I reset my trip meter and now the odo stopped working! - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-04-2007, 09:35 PM Thread Starter
Date registered: Jul 2007
So, I reset the trip meter on the 300te and I noticed a day later, it and the odometer both stopped working... Speedo still works and I messed with the little reset button, but nothing.
Any advice?
vr6freak is offline
post #2 of 5 (permalink) Old 10-04-2007, 10:31 PM
drin's Avatar
Vehicle: W124 89' 260E
Happened to my w124 260e a few months back.. did the same thing, pushed the reset button and the odometer stopped working for a day.. noticed though that the counter some what got mis aligned and clicks when running..
What i did was take out the panel and dis assembled it.. inside i saw that the gear connected to the counter had slipped from its place and is not in contact with the other gear at the bottom portion. pushed it in back in place and now its working fine..
Try it, might be the same fix for your problem..
drin is offline
post #3 of 5 (permalink) Old 10-05-2007, 07:52 PM
Moderately subtle
edfreeman's Avatar
Date registered: Dec 2003
Vehicle: 94 E500, 97 500SL
Quoted: 175 Post(s)
Send a message via AIM to edfreeman
There's a few threads in here about hitting the reset button while the vehicle is moving will sometimes get the gears out of line or even strip them. I've had it happen briefly on my 190 when I didn't push the reset button firmly while stopped. Only a couple times, but pressing it firmly again got it to work.
edfreeman is offline
post #4 of 5 (permalink) Old 10-05-2007, 08:53 PM
LTYLER's Avatar
Vehicle: 04 E320 4M Wagon, 90 560SEC, 14 VW Sportwagen TDI
Quoted: 153 Post(s)
If the ODO still clicks then just try pushing the reset switch in all the way a couple times. this worked on mine, better than removing the whole thing all together, best of luck
LTYLER is offline
post #5 of 5 (permalink) Old 10-06-2007, 09:07 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
How odd. This is the first Benz quirk I've seen that has a dead-on GM counterpart. I used to have a Z-28 and it regularly (though infrequently) did this.
The fix was the same as the one suggested by lee and ed.
Take care and enjoy the ride,
Greg
Check Codes is offline
Odometer & Trip Meter Not Working dbmoylan W140 S-Class 3 12-24-2006 03:45 AM
what is 32 / 13 2 on odo when trying to reset FSS ? Kirill R170 SLK-Class 3 05-02-2006 11:12 AM
trip meter stopped working help me? drebdy W140 S-Class 0 02-09-2006 09:26 AM
Odometer/trip odometer stopped working theratpatrol R/C107 SL/SLC Class 8 07-23-2005 08:12 PM
trip meter stopped what could be the cause? drebdy W140 S-Class 0 05-15-2005 08:33 AM
