension)
It could simply be a bad accessory.
"alte Schulqualitšt"
W124, One of the last great gifts of West Germany
humblejoe is offline
post #8 of 46 (permalink) Old 10-31-2017, 07:53 AM Thread Starter
Vehicle: 1995 E320
Quoted: 6 Post(s)
It Hasn't had any engine work done in the last 4 years, wouldn't bad timing components have other symptoms? My last car a 93 300E had the head gasket blow and the shop I took it to FUBARed it and installed the timing sprocket wrong but it would only make a noise after 1500RPM - 2000RPM I called a dedicated MB guy and told me to disconnected the camshaft positioning sensor?? round thing on top front of engine??? so it wouldn't advance and drove it to him who fixed that for me and billed the other shop for it.
This sound is completely different from that. Not sure if that helps or not.
320forME is offline
post #9 of 46 (permalink) Old 10-31-2017, 09:35 AM
Jayare's Avatar
Truthfully, all of us are at a huge disadvantage here and we understand you are trying your best. At this point, I'm out of suggestions other than taking the car to the trusted shop that helped you before. If you go that route, just let us know what the diagnosis is.
Good luck
Jayare
Jayare is offline
post #10 of 46 (permalink) Old 10-31-2017, 09:46 AM
mercron's Avatar
Date registered: Jan 2016
Vehicle: '95 E320, 221k miles, fair cond
Quoted: 136 Post(s)
Have you checked the secondary air injector? It could be a vacuum hose leak or a faulty air injector as error code 4 shows.
Also 5 indicates a faulty EGR valve which again could be a faulty vacuum hose.
Code 23 is intake manifold pressure too low or too high. This is measured by a sensor between the ABS and the purge valve that ha a vacuum hose connected to the intake manifold. That's another vacuum issue.
Code 26 could be a vacuum issue but it's a separate sensor and switch located above the master cylinder.
Bottom line is check all your vacuum hoses first for any loose hoses. Clear error codes and see if any returns. Also, is your battery still good? These sensors are sensitive to low voltage.
mercron is online now
