Found a Low Mileage 3.0 m103 to swap - Service before swap? - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 07-07-2017, 04:04 PM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 483 Post(s)
Originally Posted by RolandTiangco View Post
Good call thanks Gator. I'll search for your threads thanks for the tip.
Sent from my Pixel using Tapatalk
Nice photo of Senna!
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
post #12 of 15 (permalink) Old 07-08-2017, 03:45 PM
Date registered: Dec 2012
Vehicle: 89 190E2.6- 5-speed Manual, 95 E320 Sportsline-sold, 2001 E320 4matic Wagon-sold
Quoted: 536 Post(s)
Send a message via Skype™ to dolucasi
You already mentioned it but I would highly encourage you to pop open the valve cover and inspect the moving parts (cams, rockers, etc).
Just the look of what's under the valve cover will tell you a lot about that engine. See if there are any wear or scoring in the cam lobes. It is a young engine but you never know. All lobes should be shiny and new. I just had to replace my '89 cam/rockers/etc at 180K. They looked sad and in desperate need of replacement. My car was very well taken care off as I was the original owner.
Also see if there is any rust at the hose connections. Rust is another bad sign.....
dolucasi is online now
post #13 of 15 (permalink) Old 07-17-2017, 07:13 AM Thread Starter
RolandTiangco's Avatar
Date registered: Apr 2016
Vehicle: 1991 190e 2.6L
Quoted: 8 Post(s)
Thanks for the additional input guys. Went and inspected the camshaft today and all lobes look good. The journal bearings have some very light markings that might be evidence of low oil running, but I don't think this is a major red flag. Photos below.
Rear main seal is on the way. Also decided to replace the valve stem seals for good measure.
I'll continue documenting here as I prep the engine for the swap.
RolandTiangco is offline
post #14 of 15 (permalink) Old 11-04-2017, 06:52 PM Thread Starter
Quoted: 8 Post(s)
Figured I’d update this thread. Did a leak down test on this engine and found a lot of leakage from the exhaust valves on a couple cylinders. Removing the exhaust manifolds revealed some pretty ugly valves; looked like the engine ran for a long time with leaking valve stem seals. I figured a burnt valve or two so planned a valve job. Dropped the head off at a machine shop and learned that the head was warped .016, which is too far warped to resurface. In my search for another head I found an entire running engine for not too much more than the cost of a used head. I’m now debating between pulling the head off the ‘new’ engine to send to the machine shop or just bolting up the getrag to it and dropping it into something.
post #15 of 15 (permalink) Old 11-04-2017, 07:13 PM
ryanjamesgiese's Avatar
Date registered: Nov 2016
Vehicle: 1993 Mercedes Benz 190e 2.6 5-speed
Quoted: 5 Post(s)
just drop it in already
ryanjamesgiese is offline
