Need help choosing A/C compressor - Page 2 - Mercedes-Benz Forum
post #11 of 20 (permalink) Old 06-03-2017, 09:59 AM Thread Starter
AlecsNYC's Avatar
Date registered: Jan 2017
Vehicle: 1984 Mercedes-Benz 300D Turbo Diesel
Quoted: 25 Post(s)
Oh no, parts not included, labor only. Here's quote from another shop. Compressor replacement job 3.5 hours, drier replacement job 1 hour = 4.5 hours + $95 for R12 + $65 for recharging = $640. I decided to replace parts myself and take my Benz to the shop for leak test, evacuating and recharging.
Randy Bishop likes this.
AlecsNYC is offline
post #12 of 20 (permalink) Old 06-03-2017, 10:01 AM
LWB250's Avatar
Date registered: Jan 2013
Vehicle: 65 220SEb, 97 SL500, 98 E320 Wagon, 2002 ML500 - former W108/W112/W114/W123/W124/W126/W140/W220
Quoted: 1052 Post(s)
Unless you're not confident of your abilities, you could easily spend under $200 at Harbor Freight and buy a manifold gauge set and a vacuum pump. With these two items you'll be able to do your own AC work for the most part.
Dan
LWB250 is offline
post #13 of 20 (permalink) Old 06-04-2017, 06:45 AM Thread Starter
AlecsNYC's Avatar
Quoted: 25 Post(s)
Hi Dan. I am pretty confident I can do all the work myself including recharging AC, but main problem, with me being an urban DIYer, is a storage space for all the tools and gadgets needed to repair my Benz. Storage unit is far from me and my wife wouldn't let me turn our apartment into garage LOL. So I decided to outsource some of the jobs
AlecsNYC is offline
post #14 of 20 (permalink) Old 06-04-2017, 06:49 AM
LWB250's Avatar
Understood. Just thought I would toss it out there.
I bought all of my AC stuff when I moved to Florida, and it's saved me a bundle of money over time. I can get R134a on eBay and elsewhere for $4-$6/can, so it's easy and cheap to do my own work, thank goodness...
Dan
LWB250 is offline
post #15 of 20 (permalink) Old 06-04-2017, 07:16 AM Thread Starter
AlecsNYC's Avatar
Quoted: 25 Post(s)
Now let me ask you few more questions then.
How do you like R134a? Here in New York City in the summer we are usually at 90-98 degrees + all the heat from the bumper-to-bumper city traffic. Do you think R134a would be sufficient to cool interior down enough?
How often do you need to charge your system with R134a? I've read somewhere when you are converting from R12 to R134a you will need to replace all the hoses and o-rings. It it true?
My plan was/is to install new delco style a/c compressor, drier, expansion valve and install BG Frigi-Quiet II oil in it and then take it to the shop to evacuate, leak test and charge the system with R12.
I also may have a problem with compressor piping. Rubber hose going from compressor to the hose connected to condenser looks bulging at the ends and also feels soft (see the red arrows in the picture). I think I may have to replace it, but I can't find any reference to it. Any ideas where I may be able to source this pipe/hose?
Cheers! Have a great Sunday!
AlecsNYC is offline
post #16 of 20 (permalink) Old 06-04-2017, 08:00 AM
LWB250's Avatar
In a system designed for R12 in your climate or mine (which is cooler than yours, believe it or not) R134a may not perform well for you. It depends on a lot of variables. For the most part, converted R12 systems aren't adequate for "ICE COLD AIR" with R134a because the R12 system, primarily the condenser, are not adequate for R134a. You can change out your condenser to a multipass model to increase efficiency at a cost of about $300 for the condenser.
I am a believer in keeping the system R12 whenever possible. You have some alternatives to that as well through the use of "alternative refrigerants", which is a catchphrase for blended isobutane (propane) that is perfectly suitable for an R12 system. It's cheap and does not harm the environment like R12 does. However, most if not all commercial AC people won't touch the stuff for liability reasons - not because there's a risk of fire or explosion (highly unlikely) but because it's not an approved EPA refrigerant. If you'r still worried about it, understand that it's commonly used as an approved automotive refrigerant in a number of first world countries such as Australia. Our EPA just doesn't like it.
I have used both in my climate, and while the alternative refrigerant does work well, because it's a blend over time if you have leaks, even small ones, the ratio of gasses change as some are more prone to leaking than others due to their molecular size. When this occurs the efficiency of the refrigerant changes because the ratio of gasses is different. You can't just recharge, as you're putting the proper ratio refrigerant into an environment where the ratios are off - you have to evacuate and recharge. Granted, the stuff is about $4/can, so it fairly cheap to do so.
