New or rebuilt injectors for a OM617? - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 08-20-2018, 11:59 AM Thread Starter
luisg92's Avatar
Date registered: Sep 2016
Vehicle: 1982 300D Turbodiesel (US Spec)
Quoted: 20 Post(s)
I tried to do some research about the pros and cons of replacing the injectors with new ones vs rebuilding the old ones, but I didn’t find much information about it.
In terms of price, it seems cheaper to me buying the new ones rather than paying an injection shop to rebuild the current ones, but I am not sure about the quality of new injectors because some claim they are made in India and quality is not consistent (although no one shows proof of that).
So, what do you think about new injectors, are they any good? Or is it better to get the ones that I have rebuilt even if that cost more?
luisg92 is offline
post #2 of 10 (permalink) Old 08-21-2018, 12:33 AM
PlaneCrazy's Avatar
Date registered: Oct 2010
Vehicle: '86 W123 200, OM617 non-turbo, bastard 5-speed; '95 W202 C250 Diesel, OM605 non-turbo, 5-spd man
Quoted: 495 Post(s)
I would buy new injectors. Yes, the new stuff aren't as rugged as the originals, but I have made peace with having to potentially replace nozzles more often. However, I had injectors rebuilt at a Bosch centre, and they were never the same - more than one were cracked after being repaired, one wouldn't stop bending its plunger etc.
These injector bodies do get old eventually.
luisg92 likes this.
W202 C250 Diesel, OM605 NA engine, 5-speed manual
1986 200, OM617 NA engine, 5-speed manual, rev counter
Donkey, not gone, never forgotten...
PlaneCrazy - it's more than a name, it's a life choice!
QUOTES FROM CONSTERNATIUS:
"Inside every small problem is a big problem screaming to get out."
PlaneCrazy is offline
post #3 of 10 (permalink) Old 08-23-2018, 12:29 AM
~PERMA BANNED~
Date registered: Mar 2006
Vehicle: 1982 300D
Quoted: 152 Post(s)
Injector bodies are not wear items. Over-heating and over-torquing (of the body or tube nut) are the main causes of damage.
I would trust reman injectors over any new ones, because they have skilled eyes testing them instead of a factory machine.
Everything made in India is garbage quality. Materials are expensive, labor is the cheap resource there.
Mahindra and Royal Enfield are good examples, everyone says they are overbuilt. Because they have to be to compensate for the low quality materials and poor craftsmanship. I know this first hand.
luisg92 likes this.
Forcedinduction is offline
post #4 of 10 (permalink) Old 08-23-2018, 09:46 PM
jh84300d's Avatar
Date registered: Oct 2017
Vehicle: 1984 300d
Quoted: 8 Post(s)
I just bought and installed “new rebuilt injectors”. I bought them on eBay from “parts container”. Who is the seller....so this didn’t fix my problem, but... when my car is running good, it runs better. When it’s running rough, it is still the same/ rough... I’m starting a new thread in a minute or two about my next choices on how to fix it, but....they are easy to install, and I had new braided fuel return hose to put on anyways. Good luck.
luisg92 likes this.
jh84300d is offline
post #5 of 10 (permalink) Old 08-24-2018, 08:59 PM Thread Starter
luisg92's Avatar
Quoted: 20 Post(s)
That is the reason I will replace my injectors (after testing them of course); the car has a nasty occasional shake at idle that doesn’t manifest when is running on diesel purge. Some people suggest that's an indicator the injectors could be clogged. There is also a bit of grey/pale blue smoke despite the fact that doesn’t burn oil nor coolant.
That is what I fear. They could have been rebuild at some point in the past and perhaps were over tightened. I don’t know and won’t know until they are rebuilt. A number of items in my car were over tightened by the previous shop that repaired and maintained the car.
In case of getting new ones, I would have them tested for both, spray pattern and pop pressure cause one never knows. It seems that one has to take extra precautions when replacing something these days. Quality is so inconsistent; some things are so well made while others are worthy of shame.
luisg92 is offline
post #6 of 10 (permalink) Old 08-25-2018, 09:17 AM
jh84300d's Avatar
Vehicle: 1984 300d
Quoted: 8 Post(s)
I have the same symptoms with my car. It didn’t resolve with the replacement injectors. I will be ordering a new fuel pump today, and when it comes in I’ll also clean out the strainer and maybe the tank as well. Might as well limit my exposure to diesel to one weekend. Good luck.
jh84300d is offline
post #7 of 10 (permalink) Old 08-25-2018, 04:27 PM
~PERMA BANNED~
Vehicle: 1982 300D
Quoted: 152 Post(s)
Symptoms of retarded injection timing.
post #8 of 10 (permalink) Old 08-25-2018, 05:32 PM Thread Starter
luisg92's Avatar
Quoted: 20 Post(s)
Thanks for the input. That’s something that I will have to pay someone to check because I don’t know much about the injection timing. I guess is time to do some research.
luisg92 is offline
post #9 of 10 (permalink) Old 08-26-2018, 10:39 PM
jh84300d's Avatar
Vehicle: 1984 300d
Quoted: 8 Post(s)
What controls the injection timing? Is it controlled( advanced/ retarded) with the vacuum system, or is it a mechanical adjustment? I’m not in the “know” yet with this motor or system....and why would it be variable if it were a mechanical issue that requires adjustment? I was hoping mine was an injector that was sticking..
jh84300d is offline
post #10 of 10 (permalink) Old 08-26-2018, 10:55 PM
PlaneCrazy's Avatar
Quoted: 495 Post(s)
The timing is controlled by the throttle and the governor. The pump reference is done by rotating the fuel pump towards or away from the engine. According to MB specs, the injection pump timing should be adjusted to 15°ATDC at idle, or 24°BTDC at full-throttle, depending on the fuel pump and method you use.
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
