SRS light constantly on - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 02-21-2010, 10:40 AM Thread Starter
Date registered: Nov 2008
Vehicle: 93' W124 E36 AMG ; 71' Cadillac Eldorado
Quoted: 12 Post(s)
Unhappy SRS light constantly on
This week I finally installed the Euro headlights wipers.
After a few weeks of mechanics working on the thing, a friend of mine told me there is a small diode that might be bad and make a short. After spending a lot of money for the mechanics who told me that the wiper motor is the wrong type, I took the motor, replaced the diode, installed everything back and now it works...
But I am far from complete happiness. After standing at the mechanic's my 300E has an SRS problem. After I turn the key - SRS light comes on and stays. The mechanic tells me of course that they didn't touch anything related to SRS and that it "just happened" because the car was standing in cold (?!WTF!?)
I tried to read the codes from PIN #6, but the light is constantly on after just plugging the tool into PIN 6. I cannot read any codes.
I've used the search function, I really had, but nothing quite describes my situation. The light doesn't ever go off after turning the key, but when I turn the ignition comletely off it doesn't light.
Help me Guys. I hope they didn't burn the SRS module, while playing with the electrical system
W124 E36 AMG
MaxMatt is offline
post #2 of 14 (permalink) Old 02-21-2010, 12:22 PM
Date registered: May 2009
mostly only a connector that became loose
Cześć Max,
check the connectors under the front seats. I doubt it's got to do anything with the recent work on the headlight-wipers.
However I also reccomend that you check the red connector for the airbag in the steering wheel. It's possible the guy fiddled around somewhere near this connector (it is situated in the plastic housing for the steering column), as he might have taken the drivers side footwell padding off.
I still have some SRS black boxes for dual airbags to send to you if it's really something major.
Cheers,
Marian
Marian71 is offline
post #3 of 14 (permalink) Old 02-21-2010, 03:16 PM Thread Starter
Quoted: 12 Post(s)
Thanks for tips
I'll check the connectors under the seats first thing. I don't think they did anything to the area around steering wheel. They were testing the wipers and constantly burning the 8A fuse, so they put a beefier one in. When I picked up the car it had a 25A fuse.
What I am concerned about is that I cannot even pull the codes out of it. Last time I had squib error codes, but I managed to delete them all.
Anyway, thanks for input.
I'll write how I solved this problem. (when/if I do...)
BTW
I'm impressed with the Polish signs in Your post Marian
W124 E36 AMG
MaxMatt is offline
post #4 of 14 (permalink) Old 02-22-2010, 02:17 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1063 Post(s)
Max,
The SRS light stay on for the longest time with my coupe. The cure in my case was to remove the steering wheel and clean all the contact rings. Hasn't come back on since.
Good Luck,
Jayare
Jayare is offline
post #5 of 14 (permalink) Old 02-25-2010, 04:08 PM Thread Starter
Quoted: 12 Post(s)
I spotted some paw-prints in the engine bay and I wonder... The car stayed outdoors at the mechanic's. Is it possible that some sort of wiring is accesable through the engine bay and it could be damaged by an animal?
I try everything and the light is still on. Once the key is turned, it doesn't go off. I don't know if it makes any difference but the SRS light is constantly on - however it flickers very fast. Like if it was blinking with such a speed that the light never really goes out. I can see that it doesn't just glow steadily.
And this constant voltage on PIN 6... I cannot figure it out.
W124 E36 AMG
MaxMatt is offline
post #6 of 14 (permalink) Old 02-25-2010, 06:19 PM
Jayare's Avatar
Again, I'd try pulling the steering wheel and cleaning all the contact rings. I put a thin coat of di-electric grease on mine afterwards and the SRS light has not come back on since. It's been about a year now.
Jayare
Jayare is offline
post #7 of 14 (permalink) Old 04-30-2010, 06:45 AM Thread Starter
Quoted: 12 Post(s)
Jim, I managed to get the wheel off today. I cleaned all the contact rings and brushes to shine. No effect. The SRS light is still on all the time and I cannot read any codes out of PIN 6 (SRS).
I noticed the outer contact rings are quite "trailed" when the brushes come. However I suspect that if brushes were the problem - the light would go out at least sometimes.
I made sure all the connectors under the seats are connected properly.
Still nothing works
W124 E36 AMG
MaxMatt is offline
post #8 of 14 (permalink) Old 04-30-2010, 07:32 AM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1682 Post(s)
When I first bought my 300D, the SRS light would come on intermittently, especially during turns. When I pulled the stock wheel to swap in a C36 version, I found lots of carbon powder built up in the channels. Once I swapped the wheels, this issue cleared up...until then went to swap in leather seats. Now the light is always on with the key, and all my attempts to remedy have failed. As usual, I always snip the line that goes into the seatbelt receptacle, which has never caused a problem before. I've even tried bridging the connectors to fool the computer, but to no avail. At this point I'm stumped.
Zeitgeist is offline
post #9 of 14 (permalink) Old 04-30-2010, 07:54 AM Thread Starter
Quoted: 12 Post(s)
Is it possible that the SRS module is culpable of this? If it was bad, would there be a constant short on the diagnostic pin?
W124 E36 AMG
MaxMatt is offline
post #10 of 14 (permalink) Old 05-18-2019, 11:55 PM
Date registered: Oct 2009
Vehicle: 1992 400E
Quoted: 2 Post(s)
MaxMatt did you ever solve this problem? I am having the exact same problem with my -92 400E.
toonz is offline
SRS light stays on and SRS DTC strange result nubyOz W140 S-Class 8 11-25-2010 09:57 PM
ABS light on constantly - not OVP snakehips916 W201 190-Class 2 01-15-2010 09:15 AM
ASR light constantly on? renelsisc W140 S-Class 20 09-14-2009 05:00 AM
1997 E320 SRS LIGHT CONSTANTLY ON BrianP W210 E-Class 5 10-14-2008 03:49 PM
190E Coolant light constantly on... 190Evoluzione W201 190-Class 10 03-20-2007 04:31 AM
