Replacing coupe seat-back lock vacuum elements - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 12-30-2016, 11:46 AM Thread Starter
Date registered: Jul 2015
Vehicle: 1979 300CD
Quoted: 2 Post(s)
Hello,
The vacuum elements in my passenger-side seat-back locking system will not hold vacuum. I've got a pair of new elements but I can't figure out how to remove the old ones. I've removed the two screws holding it to the seat frame, but how do I disconnect the element from the operating rod? I've attached the schematic for reference.
Thank you.
neuromancer is offline
post #2 of 7 (permalink) Old 12-31-2016, 07:58 PM
FratBoy's Avatar
Date registered: Jun 2006
Vehicle: 1980 280CE; 1982 300CD
Quoted: 32 Post(s)
IIRC, the operating rod stays with he element. Or at least take them both out together and then swap them. It's been a while...
FB
The Inventory:
Those Not so Lucky:
1982 300SD 205k with SBC 350 + TH350
1983 280E Euro 5 speed (parts only)
1980 280E Euro 4 speed 165k
1985 500SEC US (shmoove)
1982 300D US 4 speed
1978 300CD US
1979 300D US
FratBoy is offline
post #3 of 7 (permalink) Old 01-01-2017, 04:15 AM
LWB250's Avatar
Date registered: Jan 2013
Vehicle: 65 220SEb, 97 SL500, 98 E320 Wagon, 2002 ML500 - former W108/W112/W114/W123/W124/W126/W140/W220
Quoted: 1046 Post(s)
The rod attaches ether by threading into the socket on the vacuum actuator or by means of a clip that "wraps around" the rod at the actuator, such as what's used with the actuators in the central locking system.
I looked at the replacement part pictures and the rod is not included (as you found as well) so it must come off somehow.
I'm betting it screws into the actuator.
Dan
LWB250 is offline
post #4 of 7 (permalink) Old 02-04-2017, 03:50 PM Thread Starter
Vehicle: 1979 300CD
Quoted: 2 Post(s)
For posterity:
The rods are attached to the vacuum elements with small e-clips that clip into a machined notch in the rods. I was able to pry the old e-clips off with an eyeglass screwdriver. Attaching the new elements was trickier. I made a tool by cutting a notch into the tip of a wooden chopstick.I then put a new e-clip into the notch firmly and used the chopstick to get it into the (very-tight) housing.
post #5 of 7 (permalink) Old 02-04-2017, 04:55 PM
LWB250's Avatar
Interesting. I've had those apart myself but it's easily been 10-12 years. I don't recall E clips, but then again, my memory's not what it used to be, either....
Thanks for the follow up!
Dan
LWB250 is offline
post #6 of 7 (permalink) Old 07-23-2017, 05:35 PM
Date registered: Jul 2011
Vehicle: 1994 S500 Coupe with 452,967 miles
Where did you find the elements? I've been repairing the vacuum diaphragm with glue, but don't know the part number to be able to find them. '94 S500 Coupe. You're right about the eyeglass screwdriver on the clips; they are very small.
ChrisP3 is offline
post #7 of 7 (permalink) Old 07-25-2017, 02:11 PM
Date registered: Mar 2009
Vehicle: '08 BMW 750LI, '10 Ford Expedition
Quoted: 35 Post(s)
I could supply the part numbers for a 1982 coupe but don't think that would be much help to you...
You need to be in the 140 forum and hopefully the moderator will move this thread.
innovation560 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
