What tires do people like? - Page 5 - Mercedes-Benz Forum
post #41 of 58 (permalink) Old 04-13-2017, 12:47 PM
LeftCoastGeek's Avatar
Date registered: Jul 2011
Vehicle: 1993 300CE Cabriolet (mine) ; 1994 E320 Wagon (wife's) ; 1990 Benz 300E 2.6 (son's)
Quoted: 1361 Post(s)
tires with higher speed ratings mainly have better temperature dissipation. often, they have softer rubber, which increases traction at the expense of tire wear.
side wall stiffness tends to be correlated more to the tire width profile (the /70, /60 number), and the tires load factor (the number before the speed letter & after the tire size, like 91H is load factor 91...). load factor is usually fairly consistent for a given size tire.
LeftCoastGeek is offline
post #42 of 58 (permalink) Old 04-15-2017, 05:02 PM
TechGuru's Avatar
Date registered: Oct 2008
Vehicle: 1988 M-BENZ 300E | 1991 FORD PROBE GT TURBO | 2003 FORD EXPLORER 4x4
Quoted: 20 Post(s)
I have Pirelli Centauro P5 right now
They have since stopped manufacturing them in my vehicle's required size so next time I'm probably going to go with GoodYear's ASSURANCE TRIPLETRED AS.
TechGuru is offline
post #43 of 58 (permalink) Old 04-18-2017, 01:45 PM
XJguy's Avatar
Date registered: Jan 2013
Vehicle: 1994 W124 E320 coupe, midnight blue, lowered and enhanced, 17" wheels
Quoted: 57 Post(s)
Michelin . I use a different set for summer and for winter. Best tires, best warranty, best support, best across the board.
LogicalPosition likes this.
XJguy is offline
post #44 of 58 (permalink) Old 04-18-2017, 06:25 PM
Date registered: Jul 2004
Quoted: 485 Post(s)
They are apparently the best, by far, on premature sidewall cracking too - not a good thing.
humblejoe likes this.
deanyel is offline
post #45 of 58 (permalink) Old 04-18-2017, 06:46 PM
cant say I've ever experienced that on Michelins, and most of my cars are parked outside full time. worst tire I ever had for that was some off brand (sold by Big O) LT tire, never again. just about when I noticed the first of the sidewall cracks, a tire developed a big sidewall blister and we replaced them, with at least 50% tread left.
post #46 of 58 (permalink) Old 04-18-2017, 08:53 PM
Date registered: Aug 2016
Vehicle: 1990 300CE M104
Quoted: 4 Post(s)
Why not the P7 cinturato? Much better than that tripletread GY. I'm currently on Conti DWS06's, but once those are done I'll probably switch to the P7's.
JuanTwoFore is online now
post #47 of 58 (permalink) Old 04-18-2017, 09:05 PM
Real1shepherd's Avatar
Date registered: Jul 2009
Vehicle: '92 300TE 4matic 280,000miles, '92 300TE 4Matic 'Ice Blue Metalic' 101,000miles
Quoted: 498 Post(s)
Be wary of whom you buy your tires from....some discount places are selling 3+yr old tires. Since indirect sunlight and ozone start breaking down tires immediately after manufacture...unless they are sealed in a bag and kept in the dark (not likely), they will weather check prematurely if they are 3+ yrs old.
Kevin
Real1shepherd is offline
post #48 of 58 (permalink) Old 04-18-2017, 09:45 PM
looks like p5's are discontinued. but Tire Rack, at least, has hardly anything to fit a stock w124 from Pirelli, a couple ice/snow tires, and a p6000 summer tire.
post #49 of 58 (permalink) Old 04-18-2017, 11:59 PM
Date registered: Nov 2011
Vehicle: 1993 300D 2.5 "Elsie"
Quoted: 96 Post(s)
If I were going stock size, I would probably just get a set of Cooper CS5s. Highly rated and inexpensive. I find that these cars pretty much stick like glue no matter what you put on. Even on snow tires it drives like a dream. Being in Seattle, though, wet traction is high priority, which is why I put the Continental on instead of the Pirelli P7. The P7 is supposedly softer riding, but lots of reports of subpar wet traction. Wasn't worth the risK for me.
chuckh0308 is offline
post #50 of 58 (permalink) Old 04-19-2017, 12:56 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1859 Post(s)
Originally Posted by chuckh0308 View Post
...I find that these cars pretty much stick like glue no matter what you put on.....
Errr . . . . no. Tire quality and rubber durometer are the biggest single factor to grip and ride comfort.
sbaert is offline
