w123 Door Striker - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-10-2019, 10:08 AM Thread Starter
Date registered: Feb 2009
Vehicle: 1983 300TD
w123 Door Striker
I replaced the striker but I can't find any procedure to make the adjustment. It can't be just trial and error, does anyone know?
Tyler99 is offline
post #2 of 6 (permalink) Old 05-10-2019, 06:01 PM
Gregs300CD's Avatar
Date registered: May 2005
Vehicle: 1982 300CD
Quoted: 20 Post(s)
On my coupe, I put some masking tape over the hole, then see where the point makes a dent.
Gregs300CD is offline
post #3 of 6 (permalink) Old 05-15-2019, 03:31 PM
Supporting Vendor
AutohausAZ's Avatar
Date registered: Dec 2004
Vehicle: Too Many to List
Quoted: 31 Post(s)
Using masking tape is a good tip! If anyone else is about to replace their Door Lock Strikers 123 720 0104 and 123 720 0204, we have them available: https://www.autohausaz.com/catalog/c...ker?s=d&page=1
Visit the AutohausAZ Vendor Section for special pricing for Benzworld members:
AutohausAZ is offline
post #4 of 6 (permalink) Old 05-18-2019, 11:39 AM
sd300td's Avatar
Date registered: Dec 2008
Quoted: 12 Post(s)
I masked all around the old strike before removing it. Put the new one on using the tape as a guide.
Tighten up the bolts hand tight; loose enough so that the strike can move ever so slightly when the door is closed gently. It should settle in a good spot for perfect closing. Fully tighten the bolts when you get it to where you want it.
Sent from my Pixel using Tapatalk
2005 230 K, 26k-77k (sold)
1982 300 TD, 167k-226k
1982 240 D, 308k-327k (sold)
1998 E 320, 120K-141K
sd300td is offline
post #5 of 6 (permalink) Old 05-22-2019, 06:42 PM
Premium Member
roncor's Avatar
Date registered: Jan 2005
Vehicle: 2002 CLK 430 Convt. '91 420 SEL, '80 240D, '93 190E Sportline, '70 300 SEL 6.3
Quoted: 45 Post(s)
Premium Member
My tip: I found a way of marking the striker where it enters the hole:
Gently apply a light color masking tape over the hole, use a magic marker and go over the striker point, then VERY gently close the door until you feel it barely touching - but not breaking the tape. It will leave a dot.
Now you have an idea where the striker goes in, so you can adjust up/down left/right accordingly
But, I do carefully outline the unit top and side before hand. Then, the fine tuning begins. You might shut the door 20 or 30 times! Did I mention that the depth is important! yeah, thus the reason for shims.
Gently secure the bolts to loosen again....and again..until Voila it is perfect!.
Roncor
'80 240D, '87 560SL, '93 190E Sportline, '91 420SEL, '70 300SEL 6.3
roncor is offline
post #6 of 6 (permalink) Old 05-22-2019, 07:16 PM
Smorrow's Avatar
Date registered: Sep 2015
Vehicle: 1982 300d four speed turbo & 1984 300d four speed N/A euro
Quoted: 56 Post(s)
That is a good idea, I'll have to try it with my '84 soon as the passenger door doesn't close nearly as nice as the driver's side. Perhaps lipstick would work better than a marker? I'll give it a shot soon
Smorrow is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Looking to Install w123 Headlight Wiper Motors & Arms, Have Pic & Questions Sevag W123 E,CE,D,CD,TD,TE Class 3 10-27-2012 08:34 PM
FS: W123 euro interior, W126 foot rests,... Scoot For Sale/Wanted/Trade/Giveaway 0 03-11-2012 04:35 PM
FS: W123 and W116 Parts, incl. Euro lights and front bumper, LA area holthoff For Sale/Wanted/Trade/Giveaway 28 04-27-2010 06:04 PM
Production #s on W123 Turbo Diesel wagons.... sray_Atl W123 E,CE,D,CD,TD,TE Class 3 02-21-2006 07:57 PM
W123 "variants" MBeige W123 E,CE,D,CD,TD,TE Class 3 07-06-2004 07:05 PM
