Fan Clutch Toast!! Ordered Remanufactured MB - Page 10 - Mercedes-Benz Forum
post #91 of 104 (permalink) Old 07-30-2016, 04:56 PM
dave300D93's Avatar
Date registered: Dec 2012
Vehicle: 93 300D
Quoted: 12 Post(s)
Originally Posted by ma61 View Post
Thanks for the input!
Can anyone point me to a link on how to check the operation of the fan clutch?
And is there a recommendation on acceptable brands of radiator?
A quick search brought this:
https://www.benzworld.org/forums/r129...an-clutch.html
I won't get in to the "best brand" debate..........
dave300D93 is offline
post #92 of 104 (permalink) Old 07-30-2016, 05:08 PM
LeftCoastGeek's Avatar
Date registered: Jul 2011
Vehicle: 1993 300CE Cabriolet (mine) ; 1994 E320 Wagon (wife's) ; 1990 Benz 300E 2.6 (son's)
Quoted: 1317 Post(s)
mercedes radiators are/were made by Behr. Nissens are decent too. thats pretty much it for direct fit quality radiators for these cars.
LeftCoastGeek is offline
post #93 of 104 (permalink) Old 07-30-2016, 05:15 PM
Date registered: Nov 2011
Vehicle: 1993 300D 2.5 "Elsie"
Quoted: 91 Post(s)
I did a lot of research on the radiators and it seems like a bit of a toss-up. Some say the Nissens has heavier and better plastic, so the lack of metal reinforcement in the necks isn't a big deal. Others say it is. I went ahead and bought the Nissens, but have not installed it yet. I will make the following comments based on what I know of the radiator that came out and what I can see of the Nissens.
While the metal inserts in the Behr will probably help avoid a catastrophic neck failure, they do not prevent the necks from cracking around the inserts from old age. I know this, because mine has cracks. In other words, after 15 years or so you might start getting leaking from the cracks, but the neck probably won't just snap off.
The Nissens is lighter weight and clearly has less structure. It is concerning me a bit. Then again, maybe the aluminum frame isn't that important? I can't tell by looking at it whether or not the plastic is better or thicker. It was less expensive than the Behr and feels it, to some extent. Now that I know how easy it is to replace, I am just going to factor it in as a later maintenance item. Maybe just replace it again in 5 years or something, if I even still have this car by then.
chuckh0308 is offline
post #94 of 104 (permalink) Old 08-04-2016, 04:05 PM
Quoted: 91 Post(s)
In the interest of keeping this thread going...
I decided to live dangerously again and ordered the Fichtel-Sachs clutch/fan blade combo. Much to my surprise, the clutch is actually made by Horton in Germany, which is the brand everyone says we want. So, hopefully this one will last more than 15K miles.
An additional note on the Nissens radiator. It fits almost perfectly, but there is a plastic tab on the upper passenger side that interferes and must be removed in order to get the radiator mounted flush. I carefully ground about half of it off with my dremel. Also, the top of the radiator sits slightly lower, so you can't push the shroud all the way down. Not a big deal...still clips in place the same.
post #95 of 104 (permalink) Old 08-05-2016, 06:54 AM
Real1shepherd's Avatar
Date registered: Jul 2009
Vehicle: '92 300TE 4matic 280,000miles, '92 300TE 4Matic 'Ice Blue Metalic' 101,000miles
Quoted: 486 Post(s)
Source & price for the Horton made clutch fan, please.
Kevin
Real1shepherd is offline
post #96 of 104 (permalink) Old 08-05-2016, 12:59 PM
Quoted: 91 Post(s)
Kevin
AUTOHAUSAZ for $240. I suppose it is possible that F-S might use different manufacturers for the clutch units, but the one I got has Horton stamped on the back.
http://www.autohausaz.com/pn/2100024043
Name:	2016-08-05 12.46.41.jpg
ID:	1945642   Click image for larger version
Name:	2016-08-05 12.48.16.jpg
Real1shepherd likes this.
post #97 of 104 (permalink) Old 08-05-2016, 01:01 PM
Quoted: 486 Post(s)
Thanks! Yeah, that's the thing;today made in Germany, next order comes made in Spain or Slovakia....lol
Kevin
chuckh0308 likes this.
post #98 of 104 (permalink) Old 08-05-2016, 01:12 PM
Quoted: 91 Post(s)
Exactly. I just figured with so many reports of the MB clutches being made by Behr, I didn't want to spend the $400 or whatever they want only to get another 15,000 mile clutch. Wish it were easier to know exactly what you will get.
post #99 of 104 (permalink) Old 08-05-2016, 01:28 PM
Quoted: 486 Post(s)
I hate to say it, but I think this is only going to get worse before it gets better, if it ever gets better. For yrs many of us used parts.com and were always pleased with the OE products...once you figured out their shipping chargers.
Now...case in point are the Bosch dist caps;go to the dealer and pay between $300-$400 or order a Bosch cap made in Spain for $50. The $50 caps carbon track that much I've found out, but where is the $300-$400 cap made?
Same with the Bosch fuel pumps...country of origin.
Kevin
post #100 of 104 (permalink) Old 08-05-2016, 03:42 PM
Date registered: Mar 2010
Vehicle: 2007 E220CDI, 1990 300E-24V, 1987 W124 3.6 AMG build 1993 E500 W124, 94 320CE, 1997 W140 S280
Quoted: 208 Post(s)
New MB Dealer caps for m119's (I have seen m119 items purchased in the last month from MB) are Bosch made in Spain.
So I myself bought new Bosch made in Spain- which offer significant savings over the ultimate re-boxer.
JC220 is offline
