Parts quality by brand - Mercedes-Benz Forum
post #1 of 35 (permalink) Old 09-16-2014, 10:14 AM Thread Starter
Trawlercap's Avatar
Date registered: Nov 2012
Vehicle: 1987 W124 260E
Quoted: 15 Post(s)
My morning muse....
1987 Mercedes-Benz 260E Base Sedan - Steering System - Page 2
Mercedes-Benz 260E Parts | FCP Euro
I am planning some DIY front end parts replacements. I have run into the "which brand to use" question.
I know Febi is Bilstien and is good (I think I know that) but I see Karlyn listed much less $ yet advertised as a German aftermarket. Then again Lemforder as well....and at much more, genuine Mercedes.
Ok is there a top to bottom/ Best to worst, list of manufactures amongst the group here? I do not want to save $25 and install crap, but do not want to spend on just a name either. Does the name vary from item to item? like; Febi is good for suspension, but Lemforder better for _____?
Name you preferences and suppliers, it would help a wanna be get a handle on parts procurement. Thanks ahead.
Also, from one of the suppliers pages I see this:
About Mercedes Benz 260E
The Mercedes Benz 260E was available as a sedan or as a wagon. It carried a 2.6 liter version of its predecessors straight six engine and had all the amenities indicative of a Mercedes Benz. The 260E was efficient and received a higher quality suspension system than the others, adding better handling capability as well as a lighter body due to exterior improvements. Many family oriented Mercedes enthusiasts chose the wagon version as it provided a high level of comfort and spaciousness for everyone in the vehicle.
I had never read this anywhere before, is there any truth to it?
1987 260 E 190K
My mechanic is BenzWorld/YouTube
Trawlercap is offline
post #2 of 35 (permalink) Old 09-16-2014, 10:32 AM
speed9644's Avatar
Date registered: May 2013
Vehicle: '94 E220
Quoted: 158 Post(s)
IIRC, the list from best to worse:
1.Genuine Mercedes (OEM)
2.Lemforder
3.Febi/Bilstein
4.Karlyn
5.ÜRO crap
Donno about the 260E article you read, but I suspect this isn't true, if it was true that 260E had different body and a lighter body, then it's price should be higher than other W124, (assuming same features)
Trawlercap and nathanD.rector like this.
- Samir
speed9644 is offline
post #3 of 35 (permalink) Old 09-16-2014, 11:06 AM Thread Starter
Trawlercap's Avatar
Quoted: 15 Post(s)
2.Lemforder
3.Febi/Bilstein
4.Karlyn
5.ÜRO crap
Thanks on that, yes I smelled a rat on the 260E being somehow special, maybe lighter due to smaller engine? But it must be the same engine block as all 103's.
Where is Meyle in this mix?
nathanD.rector likes this.
1987 260 E 190K
post #4 of 35 (permalink) Old 09-16-2014, 11:16 AM
~BANNED~
Date registered: Feb 2009
Vehicle: 1993 400E
Quoted: 425 Post(s)
Febi-Bilstein has nothing to do with BILSTEIN suspension
They are a reboxer of cheap Chinese parts, just as bad as URO
They make nothing, they sell parts from whoever has the cheapest price.
Meyle
Febi
Uro
In that order for cheap questionable parts
Stick with OE or Lemfoerder, Bosch, KAE, Bremi, Beru
Autohaus AZ usually says when a part is genuine Mercedes or OEM
Clarkz71 is offline
post #5 of 35 (permalink) Old 09-16-2014, 11:18 AM
Date registered: Oct 2005
Vehicle: 13 GLK350, 03 c320 wagon, 90 560sec
Quoted: 81 Post(s)
When doing front end, don't skimp. If it's not at least Febi/Bilstein/Boge quality, don't get it. I thought I'd go cheap on my 300te and got Meyle motor mounts (granted, motor mounts aren't front end, but it's for comparison), as I thought I'd use the car as a beater. Got Boge for the 190e as I thought I'd baby that one more. Well, the 300te grew on me, and the difference in engine vibration is significant between the Boge and Meyle mounts. Can't tell the motor is running with Boge, but feel a little vibration with Meyle, so I'll be ordering some OEM mounts for the 300te soon, as I really enjoy driving it.
Using good parts in the front end is very important if you want to retain the good feel of your car.
Edit:
Didn't know that about Febi-Bilstein, so see above for minimum quality.
jjcarr is offline
post #6 of 35 (permalink) Old 09-16-2014, 11:27 AM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1682 Post(s)
I tend to prefer Lemfoerder and Sachs-Boge for chassis and suspension bits. Actually, Febi does build some of its own parts (even in Germany), or at least they have in the past. They have a rather checkered reputation nowadays, due to the aforementioned repackaging problems found so often in the industry. The real evil found in the Asian parts is in the rubber and plastics/pot metals they use; the former is prone to succumbing to UV breakdown and the latter to brittleness and fatigues. If you can afford it, I'd go with OE stuff from a dealer source.
Zeitgeist is offline
post #7 of 35 (permalink) Old 09-16-2014, 11:37 AM
~BANNED~
Vehicle: 1993 400E
Quoted: 425 Post(s)
Everything I've seen the last 5 or 6 years from Febi is crap
And the boxes all say Febi-Bilstein Germany, not "made in Germany"
Then you open the box and there's a made in China decal on the part
Many aftermarket companies do this, all they need is to have the company
headquarters in Germany and they can add Germany to the name on packaging
Meyle does it to
Clarkz71 is offline
post #8 of 35 (permalink) Old 09-16-2014, 11:51 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1848 Post(s)
OR it might just say "Made in Unknown". Haven't found that country on Google Maps yet.
nathanD.rector and speed9644 like this.
sbaert is offline
post #9 of 35 (permalink) Old 09-16-2014, 12:10 PM
Cruise Control
Zeitgeist's Avatar
I have NOS boxes here, that are stamped Febi right on the part. 103 serp belt tensioners and flex discs. No idea how old these are, but they're definitely made in Germany. Febi also makes or repackages their own Euro manufactured hydraulic fluid. Sadly, I've also heard that Lemfoerder has been known to market Asian made parts these days.
post #10 of 35 (permalink) Old 09-16-2014, 12:16 PM
~BANNED~
Vehicle: 1993 400E
Quoted: 425 Post(s)
Those must be more then 5 years old. I remember back in the day
they did have some good parts.
The fluids are GTG
The transmission fluid is Fuchs, I'm not sure who does their hydraulic oil.
But it should say MB approved on the bottle, the 236.14 ATF does
They don't sell any Dexron VI though...... had to get that in...
Clarkz71 is offline
