What did you do with/to your 124 today? - Page 429 - Mercedes-Benz Forum
post #4281 of 4306 (permalink) Old 03-24-2019, 02:53 PM
Earl.Allen's Avatar
Date registered: Mar 2014
Vehicle: '93 300CE, '84 300D, '75 450SL, '82 240D-sold,
Quoted: 28 Post(s)
1993 300CE- replaced battery, plugs, wires, coils and the OVP relay. Unfortunately, some ham-handed previous mechanic that worked with my step-father stripped out three of the six bolt holes holding the cover to the coils/heads. Had anyone had success with heli-coils or keen-certs in this application?
Thanks, Earl
Earl.Allen is offline
post #4282 of 4306 (permalink) Old 04-02-2019, 02:09 AM
Date registered: May 2012
Vehicle: '92 Mercedes 190E, '93 Ford LTD, '95 E320T
Quoted: 24 Post(s)
Received most of the parts for the Getrag conversion, Billet flywheel, LUK clutch, new pedal rubbers etc. Still looking for 16v shift rods and a clutch fork.
Also picked up some new shoes for her a couple of months ago. Plans are to strip the purple and paint Silver/Grey, although the Purple goes alright with the 009, more than I expected. New wheels really show just how high factory suspension is though....
1993 Ford LTD 5.0 Manual - Heavily Modified
1995 Mercedes E320T
2005 E46 318 M-Sport
M-Cedes is offline
post #4283 of 4306 (permalink) Old 04-02-2019, 03:59 AM
Date registered: Mar 2019
Vehicle: 1990 300E
Those rims are gorgeous! Exactly what I want on my car.
I tore apart my door panel to try to access the window regulator. Me being new to W124s, it took a minute. Tonight I'll check for broken wires, and if that's not the issue then I'll unbolt the regulator and prop the window up, since it's supposed to rain.
infinitenexus is offline
post #4284 of 4306 (permalink) Old 04-08-2019, 05:51 AM
Beezersh's Avatar
Date registered: Jul 2018
Vehicle: 1993 300e 2.8
Quoted: 15 Post(s)
Transmission fluid change failure this weekend.
A lot went well this weekend. Put in a new belt tensioner damper that was rattling. Two new trans coolant lines, new drive belt. There was definitely a learning curve ((curse)) involved as it took me probably 3x linger than it should. At dusk I was buttoning up the trans pan after successfully draining both pan, torque converter, etc. cleaned out the pan nice and tidy. Started to refill, and after 4 quarts began to hear it come out the bottom. Like EVERYWHERE around the gasket. So I caught as much as I could. Cheese cloth strained it. Pulled pan back off and checked fitment. All looked well! .....sooooo I buttoned it up again , repoured new fluid and....out it came again!!!! So I think I’m over tightening the bolts. Anyone else have this happen? Frustrating,..... waiting for more fluid from Amazon now.
Beezersh is offline
post #4285 of 4306 (permalink) Old 04-08-2019, 06:47 AM
Real1shepherd's Avatar
Date registered: Jul 2009
Vehicle: '92 300TE 4matic 280,000miles, '92 300TE 4Matic 'Ice Blue Metalic' 101,000miles
Quoted: 486 Post(s)
A lot went well this weekend. Put in a new belt tensioner damper that was rattling. Two new trans coolant lines, new drive belt. There was definitely a learning curve ((curse)) involved as it took me probably 3x linger than it should. At dusk I was buttoning up the trans pan after successfully draining both pan, torque converter, etc. cleaned out the pan nice and tidy. Started to refill, and after 4 quarts began to hear it come out the bottom. Like EVERYWHERE around the gasket. So I caught as much as I could. Cheese cloth strained it. Pulled pan back off and checked fitment. All looked well! .....sooooo I buttoned it up again , repoured new fluid and....out it came again!!!! So I think Iím over tightening the bolts. Anyone else have this happen? Frustrating,..... waiting for more fluid from Amazon now.
Only OE gasket for this job. It could be that your pan is warped. I have to use hylomar gasket sealer because my pan is warped. Check the factory torque spec for the pan bolts, as it's not much.
Kevin
Jayare likes this.
Real1shepherd is offline
post #4286 of 4306 (permalink) Old 04-08-2019, 07:55 AM
Beezersh's Avatar
Quoted: 15 Post(s)
Kevin
Ok thanks. Lesson learned. I THOUGHT those bolts came off awfully easy. Turns out there was a reason. 🤨
Beezersh is offline
post #4287 of 4306 (permalink) Old 04-22-2019, 12:18 AM
Date registered: Nov 2011
Vehicle: 1993 300D 2.5 "Elsie"
Quoted: 91 Post(s)
Replaced my coolant overflow tank, finally. Now I can see the coolant level without taking the cap off and shining a flashlight in...haha!
