'93 300E Engine Wiring Harness Replacement - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 04-14-2010, 02:25 PM Thread Starter
Date registered: Apr 2010
Vehicle: 1993 300E L6 3.2L
Send a message via Yahoo to jervonics2112
Post '93 300E Engine Wiring Harness Replacement
Hey there,
I am going to replace my Engine wiring harness. I have heard that there is also another wiring issue that involves the starter/ignition that should be replaced at the same time. Can anyone tell me the exact name of the part so I can get it at the same time as my Engine Harness. I found a thread on these forums a year or so ago that had pics showing how to do the replacement. Supposedly it is supposed to be one of the easiest jobs to do on the 300E. Any help at locating the above mentioned part or the thread that shows the pics for DIY would be greatly appreciated. Thanks for your time....
jervonics2112 is offline
post #2 of 13 (permalink) Old 04-14-2010, 06:02 PM
Date registered: Jul 2004
Quoted: 485 Post(s)
It's called the starter/alternator harness, or the lower engine harness, lots of names. It doesn't necessarily have to be replaced at the same time - it's a different part and a completely different job. It might actually be a more difficult job than the upper engine harness, but the harness isn't nearly as expensive, and it isn't nearly as critical a part because the actual starter and alternator wires are not the ones that fail.
deanyel is offline
post #3 of 13 (permalink) Old 07-13-2011, 09:24 PM
Date registered: Jul 2011
replacing starter/alternator harness... ?
i just brought my car into the shop and the mechanic told me that i need to change this part. he is asking for 275 for parts and labor... is this a reasonable price? I cant seem to find the part online anywhere? where were you able to find your starter/alt harness?
guitarhero is offline
post #4 of 13 (permalink) Old 07-13-2011, 10:27 PM
Date registered: Jun 2009
Vehicle: 1995 E320 Wagon
It's on the EPC under starter harness. I've only found it at dealers. Price was about 175 retail. Your mechanic probably can buy it for about 130.
My engine harness was replaced on my 95 but my starter harness is severely cracked so is getting a new one is well. There are three wires over the oil filter that were the tell tail it was bad.
If I read the schematic the three wires are starting, oil pressure and oil level(maybe temp).
killo1 is offline
post #5 of 13 (permalink) Old 07-13-2011, 10:41 PM
im not familiar with what EPC is? is that a section on this website ?
post #6 of 13 (permalink) Old 07-13-2011, 10:49 PM
thank you!! do you think 270 is a reasonable price to get it replaced?
post #7 of 13 (permalink) Old 07-14-2011, 07:20 PM
Guest
Date registered: Dec 2006
Vehicle: ...
So you area saying that the starter harness consists of those 3 wires that run past the oil filter? I seem to have frayed wires at the same point. I have to be careful when doing filter changes as to not aggravate the problem. My main harness was replace by the PO...
xxxxxxDingo Joe is offline
post #8 of 13 (permalink) Old 07-15-2011, 06:22 AM
Yes, that is part of it.
I'll try to take a photo of my part later.
killo1 is offline
post #9 of 13 (permalink) Old 07-15-2011, 06:37 AM
Guest
Vehicle: ...
Hey that'd be great & good documentation for the site, as I'd assume that many people face this issue whether they know it or not. I often see in for sale ads, mention of the main harness being replaced, but never the starter wiring harness...
post #10 of 13 (permalink) Old 07-15-2011, 09:16 AM
Here you go.
killo1 is offline
1995 SL500 Engine Wiring Harness Replacement Keepontrucking R129 SL-Class 9 04-26-2018 07:51 PM
W124 Engine Wiring Harness - 300E eurosport W124 E,CE,D,TD Class 0 12-15-2009 06:54 AM
1996 c220 engine wiring harness replacement kickstarter69 W202 C-Class 7 10-21-2008 07:21 AM
Where to Purchase 93 300E Engine Wiring Harness tomer W124 E,CE,D,TD Class 2 10-01-2008 09:08 AM
Wanted: 1994 300E Engine Wiring Harness BigBruce For Sale/Wanted/Trade/Giveaway 5 06-15-2007 09:35 AM
