Fan viscous drive clutch engagement spring change - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-20-2009, 08:37 AM Thread Starter
Date registered: Oct 2006
Vehicle: 2009 E300 4matic Avantgarde
Quoted: 2 Post(s)
Has anyone ever actually changed one of these and can advise just how easy or difficult it is to do? It's a tight squeeze getting in there; fan on or fan off the car the best way to do it?
Thanks in advance.
jackrabbit is offline
post #2 of 5 (permalink) Old 10-20-2009, 08:46 PM
Date registered: Aug 2009
Vehicle: 2005 E320 CDI, 1992 300TE, 1999 Porsche 911 Cabriolet
Quoted: 2 Post(s)
Post
If you are asking how to change the viscous fan clutch on a 103 engine, I can help. I don't know about a spring. The first thing on a viscous fan clutch is to remove the fan shroud.
Then make a tool to freeze the fan pulley. Mine is a bent piece of 1/8" rod (3 mm) with a 3/4" (19 mm) 'L' on one end and a loop bent into the other to hang on to. The whole thing needs to be about 8" (200 mm) long.
You feed the 'L' shape into a special groove on the pulley bearing flange and into a hole in the rear of the pulley hub. This allows you to loosen and retighten the fan bolts and the viscous clutch bolts.
A good fan clutch freewheels when cold and tightens when hot. It releases at 3500 rpm. When it is working correctly, you only hear it roar when you rev the engine on a really hot day. Otherwise, it is silent.
Good luck,
Peter
ptkacik is offline
post #3 of 5 (permalink) Old 10-21-2009, 04:12 AM Thread Starter
Quoted: 2 Post(s)
It's the heat sensitive spring which engages and disengages the clutch that needs to be replaced. I accidentally bent it and want to put on a new one; right now it's always engaged, so no danger of overheating but it doesn't freewheel over 3500 or at low temps, so it is a bit noisier than I prefer.
Thanks for the tool tip though.
post #4 of 5 (permalink) Old 10-21-2009, 07:06 PM
augapfel's Avatar
Date registered: Jan 2006
Vehicle: About a dozen 1988, 1989, 1990, and 1991 sedans, wagons, 4Matics and 1 coupe
Quoted: 47 Post(s)
AFAIK there's no replacing just the bimetal strip at the front of the fan clutch. You replace the fan clutch as an assemby only.
augapfel is offline
post #5 of 5 (permalink) Old 10-22-2009, 03:54 AM Thread Starter
Quoted: 2 Post(s)
It has its own part number on it, so I'm thinking there must be a way ...
Viscous fan clutch - how firm when cold? harlz W126 S,SE,SEC,SEL,SD,SDL Class 75 06-29-2009 11:50 PM
Viscous Fan Clutch and Pulley viejo1221 W201 190-Class 0 06-11-2009 11:13 AM
Viscous fan clutch impossible to remove? Sergio W124 E,CE,D,TD Class 11 03-23-2009 06:21 AM
Viscous fan clutch Ken D W126 S,SE,SEC,SEL,SD,SDL Class 4 09-25-2008 12:46 PM
viscous fan clutch briankim G-Class 11 08-06-2003 12:48 PM
