Becker volume knob fix - Page 3 - Mercedes-Benz Forum
post #21 of 30 (permalink) Old 08-02-2018, 12:02 PM
Date registered: Jul 2018
Vehicle: W140 1994 S500 coupè
Quoted: 5 Post(s)
I used this old thread because I also want to know how to properly remove the volume knob of this radio.
thank you so much
godret is offline
post #22 of 30 (permalink) Old 08-02-2018, 12:30 PM
126guyMD's Avatar
Date registered: Nov 2017
Vehicle: 1989 560SEC
Quoted: 40 Post(s)
thank you so much
It pulls straight off the metal shaft. If it does not come off easily, a small flat-blade screwdriver or plastic interior trim wedge inserted behind can “encourage” it off the shaft.
Just take it easy...and take your time.
If you need a knob, PM me.
126guyMD is offline
post #23 of 30 (permalink) Old 08-02-2018, 12:32 PM
LeftCoastGeek's Avatar
Date registered: Jul 2011
Vehicle: 1993 300CE Cabriolet (mine) ; 1994 E320 Wagon (wife's) ; 1990 Benz 300E 2.6 (son's)
Quoted: 1296 Post(s)
it should just pull straight off. its likely very stiff if its not been removed for the 25-ish years since new. using a knob puller will likely help, htats a springy U-shaped tool with two hooks that reacch around behind the knob.
LeftCoastGeek is offline
post #24 of 30 (permalink) Old 08-02-2018, 12:36 PM
Quoted: 5 Post(s)
thanks. if i'll needed knob i'll write you!
godret is offline
post #25 of 30 (permalink) Old 08-02-2018, 12:52 PM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1063 Post(s)
Surely there are replacement knobs in Europe..
Sent from my XT1710-02 using Tapatalk
Jayare is offline
post #26 of 30 (permalink) Old 08-03-2018, 07:43 AM
humblejoe's Avatar
Date registered: Feb 2007
Vehicle: 04 odyssey (265k) 1995 E320 wagon (295k)
Quoted: 317 Post(s)
The replacement knobs from Turkey (or Poland?) are not of the same quality.
They are lower quality and the center portion where the light comes through is an insert that is not always the cleanest. (usually has nubs from where it was cut off from the molding)
But they don't have and of the grippy coating to get chewed up.
Becker Autosound has knobs ~$30, but I don't know if they are of same quality either. Only have experience with the Turkish ones.
"alte Schulqualität"
W124, One of the last great gifts of West Germany
humblejoe is online now
post #27 of 30 (permalink) Old 08-03-2018, 09:22 PM
Date registered: Feb 2009
Vehicle: 1995 e320ce. 1993 230 TE. 1987 Kit car with 260e running gear.
Quoted: 80 Post(s)
Wrong forum
boyd waugh is offline
post #28 of 30 (permalink) Old 01-13-2019, 07:21 AM
Date registered: Jan 2019
Vehicle: 1995 E300 Diesel
Found on the german ebay the original Becker knob and poti for the following US Becker radios: BE1491 BE1492 BE1691 BE1692
Link to repair kit: https://www.ebay.de/itm/Reparaturset...G6jQ:rk:1f:0
Ebay name of seller: bv.carsound
devourer is offline
post #29 of 30 (permalink) Old 01-13-2019, 07:50 AM
Real1shepherd's Avatar
Date registered: Jul 2009
Vehicle: '92 300TE 4matic 280,000miles, '92 300TE 4Matic 'Ice Blue Metalic' 101,000miles
Quoted: 482 Post(s)
Knob and pot $51 before shipping.
Kevin
Real1shepherd is offline
post #30 of 30 (permalink) Old 01-13-2019, 01:57 PM
Kevin
Yes, unfortunately pretty expensive for a $2 poti. It came to $58 with shipping. Once I get it I will check for a part number and post it if there is one. I also tried to get the poti mention earlier in this thread from digi key but they have minimum order quantities of 1500 (!).
devourer is offline
Radio Volume Knob rorypff R129 SL-Class 1 09-27-2011 11:45 PM
volume knob doesn't work 1997 e 420 Gab2012 Audio & Telematics Forum 0 08-28-2010 04:57 PM
Volume knob no longer in control Diego97 Audio & Telematics Forum 1 05-09-2007 07:56 AM
BECKER exquisit volume knob FIX :) Locry Audio & Telematics Forum 0 11-26-2006 05:41 AM
Volume Knob ---- Help davaid W210 E-Class 7 10-12-2006 07:18 AM
