Just put Dexron VI in my E320, 1994 - Page 5 - Mercedes-Benz Forum
Closed Thread
post #41 of 93 (permalink) Old 11-30-2014, 05:18 PM Thread Starter
Date registered: Sep 2009
Vehicle: E320, 1994, 1995
Quoted: 69 Post(s)
Found this statistics by BMW drivers on their transmissions and the use of ATF. Quite interesting.
Collecting Statistics on BMW auto transmission and Lifetime ATF
What is your BMW auto transmission maintenance experience? Voters 1286.
Followed BMW Lifetime ATF recommendation, did zero maintenance and auto trans. is fine. 616, 47.90%
Followed BMW Lifetime ATF recommendation, did zero maintenance and auto trans. failed. 151, 11.74%
Did an ATF drain/refill w/ BMW specified ATF fluid and auto trans. is fine. 215, 16.72%
Did an ATF drain/refill w/ BMW specified ATF fluid and auto trans. failed. 50, 3.89%
Did an ATF drain/refill w/ non-BMW ATF and auto trans is fine. 238, 18.51%
Did an ATF drain/refill w/ non-BMW ATF and auto trans failed. 16, 1.24%
The most interesting numbers above is that if you do nothing and treat ATF as life time fluid, 151 out of 767 cases (=151+ 616) result in failed transmissions, nearly 20% failure rate. This is a very high failure rate. On the other hand, if you do ATF changes with or without BMW ATF, the failure rate is 13%, a drop of 7%, which is statistically significant.
Finally, if you do ATF changes with BMW fluid, the failure rate is 50 out of 265, nearly 20%, similar to the case of doing nothing. Why? Dealer-maintained vehicles? On the other hand, if you do ATF changes with non-BMW ATF, only 16 out of 254 failed, only 6.4% failure rate.
So much for the BMW fluid, or any maker branded fluid, if similar statistics hold. Based on the above statistics, I assume that the last group, who are daring to trust the spec, not the brand name, are probably more technical savvy and take care of their cars better.
This survey is not perfect because it does not distinguish how often ATF is changed. Still, doing nothing or following BMW to teeth are the worst off groups. Is it true that if one follows MB to the teeth, he or she may not be that much better off as perceived?
jftu105
jftu105 is offline
post #42 of 93 (permalink) Old 11-30-2014, 05:50 PM
~BANNED~
Date registered: May 2009
Vehicle: 2003 Mercedes S430
Quoted: 67 Post(s)
I don't think that "lifetime" references to the transmission fluid were ever intended to suggest that the transmission would last a "lifetime". The inference that is drawn is that the transmission has a lifetime useful life, much like a part bought at AutoZone that is advertised with a "lifetime warranty".
I believe that the manufacturers are still trying to convince people that all that is required is gas and go. I see a lot of cars coming through the dealer auction where the first thing that the car needs is a good maintenance catch-up.
Going through a transmission, you'll find that other than clutch discs, you can get wear from metal parts if not properly lubricated. All of that clutch debris floating around in the fluid does interfere with the lubricating abilities. Also, the fluid wears out from heat.
I vote to change it, but not by using something that the manufacturer did not specify.
Next someone is going to say that they used Smuckers Strawberry jam in their transmission and it was "a noticeable improvement in shift quality".
tony1963 is offline
post #43 of 93 (permalink) Old 11-30-2014, 06:52 PM
dave300D93's Avatar
Date registered: Dec 2012
Vehicle: 93 300D
Quoted: 12 Post(s)
Now Tony, everybody knows that Smuckers Strawberry jam is synthetic based and contains way too many abrasive fines from the little strawberry seeds.
Any brand of organic grape jelly (not jam...viscosity is too high) would be a much better choice, is almost guaranteed to produce much smoother shifts and is also backwards-compatible.............except into reverse.
dave300D93 is offline
post #44 of 93 (permalink) Old 11-30-2014, 07:33 PM
~BANNED~
Quoted: 67 Post(s)
Thanks for correcting my error.
Has anyone tried Wal-Mart's Great Value brand grape jelly in their transmission?
I understand that Mercedes has authorized it for use in their 722.9 7-speed units. According to the report that I read, the grape jam interacts well with the molasses-based friction discs.
Its great to know that there is now an organic solution to all of that nasty Dexron.
Maybe Wesson oil for washer fluid?
tony1963 is offline
post #45 of 93 (permalink) Old 11-30-2014, 11:55 PM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1848 Post(s)
Guys,
You're wasting your breath on a cheap @ss who is still trying to justify pulling used brake pads and water pumps from the junkyard.
And should I mention the "resolder OVP" theory he's been advocating as well???
This guy's news stories hold about as much water as the National Enquirer.
sbaert is offline
post #46 of 93 (permalink) Old 12-01-2014, 01:42 AM
dave300D93's Avatar
Vehicle: 93 300D
Quoted: 12 Post(s)
Oh, now you've gone and done it...you've insulted the Sheeple's most respected source of truth and guidance.
post #47 of 93 (permalink) Old 12-02-2014, 01:54 PM
Date registered: May 2014
Vehicle: 1988 300e 75 300d 74 450sl
Quoted: 191 Post(s)
that is for the 2010 and newwer trans with the blue fluid not the red
rollin560 is offline
post #48 of 93 (permalink) Old 12-02-2014, 03:14 PM Thread Starter
Quoted: 69 Post(s)
Quote by rollin560
Nice to know the color change for newer MB transmissions. They add dye to get the color and I doubt the chemistry is drastically different.
T-man has been on my ignore list since 1963. I don't get to read his post but finally read it because it was quoted by your post.
I am so impressed with these smarT ass comments of his, which added so much intellectual value to this thread and showed off the sophistication of "elite" MB owners who don't shop at Walmart (Target, I suppose).
jftu105
jftu105 is offline
post #49 of 93 (permalink) Old 12-02-2014, 05:54 PM
~BANNED~
Quoted: 67 Post(s)
I appreciate your comments, thank you. I try to put my MBA in Health Services Administration to good use by adding a bit of information to an otherwise nonsense post.
You might be interested in my degree in accounting too, not sure.
I'm so happy to be on the ignore list of the graduates of The University of Waxed Bar Stool that come to this forum and think they have outsmarted MB by using a modern fluid in an old gearbox.
tony1963 is offline
post #50 of 93 (permalink) Old 12-03-2014, 03:21 AM
~BANNED~
Date registered: Feb 2009
Vehicle: 1993 400E
Quoted: 425 Post(s)
No such thing as "Lifetime" fluid, that was MBUSA marketing BS
The rest of the world has a 40K service interval on ATF service.
This guy is a moron Tony, your wasting your breath on his stupidity.
Clarkz71 is offline
Closed Thread
