seriously i need help for accelration - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 05-05-2016, 02:15 AM Thread Starter
Date registered: May 2016
Thumbs down seriously i need help for accelration
i have 230E 1988 auto 4 speed m102 i have a problem with acceleration my problem is very high rpm high fuel companion rough shifting i want to change the differential i have 2.27 is it suitable?? with tires R15/55/205 ?
Hassan Koura is offline
post #2 of 13 (permalink) Old 05-05-2016, 02:19 AM Thread Starter
some people say the catlytic converter is making this problem is it true ???
post #3 of 13 (permalink) Old 05-05-2016, 04:51 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1089 Post(s)
Hassan
You state that you need acceleration help, but you're not clear if the car isn't running correctly or you just want a faster car.
tuttebenne likes this.
Jayare is online now
post #4 of 13 (permalink) Old 05-05-2016, 05:49 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1848 Post(s)
^Exactly. The W124 is already a relatively heavy car, and not quick on its feet even with its 6 cylinder brother the M103. Yours is saddled with a small 4 cylinder that is taxed even further with a automatic transmission.
The 4 and 6 cylinder engines turn higher rpms to keep the engine in the power band. That is just the way they are designed. Putting in a differential with a lower ratio will only make acceleration worse.
Not quite sure what a fuel companion is, though.
If you want better acceleration then you should find a later W124 with a twin cam M104 6 cylinder or go the V8 route.
sbaert is offline
post #5 of 13 (permalink) Old 05-05-2016, 07:05 AM
Vehicle: 1993 300ce Cabriolet
It's entirely possible, though I would check myriad other things before suspecting the catalytic converter is bad. Make sure all maintenance is up to snuff first, catalyst replacement is not inexpensive.
knoxgeeks is offline
post #6 of 13 (permalink) Old 05-05-2016, 07:09 AM
sbaert's Avatar
The vast majority of 230E cars did not have any catalyst equipment, so it is unlikely that is the issue.
If the dash has a Check Engine light indicating the presence of a oxygen sensor, then it is equipped with a catalyst.
sbaert is offline
post #7 of 13 (permalink) Old 05-05-2016, 07:18 AM
1mbzdoc's Avatar
Date registered: May 2014
Vehicle: 2010 glk350 91 560sec 74 230 66 220seb 86 300e 88 300e
Quoted: 203 Post(s)
Sounds like your engine might be getting to much fuel. Check fuel mix and oxygen sensor.If you still suspect exhaust being restricted put a vacuum gauge on engine if you have less that 15 inches of vac after engine runs for five minutes then it may be possible. Cats dont go bad by them self it takes to much fuel or to much oil to kill them. I have a 300e with over 380000 miles on it and still has the original cat. It still passes california smog without any trouble
current stable
2010 glk350-86 300e-88 300e white-66 220seb-74 230- 2012 chevy cruze eco wifes commutor 40plus mpg on regular. 1970 gmc 2500- 2002 gmc 2500hd duramax/allison-50s something willeys pickup-74 harley fxe-92 harley flhtcu ultra classic-2017 harley road glide special- 2018 road glide special-98 special construction harley powered.-
1mbzdoc is offline
post #8 of 13 (permalink) Old 05-06-2016, 12:53 PM Thread Starter
the problem
the car get from 0 to 100 km/h in 35 sec and rough shifting and high rpm at ex at 100km/h the rpm 4
sure it`s not normal
i changed the short block and the gear box
but not anything changed
i need help some people say that`s vacuum leak other say it`s catalytic converter some say it`s the differential some say it`s o2 sensor and i check the presence of it not found it and mechanical shop say it`s not found in this car :/ if any one sure where the problem exactly please tell me
post #9 of 13 (permalink) Old 05-06-2016, 12:57 PM
sbaert's Avatar
Are you sure it is not just a simple case of one of the car's 3 fuel filters and/or the air filter being clogged???
4K rpm @100 km/h in a 4 cylinder W124 with automatic sounds about right, and perfectly normal. Remember, it is only a 4 speed gearbox.
If you accelerate with your foot fully depressed and without letting go, does it start in 1st gear and shift at or close to redline until it is in 4th gear???
sbaert is offline
post #10 of 13 (permalink) Old 05-09-2016, 01:22 AM
neanderthal's Avatar
Date registered: Dec 2003
Vehicle: 1995 E320
Quoted: 90 Post(s)
Unlikely that you have a 2.27 diff in a four cylinder car unless that was changed. But that could explain glacial acceleration.
'O=00=O' BMW 2002. long live the legend.
neanderthal is offline
