OVP - basic function and test - Mercedes-Benz Forum
post #1 of 72 (permalink) Old 02-22-2011, 06:38 AM Thread Starter
Date registered: Apr 2010
Vehicle: 1988 300E
Mercedes OVP – A Basic Primer and Test Process
I am dealing with my second failed OVP and reviewing the various links prompts me to try to consolidate some of the scattered information into this single format. I hope it is useful. See Figure 1. below for a picture of a typical OVP relay.
Over Voltage Protection [OVP] – devices are used to protect sensitive electric circuits from damaging high voltage. Two OVP protected circuits in the 124 series Mercedes are the Electronic Engine Control and the ABS [anti-lock brake] circuits. Hard starting/stalling are often symptoms of a failed EEC circuit, often in conjunction with an illuminated ABS light on the instrument panel. The OVP device supplying power to both these circuits is located under the hood, behind the battery, somewhat behind a removable plastic splash panel on the passenger side of the vehicle (North American configuration). It looks like Figure 1. The first thing to check is that the 10 amp fuses on the top of the device are not blown. Assuming the fuses are OK, replace them, and to further test the device; remove it from the car by wiggling and pulling it free from the plug base. Figure 2. shows what it looks like inside with the metal canister removed; but it is not necessary to dismantle the device to test its basic function. Figure 2. below is mainly intended to identify the circuit pins referred to in the next section.
The basic function of the OVP is this: Battery voltage is always present at pin 30 (nominally 12.5v – higher when the alternator is charging); and the device is connected to chassis ground through pin 31. With the ignition off (that is no 12v current delivered to pin 15) there should be battery voltage at pins 30a and 30b, but no voltage at the protected circuits 87E and 87L. If there is voltage at the 87E or 87L pins with the ignition off there is an internal short in the device. When the ignition key is turned on, battery voltage is applied to pin 15 (the skinny one) which pulls in a relay switch and battery voltage is then supplied to both the 87E and 87L protected supply circuits.
To test the basic functioning of the device out of the vehicle you only need a 12v power supply (a battery), a couple of (actually 3) jumper wires with alligator clips, and a DC voltmeter. First connect the 12v positive jumper (preferably through a 10 amp fuse) to pin 30, and the 12v negative jumper to pin 31. Use the voltmeter, with its ground lead attached to the negative terminal of the power supply (battery), to check for positive voltage at the other pins. There should be 12v at pins 30a and 30b, but no voltage at any of the other pins [15, 87E, or 87L]. Without disconnecting the jumpers to pins 30 and 31, now connect a third jumper wire from the positive side of your power supply to pin 15 (this is the same as turning on your ignition switch when the device is in the car). You may hear a slight click as the relay pulls in the internal switch, and now when you test the pins with your voltmeter, 87E and 87L should be reading 12v. If there is no voltage or reduced voltage at the protected circuits 87E and 87L this indicates a faulty OVP.
Note that passing this basic test may not be the whole story, as electric devices can fail intermittently, or partially, when in their real working environment. Further testing after heating (hair blower) or cooling (freezer compartment) may be useful if a temperature sensitive intermittent failure is suspected.
ID:	358717   Click image for larger version
Ian_C. is offline
post #2 of 72 (permalink) Old 02-22-2011, 03:43 PM
Date registered: Jan 2011
Vehicle: Merc E320 1995, BMW 740i 1995 (sold)
Thanks, Ian. Can we add this to the DIY thread?
Girrard is offline
post #3 of 72 (permalink) Old 02-23-2011, 02:05 AM Thread Starter
Vehicle: 1988 300E
Girrard. By all means, I am still half lost trying to navigate the various threads and forums. If anyone knows how to put this info in the DIY section please feel free.
Ian_C. is offline
post #4 of 72 (permalink) Old 03-06-2011, 04:31 PM
clos650's Avatar
Date registered: May 2009
Vehicle: 1990 300E 2.6 174,000Miles
Send a message via AIM to clos650
Will this test be the same with the OVP with 1 fuse?
clos650 is offline
post #5 of 72 (permalink) Old 03-07-2011, 12:53 PM Thread Starter
Vehicle: 1988 300E
Looking at the wiring diagrams I have doesn't make it perfectly clear to me, however, it would appear that they went from one fuse for both protected 87 circuits, to a separate fuse for the 87 L circuit (idle air valve/others?), at some point. Assuming good fuse(s), the test described would be the same. Ian
Ian_C. is offline
post #6 of 72 (permalink) Old 03-07-2011, 01:28 PM
clos650's Avatar
Thanks
clos650 is offline
post #7 of 72 (permalink) Old 03-07-2011, 04:19 PM
clos650's Avatar
my OVP only have 7 pins look at pictures
ID:	361433   Click image for larger version
clos650 is offline
post #8 of 72 (permalink) Old 03-09-2011, 04:41 PM
hdy_rgnc's Avatar
Date registered: Oct 2008
Vehicle: 1991 300TE 4matic
excellent thread
awesome information here, I think I might be dealing with an OVP problem myself. Intermittent no-starts with battery power (lights, radio, etc. works), no crank whatsoever, cold start problems, and just nothing happening in key position 3. I check all fuses, and battery is fully charged. I would happen every few months, then every few weeks, then every few days. Now I havn't been able to start it since Thursday and charged the battery since then.
I should also say that I've had an unresolved issue with my blower motor. Whenever I use it, it blows the fuse outside the box on the right under the hood (the single fuse with rubber cap). Every time I throw in a new fuse there and try the blower, it blows the fuse. So, for the past 2 years I havn't used the blower.
Thats the only other electrical bug its got, and after doing a ton of reading on these forums it sounds like the OVP.
Do you also think this is a likely candidate for my problem? Any opinions are appreciated before I spend the $50.
1991 300TE 4MATIC - LOOKIN FOR AMG WHEELS
hdy_rgnc is offline
post #9 of 72 (permalink) Old 03-09-2011, 04:49 PM
ps2cho's Avatar
Date registered: Oct 2006
Vehicle: 2008 E350 4M, 1988 300TE
Quoted: 347 Post(s)
^ No, the OVP is not your issue. So the car does not even turn over?
2016 Monsoon Gray Audi Allroad - 26k
2008 Black Mercedes E350 4Matic Sport P1 - 140k
2014 Jeep Wranger Unlimited Sahara - 90k
2003 Silver ML350 - 135k
ps2cho is offline
post #10 of 72 (permalink) Old 03-09-2011, 04:52 PM
hdy_rgnc's Avatar
no, it doesn't. I've had the starter replaced last year, but its almost like theres no power to it. I can turn on the lights and everything else, but position key position 3 doesn't do anything, not even a click or the engine turning over. so frustrating!
What about the EEC? I noticed when I have the key in pos 2 when all the dash lights are lit, the ABS light goes OFF while the other stay on.
hdy_rgnc is offline
UPDATE: I removed fuse on OVP Relay and car runs fine! Why? Should I drive w/o OVP? GermanCarNut W124 E,CE,D,TD Class 6 11-08-2010 08:16 AM
OVP from a 95 - looks original? How to test this bugger. soundquest W124 E,CE,D,TD Class 5 05-15-2009 03:05 AM
Neocons: It's Form FOLLOWS Function NOT Form INSTEAD of Function mcbear Off-Topic 13 09-22-2008 11:48 AM
Can someone explain the basic function of the Mechanical Injection? 220SEBC Vintage Mercedes-Benz 14 09-10-2008 08:33 AM
"basic" ML available? ML_captain W164 M-Class 7 01-26-2006 05:25 PM
