M103 belt tensioner ramp? - Mercedes-Benz Forum
post #1 of 20 (permalink) Old 05-30-2014, 02:08 PM Thread Starter
Date registered: Apr 2011
Vehicle: 91 300TE 4Matic
Quoted: 2 Post(s)
Hi, I just replaced my serpentine belt on my 91 300te wagon, everything runs pretty well until I noticed the belt is a little loose compare to yesterday. I'm worried that the tensioner is not working properly.
The pointer past the left marker(facing the car) on the tensioner. I also recall that I can't move the pointer much during the belt change, the pointer stayed close to the left marker and didn't go to the right marker on the ramp even when the belt is slacked.
Is the tensioner dead?
Thanks for your help.
highpeak is offline
post #2 of 20 (permalink) Old 05-30-2014, 02:36 PM
joesflashdog's Avatar
Date registered: Apr 2013
Quoted: 9 Post(s)
M103 belt tensioner
I bought the LITENS brand tensioner and idler pulley from advanced auto parts , the tensioner is made in Germany and looks OEM to me ( see my pictures on a old post ) about $100 less than parts.com but not a URO part . I am happy with it .
91 300E 91 300CE 93 400E 2000 BMW K1200RS
joesflashdog is offline
post #3 of 20 (permalink) Old 05-30-2014, 03:05 PM
LeftCoastGeek's Avatar
Date registered: Jul 2011
Vehicle: 1993 300CE Cabriolet (mine) ; 1994 E320 Wagon (wife's) ; 1990 Benz 300E 2.6 (son's)
Quoted: 1293 Post(s)
indeed, that sounds like a dead tensioner... I assume you loosened the main bolt through the tensioner before turning the tension adjuster screw?
if you remove the tensioner entirely, and examine it, the flats which the adjuster arm work against should be centered on the pulley, like the picture on the right... the one on the left, you can see the flats are aimed off to the right, thats bad.
PWogaman and humblejoe like this.
LeftCoastGeek is offline
post #4 of 20 (permalink) Old 05-30-2014, 08:09 PM Thread Starter
Quoted: 2 Post(s)
Thanks. I did loose the main bolt before adjust the tensioner. I replaced it 8 month ago, its a URO brand. Looks like I need to get a Dayco or Litens tensioner.
highpeak is offline
post #5 of 20 (permalink) Old 05-30-2014, 09:59 PM
miltiano32's Avatar
Date registered: Dec 2010
Vehicle: 1988 300CE
Quoted: 81 Post(s)
Please replace that URO tensioner asap, URO is like the plague for our cars. Failures happen very very early due to the bad quality, if you search this forum all you will see is negative comments. Nothing good ever comes from URO.
Most of us wonder how they are still in business.
PWogaman likes this.
miltiano32 is offline
post #6 of 20 (permalink) Old 05-31-2014, 07:33 AM
Vehicle: 1995 E320 Wagon
Quoted: 7 Post(s)
Gates also has a made in Germany tensioner. It had an INA pulley on it. Might be easier to find.
jmanbball is offline
post #7 of 20 (permalink) Old 06-03-2014, 04:01 PM
Date registered: Feb 2011
Vehicle: 1992 300E 198,000 miles
Quoted: 4 Post(s)
Hi, I'm in the process of replacing my power steering pump. I am to the point of loosening the 19mm tensioner "clamping bolt" but the thing won't budge. I'm using a half inch drive rachet with the 19mm socket so I do have some leverage. I have read so much here about tensioner problems, I don't want to screw it up. Should I use my 2 foot breaker bar and lean into it, or am I going to mess it up? I've had two tensioners replaced (by an experienced Mercedes mechanic) in the last three years so I don't want to pay for another one.
Last edited by xswg; 06-03-2014 at 04:05 PM. Reason: to add that previous 2 tensioners were not installed by me.
xswg is offline
post #8 of 20 (permalink) Old 06-03-2014, 06:15 PM
2 in 3 years suggests they were low grade aftermarket. the original mercedes ones last 10-20 years.
I dont recall that bolt being that hard to remove on mine, I think I just used my normal 3/8" ratchet set, with 6-point sockets.
post #9 of 20 (permalink) Old 06-04-2014, 05:45 AM
Quoted: 4 Post(s)
Just had the alternator replaced several months ago and they left the belt with several inches of play. The power steering was already making a 'bad bearing' noise and nothing else seemed newly wrong so I didn't go back to the mechanic to have the belt tightened. This too-tight bolt makes me wonder if something might be squirrely with the tensioner.
xswg is offline
post #10 of 20 (permalink) Old 06-04-2014, 07:58 AM Thread Starter
Quoted: 2 Post(s)
I just use a little bit more force and a pipe over the handle of the torque wrench to loose the 19mm bolt, sometime the mechanic tighten the bolt way past the 75Nm required torque.
highpeak is offline
