A/C stopped during drive. Restarted car and worked - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 07-30-2015, 06:02 AM
dtsdig's Avatar
Date registered: Feb 2011
Vehicle: 1994 Mercedes E320 Sedan 97K, 1995 Mercedes E320 Wagon 156K, 2009 VW EOS 45K (Wife's car)
Quoted: 103 Post(s)
Send a message via Skype™ to dtsdig
@ps2cho Did you make any progress on this one?
dtsdig is offline
post #12 of 12 (permalink) Old 07-30-2015, 05:35 PM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 483 Post(s)
Originally Posted by cbc atl View Post
Mine was doing that earlier this year. Finally decided to tighten the belt.
Went to loosen the front bolt and it was not even finger tight, could turn the washer by hand.
Good thing the bolt on the tensioner was at least a little bit tight.
Anyway, adjusted the tension, tighetned the front bolt and A/C has not cut off again.
Loose tensioner will cause this for sure. Belt slippage is the culprit that causes the KLIMA to drop the compressor signal when the speed sensor "thinks" the compressor has locked up or is close to it. I think he had been chasing a high running temperature problem earlier this summer. Seems like two clues to a slipping belt.
Jayare likes this.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
