What did you do with/to your 124 today? - Page 377 - Mercedes-Benz Forum
post #3761 of 4321 (permalink) Old 05-18-2016, 11:32 PM
Date registered: Nov 2011
Vehicle: 1993 300D 2.5 "Elsie"
Quoted: 96 Post(s)
Originally Posted by tjts1 View Post
Oil change, engine mounts and alternator swap... finally. 70a -> 150a
I have 14.4v at idle and 14.2v at idle with every possible electric load switched on including 30a electric cooling fan in place of the viscous clutch. The old 70a alternator would drop to around 13.3-13.5v with a similar load at idle.
All the oil is from my front crank seal leak. I'll need to address that soon.
Does the alternator swap require a wiring upgrade? I don't think I would need 150 amps, but it would be nice to get at least 90. I sometimes see 90 amp units supposedly from Japan on eBay and have been wondering about them and what would be involved.
chuckh0308 is offline
post #3762 of 4321 (permalink) Old 05-18-2016, 11:44 PM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 696 Post(s)
Yes it does require a wiring upgrade. I added a 6' long 4awg cable between the alternator and battery in parallel to the 2 existing 10awg (I think) wires that the car already had. It's just barely visible coiled up at the bottom of the 3rd pic.
The 150a alternator outputs 90a at idle and 150a by 1500rpm. With a large alternator like this an overrunning pulley is also recommended.
chuckh0308 likes this.
tjts1 is online now
post #3763 of 4321 (permalink) Old 05-18-2016, 11:51 PM
Quoted: 96 Post(s)
Cool, thanks!
post #3764 of 4321 (permalink) Old 05-19-2016, 12:44 AM
Date registered: Oct 2015
Vehicle: 1998 SL500 Sport
Quoted: 48 Post(s)
Oh bloody hell, washed the engine bay on my 320CE before consulting with internet and the result - it runs on 4-5 cylinders. I was careful with the pressure washer but bolts on coil cover are not threading, so 5 out 6 where loose and so was the cover. Not hard for the water to get in there. Yesterday pulled the plugs 4 times and suddenly it was ok, toke it for drive and after 8 miles, the problem was back. So the coils and wires are now at home drying. Hope that would fixed it
Alar is offline
post #3765 of 4321 (permalink) Old 05-19-2016, 11:01 AM
Date registered: Feb 2016
Vehicle: 1989 300CE
Quoted: 12 Post(s)
Changed the valve cover gasket. Very easy to do. Decided to do a video along the way.
https://youtu.be/9rnLc854924
speed9644 likes this.
awild is offline
post #3766 of 4321 (permalink) Old 05-19-2016, 11:19 AM
Quoted: 48 Post(s)
Luckily drying the coils inside did the job with contact cleaner. Went to a small local car meet to celebrate my luck
tjts1 and speed9644 like this.
Alar is offline
post #3767 of 4321 (permalink) Old 05-19-2016, 07:12 PM
Date registered: Sep 2015
Vehicle: 1994 E320
Quoted: 83 Post(s)
With the help of a friend, we swapped out the rear hatch struts. It really wasn't that bad of a job using the various writeups and the help of a friend. Dropping the headliner trim is probably the worst part.
No more heavy tailgate dropping on my head or back.
E320Project is offline
post #3768 of 4321 (permalink) Old 05-20-2016, 03:08 AM
gatorblue92's Avatar
Vehicle: 1977 W123.123 1993 W124.034
Quoted: 407 Post(s)
Thankfully that job was done on my wagon just before I bought it. Even after three years it will still nearly kick you in the face when you open the hatch.
gatorblue92 is offline
post #3769 of 4321 (permalink) Old 05-20-2016, 10:39 AM
Date registered: Apr 2016
Vehicle: 1989 300E 1989 420SEL
Quoted: 6 Post(s)
It was 2 days ago actually, but I pulled the injectors, tested them using Mercedessource kit, cleaned them and found 4/6 to be good to reuse.
Ordered up the 2 new ones, plus the plastic seats, and the o rings, and the rubber seals.
Looking forward to seeing how it runs afterwards, as they basilly fell out, and #1 was very bad where the whole platic holder just fell out with it.
Actually #1 -3 just fell out with the plastic holders. #4 is a pain to get out, screwing all day with a 90 degree allen head, crows foot no good there.
Hoping this cures my rough running engine - compression is good, plugs/wires/cap/rotor/coil I just replaced. Motor mnts replaced. It doesnt smoke.
black_adder is offline
post #3770 of 4321 (permalink) Old 05-20-2016, 03:31 PM
Quoted: 407 Post(s)
Drove mine to work the past two days. I'm beginning to suspect I may have a vacuum leak somewhere since the engine seems to be idling higher lately when I come to a red light.
W124 Front Suspension - 124.128 vs. 124.09 jscottallen W124 E,CE,D,TD Class 2 09-24-2009 03:58 AM
94 E320 (124.032) ~ 89 300e 124.030 jephey W124 E,CE,D,TD Class 3 05-29-2007 09:53 PM
OT: Today is a special day!! Today smog checks in the bay area starts @ $130 a pop!!! Man-Du-Ru-Gas W163 M-Class 4 08-13-2005 03:58 PM
OT: Saw a white SL55 AMG today on 635-75 today Tangent R170 SLK-Class 5 07-11-2003 08:17 AM
Hoping to see more first hand 32 reviews today. I think a couple of people are taking delivery today SteveL R170 SLK-Class 13 07-29-2001 10:13 AM
