*Help* M110 280e Engine - Page 6 - Mercedes-Benz Forum
post #51 of 62 (permalink) Old 02-17-2019, 09:16 PM Thread Starter
Irfaan_ZA's Avatar
Date registered: Mar 2015
Vehicle: 1983 W123 280e
Quoted: 10 Post(s)
Back at it again
Picked up the car from my mech.
He removed the Fuel Pump relay, did some cleaning and soldering and it now seems 100%
Took the car for a very long 60km drive , partially spirited at high speeds to make the motor get quite hot. Stopped at my 1st end point , and tried to start. It starts immediately. Drove home from there, did the same test.
Im praying its sorted, it really does look it is sorted out now.
Another thing is that after the Radiator flush, the temperature stays around 90 Degrees at most, where previously it had risen to around the 100 degree marker
Irfaan_ZA is offline
post #52 of 62 (permalink) Old 02-19-2019, 03:09 PM
Premium Member
Dr.Grillz's Avatar
Vehicle: Mercedes
Quoted: 277 Post(s)
Happy to hear that your car appears to be sorted out and you're enjoying it!
1980 Mercedes 280TE AMG
1990 Mercedes 560SEL with AMG parts modifications
1991 Mercedes 190E AMG with Brabus 4-cyl M102 2.6
Dr.Grillz is offline
post #53 of 62 (permalink) Old 02-19-2019, 09:09 PM Thread Starter
Irfaan_ZA's Avatar
Quoted: 10 Post(s)
Thank Dr.
I've been using it daily with no issue. Man I missed this car! It's thirsty as hell but its worth the feeling I get when driving it
post #54 of 62 (permalink) Old 02-19-2019, 10:42 PM
Aquaholic
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: '81 280E turbo M119 project, 85 Audi Coupe Quattro, 71 BMW turbo 2002, '73 BMW 2002tii +others
Quoted: 22 Post(s)
Think of it as smiles per gallon.
Nutz 4 Benz is offline
post #55 of 62 (permalink) Old 02-25-2019, 02:55 AM Thread Starter
Irfaan_ZA's Avatar
Quoted: 10 Post(s)
And it's all systems go.
After sorting out the fuel pump relay it starts every time.
PlaneCrazy likes this.
post #56 of 62 (permalink) Old 02-25-2019, 03:14 AM
PlaneCrazy's Avatar
Date registered: Oct 2010
Vehicle: '86 W123 200, OM617 non-turbo, bastard 5-speed; '95 W202 C250 Diesel, OM605 non-turbo, 5-spd man
Quoted: 492 Post(s)
I'm happy for you. It's always the little things.
W202 C250 Diesel, OM605 NA engine, 5-speed manual
1986 200, OM617 NA engine, 5-speed manual, rev counter
Donkey, not gone, never forgotten...
PlaneCrazy - it's more than a name, it's a life choice!
QUOTES FROM CONSTERNATIUS:
"Inside every small problem is a big problem screaming to get out."
PlaneCrazy is offline
post #57 of 62 (permalink) Old 03-10-2019, 10:50 PM Thread Starter
Irfaan_ZA's Avatar
Quoted: 10 Post(s)
And we back to square one
It happened again! I have no idea now what to do. It's going back to the mechanic this evening.
post #58 of 62 (permalink) Old 03-10-2019, 11:05 PM
Date registered: Nov 2008
Vehicle: 1995 MB 600SL, !982 G-Wagen 280GE, BMW 1150RT
Sorry to hear, have you figured out if it is fuel or spark, mine turned out to be the coil, it showed no symptoms but replaced with the correct blue high voltage Bosch coil from Diesel-Electrick and I am surprised with the allround better behavior of the engine.
Rudi Raaths is offline
post #59 of 62 (permalink) Old 03-10-2019, 11:18 PM Thread Starter
Irfaan_ZA's Avatar
Quoted: 10 Post(s)
Hey Rudi,
Not sure as yet, i had 0 tools or multimeter or anything. And being on the side of the N1 alone I couldn't even hear if the Fuel pump buzzed.
So fokkit, Im replacing the coil, fuel pump relay and fuel pump now. Im gatvol so just gonna do this and see.
post #60 of 62 (permalink) Old 03-13-2019, 05:01 AM
VON
VON's Avatar
Date registered: Apr 2004
Vehicle: 1973 416 Doka, 1978 416 Doka, 1980 416 Doka..... Help me, I can't stop buying them!!!
Quoted: 182 Post(s)
This is why when I got my 280CE with a seized motor, I put in a turbo diesel instead of rebuilding the M110. With the car sitting 25 years not running, I didn't want the headaches and cost of the M110. The turbo diesel with a 5 speed is a joy to drive and starts every time. If you were in the US I would have every part you are looking for from the two 280CE's I have the parts off of.
Irfaan_ZA likes this.
Von
Fairport, NY
1973 Unimog 416 Doka
1980 Unimog 416 Doka
1984 Euro 280CE w/diesel conversion
1985 300TD Estate wagon
(I really need to stop buying these things!)
VON is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