Also, if anyone is interested, the 124 500 184 9 tanks are no longer available, so I ordered a 124 500 134 9 tank. The 124 500 134 9 tank is almost exactly the same. The only difference I could find is that the 184 tank has a straight nub at the bottom that goes into the rubber grommet. The 134 tank has a nub with a bit of a hook at the end. Went in fine and didn't break the nub off.
Jayare likes this.
1993 300D "Elsie"
chuckh0308 is offline
post #4288 of 4306 (permalink) Old 04-25-2019, 12:21 PM
Macmade300's Avatar
Date registered: Jul 2016
Vehicle: 1990 300E I inherited from my grandmother
Quoted: 16 Post(s)
Disassembled my wiper assembly to figure out why it wasn’t working properly. Figured I’d clean and lube it while I was at it. And ordered up a new cog.
ID:	2507622   Click image for larger version
ID:	2507624   Click image for larger version
Macmade300 is offline
post #4289 of 4306 (permalink) Old 04-29-2019, 07:59 AM
Vehicle: W124 E420 : W220 S500 : W222 S550
my E420 got some care this weekend.
(1) I had some tire wear on the rear inside. It was substantial. to remedy, I ordered parts and then assembled adjustable camber arms (ordered from a website listed here on the forum). One big difference was that the bushings were meant for offroad and were very very stiff. but I found polyurethane (nice and red in color) that fit and used those. they are closer to rubber in characteristics by comparison. Also, I put high quality polyurethane grease liberally in the assembly. results are quiet and smooth ride.
(2) I replaced a failing regulator on the drivers door. IMPORTANT: The instructions call for removing rivets from the "sound system" speaker mounting. THIS SHOULD BE REMOVED FROM ALL INSTRUCTIONS. The SIMPLE way to do this is to unbolt the motor while it is inside the door. at that point the regulator hardware OR the motor can be removed, depending on your repair needs - and that's without removing the speaker mount. Next, your put the motor and/ or hardware back inside the door and assemble it inside the door. There is substantially ample room to do this inside the door. This simplifies the repair 10 fold. also, I used an exterior (weatherproof) grease on every moving part. I put thin layers in places where there is contacting rotating brackets and heavy on the tracks. It went really well and the window works smoothly.
(3) As much as I want to keep the car as original as possible, I left the farm this weekend. I located a pair of rear lights and added a several strings LEDS. I just grew tired of the small square tail light lenses (when lit) compared to the plethora of modern taillights you see today. It took about 4 evenings to build. I added LEDS for the taillight, which then brightens when the brakes are activated. Also, I added LED strips to the turn signals. I did leave the bulbs active although it looks good with or without the original bulbs. I attached a photo, but thanks to Samsung note, it shows the individual LEDs when they are actually fully diffused and don't appear as individual light sources..to keep the heat in check, I built a small box that houses the resistors and diodes. I mounted a very small, but effective, CPU fan that runs whenever the car is running to thwart any heat buildup.. actually I love the mod. My alterations to date are now the keyless entry (totally invisible) and now these LEDs (highly visible).
(4) changed transmission fluid and filter.
the "E" is happier than ever
Name:	W124 - rear LED tail and brake light.jpg
luckymike likes this.
kafklatsch is offline
post #4290 of 4306 (permalink) Old 05-12-2019, 06:42 AM
Beezersh's Avatar
Quoted: 15 Post(s)
Is that cog available still? How was reassembly?
Beezersh is offline
W124 Front Suspension - 124.128 vs. 124.09 jscottallen W124 E,CE,D,TD Class 2 09-24-2009 03:58 AM
94 E320 (124.032) ~ 89 300e 124.030 jephey W124 E,CE,D,TD Class 3 05-29-2007 09:53 PM
OT: Today is a special day!! Today smog checks in the bay area starts @ $130 a pop!!! Man-Du-Ru-Gas W163 M-Class 4 08-13-2005 03:58 PM
OT: Saw a white SL55 AMG today on 635-75 today Tangent R170 SLK-Class 5 07-11-2003 08:17 AM
Hoping to see more first hand 32 reviews today. I think a couple of people are taking delivery today SteveL R170 SLK-Class 13 07-29-2001 10:13 AM
