My 300ce cranks and is close to starting, but it wont. Suggestions? - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 12-10-2015, 06:13 PM Thread Starter
Date registered: Apr 2015
Quoted: 22 Post(s)
When I first got the car, I would turn the key and it would start up without hesitation and then immediately cut off. It would always start up the second time. Well last week when I tried starting up the car, but after a few tries, it started up, but began idling rough and the ABS light was on. A few tries later and the ABS light went away and it began idling normally. I tried to start it today and it cranks and cranks like it's about to start up, but it doesn't. If I try turning the key and pushing down on the gas pedal, it will abruptly stop trying to start and shut off. The very next try, it starts, but it idles rough with the ABS light on.
I'm guessing it is the fuel pump relay and the ovp relay? I bought a fuel pump relay on ebay, but I can't find a ovp relay. All of the ovp's say they are only compatible with 93's and up.
http://www.ebay.com/sch/i.html?_odkw...relay&_sacat=0
I have a 1989 300ce
bigbob777 is offline
post #2 of 14 (permalink) Old 12-10-2015, 06:21 PM
R.P. McMurphy's Avatar
Date registered: Dec 2010
Vehicle: 1984 300dt 1985 300 dt 1992 300e just added another 92 300e 1994 e420 1993 300te 4matic
Quoted: 272 Post(s)
...are the spark plugs cap and rotor in good condition and not a lot of miles on them? have you looked behind the battery compartment to look for the ovp? theres a plastic splash shield behind the battery that you need to remove.
Alcoholic RAT drunk on stolen cheese
R.P. McMurphy is offline
post #3 of 14 (permalink) Old 12-10-2015, 06:57 PM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 483 Post(s)
Check the fuse in the OVP. ABS light and starting problem sound awfully familiar to me.
After that you may want to validate your fuel pressure is doing what it should (not bleeding off when the car is sitting).
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
post #4 of 14 (permalink) Old 12-10-2015, 07:22 PM
miltiano32's Avatar
Vehicle: 1988 300CE
Quoted: 83 Post(s)
w124 ovp relay | eBay
I have a 1989 300ce
This has been happening to me as of today same symptoms and everything. I confirmed on my car that my OVP has the single fuse still. Replacing your OVP i believe will cure your problems, I have one on order coming in. Is this what you are looking for?
Kaehler (KAE) 2015403745 Overload Protection Relay
miltiano32 is offline
post #5 of 14 (permalink) Old 12-10-2015, 07:45 PM Thread Starter
Quoted: 22 Post(s)
Thanks. I found the exact model on ebay for $20.
I think you overpaid
http://www.ebay.com/itm/Mercedes-Ben...ht_2943wt_1186
post #6 of 14 (permalink) Old 12-10-2015, 08:25 PM
miltiano32's Avatar
Vehicle: 1988 300CE
Quoted: 83 Post(s)
Mercedes Benz 560SL 300SE 500SL 2 Fuse Overload Protection Relay 9 Terminal | eBay
I didn't buy that one off of autohausaz, I only posted it in reference to you not being able to find an OVP relay. I ordered my relay off of FCPeuro only because they have free shipping after 49$ compared to autohaus which is free shipping after 79$. Naturally I do plenty of research to get the best deal and also best longevity from my purchases. I paid 62.99$ for this Genuine Mercedes relay and my perception is that I didn't overpay. I learned a lot from reading @sbaert posts about this subject.
https://www.fcpeuro.com/products/mer...ay-2015403745s
I believe that you ordered a URO relay from that Ebay link you posted, I don't think that style will last very long. URO doesn't have a good reputation for anything regarding our cars, not even rubber hoses....I think you overpaid yourself though on Autohaus it has URO OVp for 18.64$ I hope i could have helped you out for future buys.
Uro Parts 2015403745U Overload Protection Relay
post #7 of 14 (permalink) Old 12-10-2015, 08:43 PM
Quoted: 272 Post(s)
...no he didnt over pay, you bought a cheap knock off part that should be avoided in this instance. if you can cancel the ebay purchase do it and buy a KAE ovp.
post #8 of 14 (permalink) Old 12-10-2015, 09:17 PM Thread Starter
Quoted: 22 Post(s)
Ah I see. Thanks for the info. You are absolutely correct. I had no idea. Went ahead and ordered KAE from fcpeuro.
post #9 of 14 (permalink) Old 12-11-2015, 02:19 PM Thread Starter
Quoted: 22 Post(s)
Tried to start it up again, and it seems like it's very close to starting, but while it's trying to start, there is a grind noise and then it stops.
post #10 of 14 (permalink) Old 12-11-2015, 02:31 PM
Quoted: 272 Post(s)
...youre wearing out the starter. if your plugs cap and rotor arent fresh without a lot of miles/wear on them you will have starting problems. i already asked you once, are those components in good condition? if you keep grinding on that starter youe gonna chip the flywheel.
