Anyone ever LS1 swap a W123? Preferably a estate? - Page 4 - Mercedes-Benz Forum
post #31 of 39 (permalink) Old 10-06-2015, 09:01 AM
Date registered: Aug 2011
Vehicle: Diesels om616 -> om606
Quoted: 85 Post(s)
Originally Posted by 1884benz View Post
In currently almost finished with my swap. I ditched the gear box and swapped a rack and pinion from a w210 in, I was going to run a T56, which fits without modifying the trans tunnel, but switched directions since the 4L60E has a shorter first gear which will work better with the 2.65 rear gear im running. that's the only option for a factory lsd (450 sel 6.9 rear diff)
do you have pictures of how you adapted the rack and pinion? i would be super interested!
how much space did you save? if this is a valid option, it might be a good way to go instead of the crazy routing of the exhaust on my v12 s123 build, lacks space for the downpipe from the turbo on the driveside, so need route that behind the engine and join the passengerside downpipe
(yes i do have space for that routing, yes it is darn f-ing tight)
a rack and pinion would be better if/when i decide to make it somewhat driftable to.
w123 m275 v12 biturbo | Cars | Mercedes-Benz turbo
btw, the w126 and the r107 and w116 also had LSD as an extra,
3.06 and 3.07 large house from 450se/sl/slc,
3.27 in the 380SE/SEC
2.47 in the 380SE/SEC and 2.24 in the 500SE...
have both 3.27 and 2.47 and the 2.65, but am looking for the 3.07 in a LSD version, gearratio wise, the 2.47 was a little to though on the gearbox with dieseltorque
althou those are superrare in the us, but know of people that has imported the 3.07 from Canada here to Sweden.
they might not be as hard to find as the elusive 6.9 differential, but im not shure.
Daily: w123 om602 7.5mm 200whp
special/projects/storage: 20 cars +
swampmonkey is offline
post #32 of 39 (permalink) Old 10-06-2015, 09:12 AM
Date registered: Mar 2015
Quoted: 2 Post(s)
I do have some pictures somewhere of the rack and pinion. It saved so much room! Enough that I'll go back eventually and make some custom long tube headers for it. Here in the states basically the only LSD that's a direct bolt in is the 6.9 diff. It would be awesome to see if I can get my hands on one of those 3.07 diffs! My boss has a good friend in Germany and he goes over there a few times a year. So maybe they can find one for me. The rack and pinion is definitely the way to go! Didn't take much to notch the cross member and install.
1884benz is offline
post #33 of 39 (permalink) Old 10-06-2015, 07:04 PM
FratBoy's Avatar
Date registered: Jun 2006
Vehicle: 1980 280CE; 1982 300CD
Quoted: 32 Post(s)
Heh. Funny this thread should pop up...
Just last week I took the stroker out of Dad's 82 300SD. I have a 350 bored over to 360 going back in.
This is a quick pic I took to text to someone- I will get some more detailed ones after I clean it up.
FB
FratBoy is offline
post #34 of 39 (permalink) Old 10-07-2015, 06:09 AM
Quoted: 85 Post(s)
i need those pictures! like for real,
the last resort was to remove the brakebooster, adapt a hydrobrake to another place/ofset so i have the "downpipe" of the turbo going to close to the IC (modded for different inlet) to be comfortable, and then behind engine, above swaybar and down with the left side.
fitting the engine, next try | Mercedes-Benz turbo
this is advanced shoehorning as is :P and i have been thinking about the w210 rack and pinion a lot.
what is the ratio of that steering btw? where you able to get a more aggresive steeringangle? (was it a lot of mods, and would it be a valid option for a "drifter"?
im not building a "driftcar", but would be nice to have the oportunity to do some wide laps, a better steeringangle in case of
post #35 of 39 (permalink) Old 10-07-2015, 08:28 AM
Quoted: 2 Post(s)
Send me a pm with your email and I'll send you any pictures you need. I'm honestly not sure how the ratios compare. I didn't research them before hand. Because the w210 tandem pump was my best option for the rear suspension I just decided to go with the matching rack. I did have to get shorter outer tie rods. They were for a kia or something. Moog part number: MOG es3403. That v12 is crammed in there! Will be nasty as hell with those big turbos too!
1884benz is offline
post #36 of 39 (permalink) Old 10-07-2015, 02:55 PM
Quoted: 85 Post(s)
not using the turbo on the picture, going for smaler td04-19t something, wants to keep the stock "dieseltorque" 800nm from 1800rpm, and 1000nm from 2400rpm something. with two turbos i dont need to go hx40-hx50 in size :P
PM sent, hoping for pictures!
post #37 of 39 (permalink) Old 06-29-2017, 09:27 PM
Date registered: Jun 2017
Originally Posted by POS View Post
Most common is Ford - smaller, more lightweight, easier to swap in.
question about your ford comment. So I have a C class and a build 4.6 for a big turbo cuz the mustang I built it for got wrecked. So you're telling me you think It's possible to girl put it in my C class? Or at least better fit then a LS ?
MobbinSRT8 is offline
post #38 of 39 (permalink) Old 07-20-2017, 07:48 PM
u37
Date registered: Feb 2015
Vehicle: 1984 280ce - 1969 Dodge Superbee
I'm just curious has anybody ever thought of sticking one of those Cummings 2.8 diesels. Into one of these cars. Wouldn't even fit?
u37 is offline
post #39 of 39 (permalink) Old 07-21-2017, 06:37 AM
~PERMA BANNED~
Date registered: Mar 2006
Vehicle: 1982 300D
Quoted: 152 Post(s)
*Cummins
Its a great idea, if you have a spare $13,000 to throw a vehicle.
Forcedinduction is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Wet w123 estate floor montreal W123 E,CE,D,CD,TD,TE Class 10 11-13-2010 03:31 AM
w123 v w212 estate comparison PBS sd300td W123 E,CE,D,CD,TD,TE Class 6 05-27-2010 07:19 AM
WTF W123 4X4 not an estate but an actural 4x4 DVRDCT W123 E,CE,D,CD,TD,TE Class 12 12-11-2009 07:57 PM
Swap a E320 Estate for an E300? White_Knuckles W124 E,CE,D,TD Class 5 11-01-2007 08:03 AM
WANTED: W123, preferably 300D Turbo Leeyore For Sale/Wanted/Trade/Giveaway 4 08-02-2006 09:57 AM
