replacing OVP - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 04-22-2015, 03:15 PM Thread Starter
Date registered: May 2013
Vehicle: W124 300CE-24 1991, japan spec
Quoted: 43 Post(s)
replacing OVP
hello everyone, my car has a rought idle, cold start problems & a occational stalling so after a small inspection of my mechanic, he found that the OVP has some loose solder inside but the two fuses are in good shape.
just i buy any "red" OVP with two fuses & replace or should i buy a especific OVP for my car? also where to buy it?
My car is a 1991, 300CE-24, japan spec & has the m104.980 engine.
Many thanks
Gianpiero124 is offline
post #2 of 19 (permalink) Old 04-22-2015, 06:13 PM
LeftCoastGeek's Avatar
Date registered: Jul 2011
Vehicle: 1993 300CE Cabriolet (mine) ; 1994 E320 Wagon (wife's) ; 1990 Benz 300E 2.6 (son's)
Quoted: 1319 Post(s)
ideally, you look up the correct part number for your VIN in the EPC. Stribel and KAE makes them for Mercedes and those are pretty widely availalbe via the aftermarket parts supply chains.
My M103 based 1990 uses 2015403745, while my M104.992 based E320 uses 0005406745 or 0005405245. I've never had a 104.980 so I dunno what it uses.
EPC suggests a Japanese market 124.051 300CE-24 uses the 2015403745 also.
I'd get it from here,
https://www.fcpeuro.com/products/mer...lay-2015403745
but if you're in Chile, I doubt they ship there.
Jayare, liebeskind and LostInTime like this.
LeftCoastGeek is online now
post #3 of 19 (permalink) Old 05-06-2016, 11:27 AM
Itamar's Avatar
Vehicle: 124.031 1992 300E-24 3.0 L M104.980 I6 Sedan
Quoted: 2 Post(s)
Hello there...
I would like to kknow if someone can help me on this. Uro parts might have doomed my W124. Take a look at the OVP... What might have happened with other parts?? The car cranks, but does not start...
Itamar is offline
post #4 of 19 (permalink) Old 05-06-2016, 12:20 PM
gsxr's Avatar
Vehicle: Buncha W124's
Quoted: 118 Post(s)
Is the failed OVP relay Uro brand? If so... I hope you learned a lesson here. Also read this thread for more enlightenment:
https://www.benzworld.org/forums/w126...uro-parts.html
Dave M.
Boise, ID
1997 E420 - 159kmi (
1994 E420 - 150mi (
1994 E500 - 115kmi (
1992 500E - 179kmi (
gsxr is offline
post #5 of 19 (permalink) Old 05-06-2016, 12:52 PM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1848 Post(s)
But, but according a certain forum member URO is "da bomb a.k.a. da sh!t" and anybody who even dares to think about buying the genuine MB version is a fool/moron.
LWB250 and Jacques405 like this.
sbaert is offline
post #6 of 19 (permalink) Old 05-06-2016, 03:02 PM
LWB250's Avatar
Date registered: Jan 2013
Vehicle: 65 220SEb, 97 SL500, 98 E320 Wagon, 2002 ML500 - former W108/W112/W114/W123/W124/W126/W140/W220
Quoted: 1052 Post(s)
Originally Posted by Itamar View Post
Hello there...
Must be like their flex disks. Guess they don't *quite* meet the standards.
Another reason to avoid their stuff.
Dan
LWB250 is online now
post #7 of 19 (permalink) Old 05-06-2016, 04:14 PM
Date registered: Nov 2007
Vehicle: 1984 380SL, 1985 500SEC
Quoted: 12 Post(s)
Hello there...
Originally Posted by 1mbzdoc View Post
just hooking up cables can damage ovp relay. i have worked on these cars for more than 30 years and the old cars have no problem with jump starts but the computors dont like spikes or low voltage. the sl is probably mercedes most jump started model because they sit in garage most of the time. i have seen the fuse in ovp relay blown after correct jump start so to say that all reports of damage are from incorrect cable hookup is just not true. a battery tender is best option will keep batt from getting low. very little damage reported from vehicle with dead batt most of the time damage is on the vehicle that is used for jumping. just disconnect good bat from car than use it to jump. mercedes reccamends to only try to start car when batt is fully charged. not reccamended to start with low bat
Did you jump start your car? This is a common cause of ovp relay issues.
dmotoren is offline
post #8 of 19 (permalink) Old 04-05-2017, 11:17 AM
Itamar's Avatar
Quoted: 2 Post(s)
Now, with a new OVP, kaehler, the OVP SPARKS!!!
Itamar is offline
post #9 of 19 (permalink) Old 04-10-2017, 05:19 AM
Date registered: Apr 2017
Hello everyone, i want some help about a problem that i got recently. im kind of amateur so any help would be great. I have s124 200TE...the car worked fine until yesterday when i tryed to start it and it didnt. My battery was down sudently...i didnt hear the fuel pump running. i thought maybe is problem of the fuel pump because i checked the fp relay and it looks in good conditions. as i have a lpg too, i tryed to start it with lpg,,,(i did this some times before and it started) but didnt happen anything...the car cracks but not started...so i found the ovp relay but o dont know in what condition it is because theres a lot of rust...so do you think thr cause of all this is the ovp? thank you
Tema-Punim Diplome is offline
post #10 of 19 (permalink) Old 04-10-2017, 06:17 AM
sbaert's Avatar
Rusty OVP? Post a picture, but your symptoms sound more like worn out voltage regulator. The discharged battery is the key
sbaert is offline