With R134a in a converted R12 system I get 45F vent temperatures at driving speeds. However, when I come to a stop and the compressor speed slows the inefficiency of the condenser comes into play and vent temperatures might rise to 70F. Not a big deal, but definitely noticeable.
If I went through a system and replaced hoses and O rings I would keep it R12. Understand that the hoses on our cars are not what is used today, i.e., "barrier" hoses that prevent refrigerant from leaking out at the molecular level. I can charge a system properly that has no leaks and in a year or so of operation it will need to be topped off. There are no leaks, per se, this is due to refrigerant leaking through the hose medium at a molecular level over time. With newer style barrier hoses there is a physical barrier in the hose material that prevents this from happening.
You don't have to change hoses but it's to your advantage to do so. This is usually beyond the level of the typical conversion, however, as it entails a significant cost and labor to do. O-rings, yes. The R12 O-ring composition will not play nice with the oils used in R134a and they will break down. The green O-rings used today are compatible with both R12 and R134a, so use them and you're covered should you ever decide to convert.
Sounds like a plan, but be sure to put the receiver/dryer on last and make sure the system is closed at that point. Otherwise the desiccant in the receiver/dryer will be exhausted from absorbing moisture from the atmosphere.
Mercedes, or better yet, find an industrial hose supplier. They should be able to rebuild your existing hose using the fittings and installing new hose. This is usually far cheaper than buying a new hose.
Cheers! Have a great Sunday![/QUOTE]
You, too.
Dan
oldmako likes this.
LWB250 is offline
post #17 of 20 (permalink) Old 06-04-2017, 09:41 AM
VON
VON's Avatar
Date registered: Apr 2004
Vehicle: 1973 416 Doka, 1978 416 Doka, 1980 416 Doka..... Help me, I can't stop buying them!!!
Quoted: 184 Post(s)
I am changing both the 300TD and the 280CE that I am putting a diesel in over to R134a. If you shop around you can find the parts to do it very cheap. New condensers were only $48 each and that included shipping. Compressors are only $120 each new, again with shipping. And the rest of the stuff was about $400 for each car for what is needed to swap over. Most are getting temps around 38-43 at the vents with outside temps above 80.
oldmako likes this.
Von
Fairport, NY
1973 Unimog 416 Doka
1980 Unimog 416 Doka
1984 Euro 280CE w/diesel conversion
1985 300TD Estate wagon
(I really need to stop buying these things!)
VON is offline
post #18 of 20 (permalink) Old 12-06-2017, 08:39 PM
luisg92's Avatar
Date registered: Sep 2016
Vehicle: 1982 300D Turbodiesel (US Spec)
Quoted: 20 Post(s)
Ordered Four Seasons compressor, expansion valve and a drier. Next week planning to overhaul AC system. A number of tutorials online suggest to flush the system if old compressor seized potentially scattering metal bits all over the system. I will need to use compressed air to blow AC flush and debris out of the system, but the problem is I really don't have access to a repair shop compressed air. Is there an alternative method?
Where did you buy the compressor, expansion valve and drier?
luisg92 is offline
post #19 of 20 (permalink) Old 12-12-2017, 07:13 AM Thread Starter
AlecsNYC's Avatar
Quoted: 25 Post(s)
Hi luisg92
I bought everything on rockauto
FOUR SEASONS 58228 compressor (New) w/ Clutch; Includes 2 Pins and 2 Rubber Bushings
FOUR SEASONS 38602 expanson lab
FOUR SEASONS 33396 Filter Drier
You need to do your research. My compressor started chirping after two weeks. IDK what's the problem at this point. I durned A/C off for good and put it off until spring to figure out. I must've put too much oil in the system. Or maybe poorly cleaned the hoses.
At this point, I am considering to maybe retrofit my Benz with some modern A/C system.
Good luck
AlecsNYC is offline
post #20 of 20 (permalink) Old 12-12-2017, 05:39 PM
luisg92's Avatar
Quoted: 20 Post(s)
Hi luisg92
Good luck
Oh dear. Its sad to hear to had problems after all that work. Perhaps you still have some metal shavings on the lines from the seized compressor. They are very difficult to remove. Generally, you have to flush the system several times, even if it looks clean.
Back to the question. I have been doing some research to decide, whether replacing the R4 with another R4 (new, of course) or getting a sanden kit, which seems well made, has everything that is necessary to covert it without having to worry about fabricating bits and has a very reasonable price (considering the time and effort put into producing it).
However, due to money reasons, Ill have to go the the R4 way. I have to rebuild the front suspension also.
There are many places to buy that offer R4s, but not a whole lot of references. I saw that kit from RockAuto as well, and a few other on Ebay but, I wanted to know where you got your parts before buying.
Thanks for the information.
luisg92 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
