Transmission sound question - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 11-11-2017, 11:21 PM Thread Starter
AlecsNYC's Avatar
Date registered: Jan 2017
Vehicle: 1984 Mercedes-Benz 300D Turbo Diesel
Quoted: 25 Post(s)
Hi guys, it surely been a while since I read and posted on this forum. I've been awfully busy. But now I may have a problem, and where else would I go to seek answers?
So my automatic transmission on 1984 300d turbodiesel was shifting really rough for a while especially when I was gunning it. I just changed ATF fluid and filter and shifting became much, MUCH smoother. At the same time I am concerned now because I started hearing this faint whining noise when I shift from D to P or from D to N or from R to N. Not sure what this is, but I don't like it. Any ideas? I used Bosch filter and Super Tech Dexron III/Mercon ATF fluid from Walmart. I was unhappy to use this ATF but the store was fresh out of Valvoline ATF that I wanted to buy.
Thanks everybody for your suggestions!
AlecsNYC is offline
post #2 of 8 (permalink) Old 11-12-2017, 01:50 PM
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: '81 280E turbo M119 project, ‘85 Audi Coupe Quattro, ‘71 BMW turbo 2002, '73 BMW 2002tii +others
Quoted: 22 Post(s)
Whining comes from the clutch/friction pack 9/10 times.
Did you drain torque converter?
AlecsNYC likes this.
Nutz 4 Benz is offline
post #3 of 8 (permalink) Old 11-12-2017, 02:01 PM Thread Starter
AlecsNYC's Avatar
Quoted: 25 Post(s)
Hi Nutz 4 Benz,
yes, I did drain torque converter. Amount of oil that went in was about the same that came out. I used oil changing procedure from MB service manual.
It this a bad thing that "Whining comes from the clutch/friction pack 9/10 times?" What are the implications? Thanks
AlecsNYC is offline
post #4 of 8 (permalink) Old 11-12-2017, 02:02 PM Thread Starter
AlecsNYC's Avatar
Quoted: 25 Post(s)
Hi Nutz 4 Benz,
AlecsNYC is offline
post #5 of 8 (permalink) Old 11-12-2017, 04:53 PM
luisg92's Avatar
Date registered: Sep 2016
Vehicle: 1982 300D Turbodiesel (US Spec)
Quoted: 20 Post(s)
Mine does a funny noise evert time I shift to N. At the same time, the rear end lifts a bit. I am sure the noise comes from the gearbox. Has been doing that since I got it and never felt concerned. Changing the fluid didn’t change the noise.
Now that you mention the issue on yours, I feel curious about the cause.
luisg92 is offline
post #6 of 8 (permalink) Old 11-12-2017, 08:02 PM Thread Starter
AlecsNYC's Avatar
Quoted: 25 Post(s)
My limited experience tells me if any new automotive noise stays the same it's OK if it gets louder over time its BAD
AlecsNYC is offline
post #7 of 8 (permalink) Old 11-14-2017, 12:18 AM
Date registered: Nov 2010
Vehicle: 1985 300D Gone 1985 230CE Perfect, 1984 300TD Driver, 1981 300TD Bad engine
Quoted: 80 Post(s)
Mine has done the same thing for years. I don't even notice it any more.
Commuter is offline
post #8 of 8 (permalink) Old 11-16-2017, 07:59 PM
~PERMA BANNED~
Date registered: Mar 2006
Vehicle: 1982 300D
Quoted: 152 Post(s)
The noise is normal. It is the clutch packs and bearings changing speed as internals start/stop moving.
When in D/S/L the transmission should be quiet as the only moving parts are the torque converter impeller and pump.
Forcedinduction is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
