Fan Clutch Toast!! Ordered Remanufactured MB - Page 5 - Mercedes-Benz Forum
post #41 of 104 (permalink) Old 06-07-2016, 12:06 PM
Real1shepherd's Avatar
Date registered: Jul 2009
Vehicle: '92 300TE 4matic 280,000miles, '92 300TE 4Matic 'Ice Blue Metalic' 101,000miles
Quoted: 486 Post(s)
Originally Posted by dave300D93 View Post
I never could understand how laying a fan clutch assembly on it's side instead of straight up would cause it to fail. Can anyone explain this?
It's the weight of the fluid on the seals in that position....it's designed to orient vertically at all times. It probably takes a long time in storage, laying down, for the adverse effect, but it does happen on occasion.
Kevin
Jayare likes this.
Real1shepherd is offline
post #42 of 104 (permalink) Old 06-07-2016, 12:52 PM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 691 Post(s)
Originally Posted by Richard F View Post
Out of interest what is the solution?
On the om603, 2 electric fans one pusher one puller driggered by a temperature switch at 82c. On the om606, I'm setting up dual puller fans from a Prius (the only fabs thin enough to fit in the space) triggered by a temp switch at 82c. On the m102 powered 190e one very powerful puller fan from a Volvo triggered by megasquit at 87c.
Triggering religious fanatics since 1969
tjts1 is offline
post #43 of 104 (permalink) Old 06-07-2016, 01:06 PM
geordie's Avatar
Vehicle: 2002 SLK32AMG,1995 E320 Cab 1990 300CE(Gone).2002 ML320 (Gone)
Quoted: 16 Post(s)
I got scared once while stuck in traffic while driving the E320 cab, the temp gauge started flirting with the red zone. Fortunately the top was down and the AC was off.
I bought a device called a "cool harness" which is basically a resistor that goes in parallel with the coolant sender to bring the aux fans in at 95 Celsius.
It seems to work very well - no more scares.
tjts1 likes this.
Geordie
VA USA
2002 SLK32///AMG
1995 E320 Cabriolet
geordie is offline
post #44 of 104 (permalink) Old 06-07-2016, 02:18 PM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1848 Post(s)
As Nobletruths stated earlier, IF you have a properly functioning cooling system there is never any worry about running hot or the need to mod the system.
Read my post from a few years back. I went through the Behr clutch fans (both Chinese and German versions), only to settle for the OE MB clutch made by Horton.
Since then, it never touches the 100C mark even on the hottest of days.
tuttebenne and Real1shepherd like this.
sbaert is offline
post #45 of 104 (permalink) Old 06-07-2016, 03:46 PM
tjts1's Avatar
Quoted: 691 Post(s)
That is a really good solution on the later w124s with dual aux fans. Those 2 pusher fans while not ideal are powerful enough to cool the engine on their own IF triggered early with the cool harness. On early w124s with the single aux fan you're shit out of luck. On the w210 MB did a cheap cheat and only used one fan motor while driving the second with a small belt off the first. It's a crap setup.
Jayare likes this.
tjts1 is offline
post #46 of 104 (permalink) Old 06-07-2016, 07:40 PM
dave300D93's Avatar
Date registered: Dec 2012
Vehicle: 93 300D
Quoted: 12 Post(s)
Kevin
Thanks for the explanation....but it still doesn't make sense how the miniscule weight of a fluid can affect a seal that is subjected to much greater extremes like heat, pressure, expansion, contraction....
But we as W124 owners have much bigger fish to fry than a pissy little fan clutch.....
dave300D93 is offline
post #47 of 104 (permalink) Old 06-08-2016, 12:41 AM
Richard F's Avatar
Date registered: Feb 2014
Vehicle: 1994 SL320
Quoted: 449 Post(s)
It seems a very complex solution to avoid replacing a fan clutch.
Richard F is offline
post #48 of 104 (permalink) Old 06-08-2016, 05:00 AM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 483 Post(s)
... I doubt they would cover and collateral damage from a bad fan clutch....
Yes I doubt it too but a failed fan clutch doesn't result in collateral damage. We have all been talking about situations where engine temp creeps up in hot weather not cars that have exploded fan clutch bearings.
Jayare and Real1shepherd like this.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
post #49 of 104 (permalink) Old 06-08-2016, 05:56 AM
Quoted: 486 Post(s)
It's a long term, storage shelf phenomenon. And some of these fans sit a long time until sold and not necessarily in climate controlled warehouses.
Kevin
post #50 of 104 (permalink) Old 06-08-2016, 06:34 AM
humblejoe's Avatar
Date registered: Feb 2007
Vehicle: 04 odyssey (265k) 1995 E320 wagon (295k)
Quoted: 328 Post(s)
The fluid is not pressing on the front seal in a vertical or face up position. Its when the clutch is left on its face that the very thin fluid can slowly weep from the front seal.
They are to be stored vertical or horizontal, but facing up (front to the sky).
Jayare likes this.
"alte Schulqualität"
W124, One of the last great gifts of West Germany
humblejoe is online now
