1995 E320 ball joint LCA options - Page 2 - Mercedes-Benz Forum
post #11 of 39 (permalink) Old 02-24-2017, 05:29 AM
Stutz's Avatar
Date registered: Oct 2009
Vehicle: 1999 500SL, 1988 SEC
Quoted: 257 Post(s)
Well I had to do the same on a R129 and chose the febi route. The new lca's said they were made in Spain and they seemed like build quality was ok. I went with the whole lca since by just replacing the ball joint you miss replacing the rubber bushings on the arms themselves. To me that was important also. I have not put many miles on it yet so only time will tell. The MB ones were simply too much money since I also replaced springs, struts and spring insulators at the same time.
humblejoe likes this.
Stutz is offline
post #12 of 39 (permalink) Old 03-20-2017, 12:24 AM Thread Starter
mercron's Avatar
Date registered: Jan 2016
Vehicle: '95 E320, 221k miles, fair cond
Quoted: 136 Post(s)
Well I finally came around to working on my E320's front suspension - the driver's side at least. I'll work on the passenger side next week.
I replaced the tie rod with Hamburg Technic rods from eBay as they came as a pair. I'll see how long this will last compared to Lemfoerders. No more clunking over potholes.
I also replaced the strut mounts with Meyle mounts from eBay and that was a little hard to do with the strut lowered and supported by a jack. I could already notice the difference with a tauter ride.
I then just repacked and rebooted the ball joint after opening it up and finding no play and rust. I had bought a new ball joint boot set and cleaned up the old grease then put on new grease. I had also tested the ball joint for play using the method in the DIY and there was no play. Control arm bushings were still intact.
Anyways, the hard part was using the jack as a support to the LCA while rebooting the ball joint. It was nerve wracking knowing the coil springs is just inches away trying to kill or maim you. The inner spring compressor I rented from Autozone didn't fit. I had to lower and raise the LCA with the jack to get the ball joint pin out once and back in several times very, very slowly and carefully.
Anyways, all three job done on driver's side in two hours. I'll tackle the other side next week.
jftu105 likes this.
mercron is offline
post #13 of 39 (permalink) Old 03-27-2017, 05:57 PM Thread Starter
mercron's Avatar
Quoted: 136 Post(s)
Bad news. My passenger side ball joint has some play in it, maybe 1 to 2 mm downwards, but with some resistance. After cleaning it of the old grease, there was no sign of rust. I just repacked it with grease and rebooted it until I get new balljoint / lower control arm combos for both sides.
My question is, how long can I still drive this car with a repacked balljoint with some play but no rust? Can I still drive it while waiting for parts or should it not be driven at all?
mercron is offline
post #14 of 39 (permalink) Old 03-27-2017, 06:17 PM
Date registered: Oct 2013
Vehicle: Mercedes-Benz 190E 2.6, 300E, Volkswagen Jetta 1.4T
Quoted: 251 Post(s)
Originally Posted by mercron View Post
Bad news. My passenger side ball joint has some play in it, maybe 1 to 2 mm down. After cleaning it of the old grease, there was no sign of rust. I just repacked it with grease and rebooted it until I get a balljoint lower control arm combo for both sides.
I'm normally on the W201 and W126 forums, but my W201 has the same front suspension. The critical part to replace is the ball joint as it is the only thing connecting your LCA to your hub. I replaced just the ball joints on my car, as I could not justify the expense of a spring compressor and brand new arms (and can't really afford it as a college student either).
Ball joints are a must replace item on these cars, a friend of mine and his dad almost plowed their 300E into a ditch because the ball joint separated, the spring left the perch, and the whole hub/strut assembly decided to leave the rest of the car (the car was junked for $50 after that). The joints themselves are $17 for Lemforder, and I used a harbor freight ball joint press to press them out, but they are a pain in the ass to press out without the MB press (I think you can rent one from some guy on peachparts for like $35 + shipping).
If you don't have the cash for even the cheapest LCA, then please at least do the ball joints. The LCA bushings won't leave you stranded or cause an accident and should be the last of your worries if strapped for cash.
By the way, the failure mode for these ball joints is that the ball shoots out of the worn socket.
mercron likes this.
A.Cabral is offline
post #15 of 39 (permalink) Old 03-27-2017, 06:25 PM Thread Starter
mercron's Avatar
Quoted: 136 Post(s)
Thanks. My 1995 W124 balljoints are built in to the LCA. I wish I could just replace the balljoints like the older version.
I already ordered the BJ/LCA's for both sides. It'll take 2 - 3 weeks to arrive. I was just wondering if I can still drive this car during that time until I replace them.
Then I'd have to find some way to rent an MB spring compressor as the ones at the parts store do not fit.
mercron is offline
post #16 of 39 (permalink) Old 03-27-2017, 06:30 PM
Quoted: 251 Post(s)
You should be able to, but I'd try to drive it as little as possible until you complete the repair.
mercron likes this.
A.Cabral is offline
post #17 of 39 (permalink) Old 03-28-2017, 02:56 AM
gatorblue92's Avatar
Vehicle: 1977 W123.123 1993 W124.034
Quoted: 407 Post(s)
These are getting ridiculously cheap.
5pcs Coil Spring Compressor Telescopic Repair Tool Kit Clamps For Mercedes Benz | eBay
mercron likes this.
gatorblue92 is offline
post #18 of 39 (permalink) Old 03-28-2017, 01:52 PM
Date registered: Mar 2007
Vehicle: 1995 E320 Cabriolet
Quoted: 18 Post(s)
I would not drive that. If that ball joint lets go, you rapidly transition from driver to passenger, endangering not only you but other people around you as well. Huge risk!
mercron likes this.
Maxbumpo is offline
post #19 of 39 (permalink) Old 03-28-2017, 03:30 PM
humblejoe's Avatar
Date registered: Feb 2007
Vehicle: 04 odyssey (265k) 1995 E320 wagon (295k)
Quoted: 334 Post(s)
I tried a cheap compressor but the plates were too thick to fit the coil gaps. I sold a mid tier one that worked for me to another be member and he reported it didn't fit his coils.
So it looks like they're not all created equal. And spring sag happens.
Another member had the same experience as me too.
Make sure you can return if necessary.
mercron likes this.
humblejoe is offline
post #20 of 39 (permalink) Old 03-28-2017, 05:04 PM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1103 Post(s)
This is the one I bought off eBay about 7 or so yrs ago. This far, it has worked like a champ on every MB (201, 124, 140) I've had during that period and more that one junk yard car and loan out.
Everyone is speaking the truth in this thread. Mine is just another experience.
mercron likes this.
Jayare is offline
