'93 Sportline Control Arms - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 06-24-2012, 04:35 PM Thread Starter
Date registered: Aug 2011
Vehicle: 1993 300CE Sportline
I have a 1993 300ce Sportline with the 124.052 body. I'm looking to replace the front control arms and have run into a problem.
Everyone seems to list the Sportline control arm replacements in two groups for the 1993, as VIN 000000 to C017668 or from C017669 on up.
I happen to have VIN B905899. The problem is that no one carries the VIN 000000 to C017668 control arms, they all list them as out of stock.
Would anyone happen to have a source for VIN 000000 to C017668 Sportline control arms, or possibly what else would fit the car?
Thanks in advance.
M. Schneider likes this.
SportlineCE is offline
post #2 of 10 (permalink) Old 06-24-2012, 08:45 PM
ccrelan's Avatar
Date registered: Sep 2010
Vehicle: 1995 C36 AMG
Quoted: 38 Post(s)
Autohaus AZ Front LCA, Febi
This thread may help you
ccrelan is offline
post #3 of 10 (permalink) Old 06-25-2012, 07:58 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1848 Post(s)
Sportline controls arms are going to be pretty much a dealer only part.
IIRC, the control arm bushings are not included with the dealer part. They must be purchased separately.
sbaert is offline
post #4 of 10 (permalink) Old 06-25-2012, 09:11 AM Thread Starter
Thanks for the feedback guys.
If I wanted to order a set of non-Sportline lower control arms and to then upgrade the arms with Sporteline bushings, what LCAs should I buy? Based on what I'm reading the only difference between the standard W124 LCAs and the Sportline LCAs is the bushing, it this correct?
Again, this is for an original, stock, '93 300CE Sportline.
post #5 of 10 (permalink) Old 06-25-2012, 09:17 AM
sbaert's Avatar
Nope, the A arm is physically different between Sportline and non-Sportline.
I would avoid Febi A-arms even if they did make a Sportline version. Last I heard, they were made in China.
I don't know of any aftermarket supplier of Sportline arms rendering them pretty much a dealer only item if you're looking to get new A arms.
sbaert is offline
post #6 of 10 (permalink) Old 06-25-2012, 09:24 AM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1682 Post(s)
I'm pretty sure the only difference with Sportline LCAs is that the inner bushings are simply stiffer. I believe the chassis cutoff is to delineate between the LCAs with the replaceable and non-replaceable balljoints.
Zeitgeist is offline
post #7 of 10 (permalink) Old 06-25-2012, 09:29 AM
sbaert's Avatar
IIRC, there is also a 124-330-06-75 Sportline bushing kit.
AutohausAZ sells it/used to sell it and is/was made by Lemfoerder who is most likely the OES to MB.
I would also suggest replacing the eccentric bolt just for the sake of safety. MB p/n#2013300018
sbaert is offline
post #8 of 10 (permalink) Old 06-04-2019, 04:08 AM
Six_wheeler's Avatar
Date registered: Jun 2004
Vehicle: 1994 E320
Quoted: 98 Post(s)
Send a message via MSN to Six_wheeler
Which side of the fence are we at, gentlemen?
Shady
1994 E320
Six_wheeler is offline
post #9 of 10 (permalink) Old 06-04-2019, 03:19 PM
Premium Member
Date registered: May 2018
Vehicle: MY94 E320 Coupe
Quoted: 11 Post(s)
Premium Member
Sportline suspension bits.
Being a w124 coupe owner of two years there comes a time to begin refurbishing the 25 yo suspension; OEM front to back. After 10 months of scouring the earth for true OEM suspension components, mainly Sportline spec., it is my understanding the difference between the two is in a bushing's hardness. The "Shore durometer hardness scale" is often sighted.
Bit by bit new OEM Sportline front dampers were sourced, as was most everything else on both front/rear axles. A thorough rebuilding right down to new hardware where possible was the way north... In only one instance,,, new Sportline coil springs were substituted by Eibach street sport springs bought while in Germany. Lufthansa lov'd the weight. The rear swaybar was a mix and match with an E420 sedan IIRC. It's all good.
Here's a link to 124 Performance. http://www.w124performance.com/docs/...4_swaybars.pdf
Cheer's Mike
'94 E320 Coupe - 2nd Owner, 702 H Smoke Silver / 265 Leather - Creme Beige/Mushroom 8E80
'98 911 Carrera C2S - Org Owner Arctic Silver LY7U / Leather-Black
M. Schneider is offline
post #10 of 10 (permalink) Old 06-05-2019, 09:27 AM
Robert Kyle's Avatar
Date registered: Feb 2018
Vehicle: 1994 e320 coupe (sold), 1990 300CE ($400 beater)
Quoted: 163 Post(s)
https://www.getmercedesparts.com/oem...arm-1243303507
https://www.getmercedesparts.com/oem...MtMmwtbDYtZ2Fz
Do you really really need Sportline-specific control arms? Are you going to go racing around a track?
Robert Kyle is offline
