LCA Bushings??? - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 11-03-2017, 08:54 PM Thread Starter
Date registered: Jul 2008
Vehicle: 78/82 300D
Quoted: 420 Post(s)
LCA Bushings???
I have an issue, and it is upsetting me! Just lost a tire
I've replaced the upper control arms and all associated bushing oh say three years ago...and all tie rods/drag but the idler arm about seven years ago..lower ball joint boots aren't tore and no noise from the bearing...
I can't figure out what caused this wear? The outside edge has wear but I think because of the sever inner wear the outside is just going along? The only thing I can think is LCA?? I want to say it happened in a few weeks too...
I grab the tire and nothing moves behind, the tire is a bit lose grabbed at say 3 n 9 but I think its normal movement?
Any thoughts before I tear into the LCA? I was waiting to tackle those until I got a compressor and could do it all in one shot buutttt as you can see
"Take me to church"
cooljjay is offline
post #2 of 15 (permalink) Old 11-03-2017, 09:59 PM
260e crusier's Avatar
Date registered: Nov 2010
Vehicle: 1999 E320, 2003 E320 Wagon, 2005 C230K SS, 2010 Accord LX w Eibach & Koni FSD's
Quoted: 492 Post(s)
Did you check your alignment? Excessive toe out will cause RAPID inner tire wear. Under inflation of tires can cause both edges to wear out faster.
260e crusier is offline
post #3 of 15 (permalink) Old 11-04-2017, 09:47 AM Thread Starter
Vehicle: 78/82 300D
Quoted: 420 Post(s)
Nope I didn't...
This happened fast! I just changed my coolant last weekend and there wasn't any issues plus I rotated the tires 5k ago...also just filled all the tires to possible two weeks ago...
I drive the car 100 miles a day sometimes 5 days a week, so I am always inspecting crap so I don't get stranded. The LCA bushings are rotted and original too...hints my conclusion...
Not easy to get an alignment out here in the sticks on a Mercedes....never had an issue till I moved out here...
"Take me to church"
cooljjay is offline
post #4 of 15 (permalink) Old 11-04-2017, 04:37 PM
Noah Way's Avatar
Date registered: Nov 2012
Vehicle: 1981 280E, 1995 E320 Wagon
Quoted: 170 Post(s)
Could be a loose steering box. Makes it impossible to align.
Wherever you go, there you are.
Noah Way is offline
post #5 of 15 (permalink) Old 11-04-2017, 07:33 PM
Quoted: 492 Post(s)
You should have the alignment check and see if things are within spec. Any shop should be able to adjust the toe if necessary.
As mentioned, excessive toe out can cause very rapid tire wear on the inside of the tire.
post #6 of 15 (permalink) Old 11-04-2017, 07:59 PM Thread Starter
Vehicle: 78/82 300D
Quoted: 420 Post(s)
I was wondering that, but wouldn't that cause wear to both tires? The passenger is still perfect...
"Take me to church"
cooljjay is offline
post #7 of 15 (permalink) Old 11-04-2017, 08:00 PM
luisg92's Avatar
Date registered: Sep 2016
Vehicle: 1982 300D Turbodiesel (US Spec)
Quoted: 20 Post(s)
What is the brand of the replacement parts you used ? How many miles have you driven after replacing them? Have you hit a pothole recently?
Some aftermarket parts donít last as long the originals and 7 years is a long time for most suspension components. Sometimes you can have a bad tie rod and not notice it while driving.
They can be worn out even if they have grease inside. Have you tried to use a pry bar to see if there is vertical play on the ball joints?
luisg92 is offline
post #8 of 15 (permalink) Old 11-04-2017, 08:02 PM Thread Starter
Vehicle: 78/82 300D
Quoted: 420 Post(s)
Yeah I have a shop that did an alignment in the next town over on the 78 when no one else would....I figured Monday I will stop in and say "hey you guys have seen more worn tires then me, whats your opinion?"
What is just odd, is the wear is only to half the tire on the inner....just strange....
"Take me to church"
cooljjay is offline
post #9 of 15 (permalink) Old 11-04-2017, 08:25 PM
kevdupuis's Avatar
Date registered: May 2016
Vehicle: 1985 300 TD 1981 300 SD
Quoted: 37 Post(s)
From what i see there is a bit of an under inflation issue but the looking at the inside of the tread you cab see a pattern where the excess wear starts part way around the circumference of the tire and gets heaviest at the patch where the cords are poking out, it tells me your tire is out of round, possibly a belt starting to let go which can be caused by running tires under inflated or hitting a pothole.
Now this is just my thoughts and not necessarily fact in this case but the very heavy wear spot is an indicator.
kevdupuis is online now
post #10 of 15 (permalink) Old 11-04-2017, 08:42 PM Thread Starter
Vehicle: 78/82 300D
Quoted: 420 Post(s)
The UCA's were lemforder....hmm can't even say how many miles, they were put on two years ago last month..the tie rods were URO, yeah I know horrible! But these were bought years n years ago before the URO we know now..drag link wasn't though...No pot holes that I can think of, usually stay clear of that stuff...there was a horrible large sped bump type patch put on the highway that I couldn't avoid a lot of times...
God I know! Its horrible, even if you buy genuine, it won't last
Yeah I was talking to a neighbor who was telling me his looked fine too. I will go try the pry bar trick, was going to read on how to check them...
"Take me to church"
cooljjay is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
