Fan Clutch Toast!! Ordered Remanufactured MB - Page 6 - Mercedes-Benz Forum
post #51 of 104 (permalink) Old 06-08-2016, 06:51 AM
Real1shepherd's Avatar
Date registered: Jul 2009
Vehicle: '92 300TE 4matic 280,000miles, '92 300TE 4Matic 'Ice Blue Metalic' 101,000miles
Quoted: 498 Post(s)
Like I originally said;the weight of the fluid pressing on the seal in the horizontal position.
Kevin
Real1shepherd is offline
post #52 of 104 (permalink) Old 06-08-2016, 07:08 AM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 696 Post(s)
Originally Posted by Richard F View Post
It seems a very complex solution to avoid replacing a fan clutch.
When MB or anybody else builts a fan clutch for the inline 6 that can maintain the coolant temp under 90c while sitting in traffic on a 100f+ day, I'll buy it. Until then I'll stick with electric cooling.
tjts1 is offline
post #53 of 104 (permalink) Old 06-08-2016, 08:37 AM
Date registered: Aug 2006
Vehicle: 97SL500R129, 01ML320W163, 94E320W124 & 93500EW124
Quoted: 226 Post(s)
Originally Posted by humblejoe View Post
The fluid is not pressing on the front seal in a vertical or face up position. Its when the clutch is left on its face that the very thin fluid can slowly weep from the front seal.
They are to be stored vertical or horizontal, but facing up (front to the sky).
I don't see any "front seal" on the clutch; do you mean the seal on the pin under the bimetallic temp sensor?
edcarls is offline
post #54 of 104 (permalink) Old 06-08-2016, 08:44 AM
Quoted: 226 Post(s)
They may have already built the specific fan clutch you are looking for. Check "Electromagnetic Fan Clutch."
edcarls is offline
post #55 of 104 (permalink) Old 06-08-2016, 09:02 AM
Quoted: 498 Post(s)
As I mentioned many moons ago, the bad cooling system rap the 124 cars are getting here in this forum is absolutely bogus. Whether it's the 'best' possible system the Germans could have designed is absolutely irrelevant. Cooling system problems were a non-issue in any climate in NA when the cars were new. They were way long in the tooth when all this balderdash started about 'design flaws'. Just like condemning 'German electronics' after 20+yrs of service.
Now you have owners putting in inferior radiators, cheaper clutch fans and water pumps, along with residual corrosion inside the engine blocks, bad auxiliary fans, aftermarket stats etc. You get all this sorted out, use OE components and you won't have cooling 'problems'.
I had an electromagnetic clutch fan in a Peugeot wagon. It was a good system, but what you may not know is that every time that electromagnet pops that fan hub together with its base, some metal is shaved off the two surfaces(one surface spinning, the other stationary). Once or twice a season I'd have to go in there with feeler gauges and adjust that gap...too big a gap and it won't engage reliably. I can't see how that system design could get around that and I don't think it was reasonable to adjust the gap that often by the owner.
Kevin
post #56 of 104 (permalink) Old 06-08-2016, 09:26 AM
humblejoe's Avatar
Date registered: Feb 2007
Vehicle: 04 odyssey (265k) 1995 E320 wagon (295k)
Quoted: 334 Post(s)
Correct. No "rear seal" because its a cavity in the clutch.
It may have a gasketed seal in the rear like this one though, but I think its more reliable than the front one under bi-metallic strip.
https://youtu.be/N_GkuTgJr3w
Here's a vid of a guy refilling a Toyota one https://youtu.be/3ACx7GTCn7Y
humblejoe is online now
post #57 of 104 (permalink) Old 06-08-2016, 10:15 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1103 Post(s)
Looks like it's time to let this one end boys. I pretty much figure Robert has it handled. If not, he'll chime in.
Jayare
Jayare is offline
post #58 of 104 (permalink) Old 06-08-2016, 11:48 AM
Date registered: May 2008
Vehicle: 1992 300TE (RIP), 1994 SL500, 1998 E320, 2003 E320 Wagon, 2006 R500
Has anyone else tried this fan clutch modification on an inline six? Works great for me.
K6JRF Auto Page
jplatford is offline
post #59 of 104 (permalink) Old 06-08-2016, 12:22 PM
tjts1's Avatar
Quoted: 696 Post(s)
K6JRF Auto Page
It worked really well on my 190e 2.6 with dual aux fans.
tjts1 is offline
post #60 of 104 (permalink) Old 06-09-2016, 08:36 AM
1mbzdoc's Avatar
Date registered: May 2014
Vehicle: 2010 glk350 91 560sec 74 230 66 220seb 86 300e 88 300e
Quoted: 203 Post(s)
Originally Posted by LeftCoastGeek View Post
who made the *original* MBZ fan-clutches ?
Do we have any anecdotal or otherwise evidence that the current MBZ branded clutches are short-lived? Its *very* possible that the ones MBZ sells and the ones Behr sells themselves are different quality. Of course, its equally possible they aren't, hence my query for evidence either way.
so here is what showed up today from the dealer brand new in factory box with emblem and part number on part made by behr
ID:	1903914   Click image for larger version
ID:	1903922   Click image for larger version
humblejoe and tjts1 like this.
1mbzdoc is offline
