300D engine cuts after turning over. - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-15-2019, 04:15 PM Thread Starter
Date registered: May 2019
Vehicle: 1982 300d
Ok, so bear with me, a bit of background- also I'm new here, usually on Peachparts, so hello!
I was trying to do a long distance drive a few weeks ago when I stopped to fuel up.When I put the key back in the ignition the starter tried to crank before I even got the key to position two.I took it out and tried it again and small puffs of smoke came out of the keyhole.
On my second attempt to turn it over the starter engaged at terminal speeds, incredibly high pitched screaming.Key was out of the ignition but it wouldn't stop wouldn't stop until I yanked a battery terminal loose.
Replaced the ignition switch that had shorted all, Replace the starter and its very melted solenoid. But there's a new problem
When I go to start the car the ignition behaves normally, the starter cranks and the engine turns over, and then it immediately cuts out. I've tried giving it a little tap on the accelerator, I checked out the STOP lever and its not stuck or anything unusual. Checked the fuel lines after trying to start and diesel is getting to the injectors so I'm ruling out lift pump.
Also checked to make sure the vacuum lines to the ignition aren't switched, and those are good.
It's getting plenty of fuel, so I think that rules out the shutoff switch?
Here's a video of starting it as it is, and again with the vacuum unplugged.
https://photos.google.com/search/_tr...hVuIopPno1fRTN
Does anyone have any suggestions? I've never had an issue like this with my 4+ 300s.
Thanks very much,
LBJ
lbj.lbj is offline
post #2 of 5 (permalink) Old 05-15-2019, 06:15 PM
Gregs300CD's Avatar
Date registered: May 2005
Vehicle: 1982 300CD
Quoted: 20 Post(s)
Well, the engine isn't stopping because of anything electrical. What happens if you remove the vacuum from the shut-off at the IP?
christuna likes this.
Gregs300CD is offline
post #3 of 5 (permalink) Old 05-16-2019, 02:03 PM
kevdupuis's Avatar
Date registered: May 2016
Vehicle: 1985 300 TD 1981 300 SD
Quoted: 37 Post(s)
My thought is that the 2 vacuum lines at the ignition switch may have gotten switched and as soon as the engine starts vacuum is applied to the shut off shutting down the engine ( if that is a possibility), or he may have left a piece out when he changed the ignition switch and the vacuum switch is now stuck allowing vacuum to the shut off full time.
kevdupuis is offline
post #4 of 5 (permalink) Old 05-17-2019, 04:15 PM Thread Starter
Vehicle: 1982 300d
My first thought was that the vacuum lines from the ignition were switched too, but not the case.
so here's what i've tried
Disconnected vac at the injection pump, starts no problem, plug it back in, car shuts off.
Disconnected brown ignition line that goes through the firewall at the Y connector, plugged off the y, starts right up, plug line BACK in, continues running but key will not shut it off.
disconnect both vacuum lines at the ignition, starts up, runs, drives, if i press them together to close the vacuum (please see lovely illustration), car shuts off. (well, it was, but after driving for an hour and a half and car got hot it didnt shut it off, but engine slowed, had to use cut off switch under hood)
So, the starter switch was replaced, not the whole assembly. I'm thinking that whatever part is in there that separates the vacuum in and vacuum out got blown up with the original incident happened ( smoke coming out of the ignition)
This seems reasonable yes? But why wouldn't the two vacuum lines pressed together fail to shut the car off when hot?
lbj.lbj is offline
post #5 of 5 (permalink) Old 05-17-2019, 04:19 PM Thread Starter
Vehicle: 1982 300d
I was just going to get a new ignition assembly, but now since it wouldn't shut off hot, I'm doubting. How can i check my existing vacuum switch to see if thats the issue?
lbj.lbj is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
W220 S430, S500 And S55 Engine removal W/O 4MATIC SChalmers W220 S-Class 50 08-17-2018 07:39 AM
E 320,straight 6, versus V6 engine Viriato W210 E-Class 24 03-04-2018 06:19 PM
Replacing your 404 engine with a new crate engine! Tips! Monstermog1964 Unimog 3 08-21-2009 08:47 PM
Wanted Mechanic + Engine 300D wer1 For Sale/Wanted/Trade/Giveaway 4 06-14-2006 11:27 AM
Long sucess history Zé Bocaina G-Class 3 05-27-2005 01:19 PM
